Camber Question
Camber Question
about to order Tein S-tech from a local shop and thinking about koni yellow shocks(atm i dont have enough for the shocks). should i wait until i have enough money for the springs and shocks or should i just get the springs right now and save up for shocks later? and will i need a camber kit. sorry im a newbie on this stuff
it will take a few weeks for the springs to settle in completely; so you should hold off on buying a camber kit till then. and yes, you do need a camber kit for any type of drop, unless it's really minor like a 1" drop (ex. HFP springs)
...JDMDC5...one day...one day...
If you dont have the money but want the drop NOW...i would get the springs because when you do get the struts, it is going to replace the stock strut any ways...Now as for installation...the whole strut-spring assembly will have to be taken apart twice, once to install the spring and once to replace the strut...As for a camber kit, you dont NEED one, just that one is recommended if you are concerned about rapid tire wear...My car doesnt look like the front needs one tooo much but the back definitely needs one...so its up too u...hope I helped...
Need to search first, there is a sticky on the top of this forum about any suspension stuff
http://www.7thgencivic.com/forums/sh...d.php?t=133266
PM Sent
martinsmartin
Aug 15, 2015 07:34 PM
