For those that have/have used y8 intake manifold
Old Sep 13, 2005
andyman97's Avatar
Turbo Guru
Did you guys have issues with the tps? Have you guys used the y8 tps and tb or d17 or what combinations? I am using the emanage with 440's and have been having a helluva time getting it to work right.
My issue is that when I hook up the tps the way it should read .5V when closed and 5V when open but it throws a cel every time. When I switch the outer two wires, it reads 5V when closed and .5V when open but it doesn't throw a cel.
Now, I am also throwing a cel because I'm running 440's and I have to use the injector correction factor or the car won't idle, it's way too rich. But, when I use the correction factor, it gives me a p1106 for the baro sensor every time. I'm wondering if they may be somehow related.
Any input welcomed.
Old Sep 13, 2005
dezod's Avatar
7thgen Power Maker
Any input welcomed.
They are related in the fact that the TPS is used to determine load in comparison with RPM to figure out which cells to read off your E-Manage maps. The E-Manage, once it determines which cell to read, it averages the surrounding cells to level the fuel delivery. Once this is done it alters the map signal accordingly to make the fuel delivery possible.
Old Sep 13, 2005
andyman97's Avatar
Turbo Guru
Right, I'm aware of that, but I'm trying to figure out if one issue can/will potentially cause another, of course with out ecu, nothing surprises me.
Old Sep 13, 2005
dezod's Avatar
7thgen Power Maker
One can cause the other. Think about it. TPS helps determine TP, which helps the e-manage determine how much to correct the MAP sensor reading. If your TPS is off, the whole rest of the equation is off.
Old Sep 13, 2005
andyman97's Avatar
Turbo Guru
I'm not asking if the tps can cause other cels for other things, what I'm trying to figure out is if other cels can cause an issue with the tps.
Old Sep 13, 2005
dezod's Avatar
7thgen Power Maker
Be more specific
Old Sep 13, 2005
andyman97's Avatar
Turbo Guru
I'm trying to figure out why I'm throwing a tps cel. I'm thinking it may have to do with using 440cc injectors with the emanage. What I'll probably end up doing is picking up some 310's temporarily until the aem 1030 comes out. I'm trying to get input from people who have had experience using the d16 intake manifold.
Old Sep 15, 2005
Daemones6's Avatar
Daemones6 is an unknown quantity at this point
Where can I get one of those?
Old Sep 16, 2005
blouisgod's Avatar
Life Begins > 6800rpms
how hard was this to install? did you need any extra parts other than the mani and d16 tb? im thinking about doing this - if i do maybe i can help.
Old Sep 16, 2005
andyman97's Avatar
Turbo Guru
Well, I'm looking at having a bracket fabbed to fit the d17 tb on the d16 im. If so, you can support all of your factory wiring by just lengthening the wires on the sensor clip. If we get something to work, I may see if I can get a few extra made which will make the d16 im a direct fit.
1sdxc The only other thing is that two new holes need to be drilled and you need a gasket. But again, Whatever the solution to the issue is, I'll post back.
Old Sep 16, 2005
blouisgod's Avatar
awesome! i scored an im for 100 complete...
Old Sep 16, 2005
tfnaaf's Avatar
BLDNPSI Mod
So your saying the manifold is a direct bolt up minus the TB flange/ wiring, and drilling what 2 holes?
Old Sep 17, 2005
02fpcivic's Avatar
02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light
it would be wise to port match the manifold as well. You can use the factory injector flange as a template.
