obx manifold and t3super 60
Old Aug 27, 2005
SuperFrankie's Avatar
SuperFrankie should not be trusted
any one running this? if so can i have a pic.. before anyone talks **** this is for cocky's car and this manifold is temp
but it won't fit the lower mount gets in the way hitting the turbo so wtf can somone help
Old Aug 27, 2005
MiamiUgen7's Avatar
you get what you pay for with a cheap manifold like that
Old Aug 27, 2005
turboengnr's Avatar
DONT PANIC
is his car an lx?
the ex motor has a slightly different front motor mount. Only has 2 bolts instead of 3.
Old Aug 27, 2005
its a dx
Old Aug 27, 2005
Shifty's Avatar
so the obx manifold wont fit and ex engine?
Old Aug 27, 2005
turboengnr's Avatar
DONT PANIC
it will fit an ex, wont fit an Lx/Dx unless you mod the motor mount. At least it wont with a turbo that large.
If you use a standard T3, it may fit.
Old Aug 27, 2005
Shifty's Avatar
Thank you very much turboengr, repped!!
*EDIT: sorry turboengr, apparently i cant rep you yet since i havent spread it around.....reps i mean....lol. I'll owe you one
Old Aug 27, 2005
MiamiUgen7's Avatar
you guys know the obx/SSAutochrome manifolds are total **** and always break, right???
http://honda-tech.com/zerothread?id=1281153
http://honda-tech.com/zerothread?id=1217312
Old Aug 27, 2005
Logan3024's Avatar
Originally Posted by turboengnr
is his car an lx?
wth? Where are you getting these facts from cause my LX has only 2 bolts, you may want to check again..
Old Aug 27, 2005
Logan3024's Avatar
Actually OBX and SSautochrome are not the same company. Though SSautochromes manifolds look identical to OBX, they are not the same, OBX is a better quality manifold than the SSautochrome.
Go to SSautochrome.com and youll see they dont even have a manifold for the D17.
Old Aug 27, 2005
turboengnr's Avatar
DONT PANIC
well, for some reason my car has 3 bolts. Mine is an Lx.
so have several of the cars i have built custom turbo systems on.
Old Aug 28, 2005
BlackFire's Avatar
BlackFire is an unknown quantity at this point
umm.... well.... mine is a 2001 EX 5spd manual and the front motor mount have 3 bolts.
Old Aug 28, 2005
turboengnr's Avatar
DONT PANIC
i dont know. just pointing out a possibility. because i had a kit for a 2002 civic ex that had a turbo performance manifold and turbo, that was actually installed on a 2002 ex. and it fit on that car. but for some reason hit my motor mount. Under closer inspection, that car had a 2 bolt mount
That was the first of about 7 turbo systems on my car.
Old Aug 28, 2005
turboengnr's Avatar
DONT PANIC
the turbo performance manifold is almost exactly the same as the OBX.
And the turbo system was the original setup off the fiber images car. Not the SF kit that was on it. They only had the TP kit for about 2 months before switching.
since this is getting off topic really fast, here is some advice.....
try using a turbo with a smaller scroll. The super 60 has a thick compressor housing. Try using a standard t3. .42int, .48exh. if that works, then your good.
If this is for a stock car, that smaller turbo will do just fine. I ran one of my fastest times with a turbo i got off a volvo in a junk yard.
nola000
Engine start problems
63
Feb 17, 2023 09:18 PM
SammySC
121
Apr 7, 2017 07:43 PM
jdh022764
18
Nov 3, 2015 06:44 AM
Mannimarco
Sep 7, 2015 10:01 PM
dantheman42
Sep 4, 2015 01:10 PM
