60,000 mile Transmission fluid change
I look in the DIY's and I didnt see how I can flush out my automatic transmission. Can someone refer me to a webpage or what not on how to do this. I dont feel like paying Honda to do the 60k mile maintenance and charging me an arm and a leg for it. Thanks guys, any help will be appreciated!
its the exact same procedure as motor oil changing. there should be a drain plug that you can access if your not lowered or up on jacks to be easier. unbolt, drain the atf, tighten back in, refill.
gearbox has an auto ex and hes not dropped, he claims he changed his atf without raising the car. also check out the manual, im sure it tells you what fluid you need and a procedure hopefully
2k1civic.com O. G.
yea if your not lowered, and you are thin and have a good reach. also if you know exaclty where the drain plug is. you could do it without jacking the car up.
You gotta be pretty strong too, becuase you kinda gotta knock it loose, just as if you would with the oil drain plug.
Originally Posted by TemjinX2
aren't you suppose to flush it at 60k rather then just drain it?
But basically jack the car up, look for the lower drain on the transmission (passenger side). Its the smaller plug that a socket wrench fits in. Open it up and drain it out. Than look for the drain thats on the same side of the tranny(passneger side) but a little higher up and more towards the firewall. Open that up. Hopefully you have a manual pump. The easiest way to get the fluid back in, is to get a manual pump. Plug the lower drain back up. Than set the new tranny fluid up near the battery, since it has to be higher than the place the fluid is going. Stick the smaller hose of the pump into the fluid. Cover the other end of the pump with your finger and pump a few times to get some pressure in the line. Fluid should start flowing. Now hurry and put the hose your covering in the top drain part thats still left open. try to make sure the hose is as low as you can get it in there (not too far in). Just so it stays still and doesnt leak fluid all over. Bolt it back up when it starts leaking out and is full.
You need about 1.6qts I think it is. 1.6 of the bottles is fine, so just buy 2.
This is for the manual tranny, but should be the same basic idea. The pump is only 5 or 6 bucks, and is a little rubber ball looking thing in the middle, with a hose on each end of it. you can get it at Ace Hardware. Use only Honda tranny fluid.
Costs about 18 bucks to do it yourself.
Ok I finally had time to pick up the hose and the fluid from Honda. I am looking under my car now and I am amazed at how many bolts there are to the transmission. I am confused on which one to loosen to drain the fluid. Can anyone tell me what bolt needs to be taken out?
why did you buy a hose? Anyway, the bolt is closet to the passenger wheel. It is a 3/4 lookiong bolt. All you need is a wrench to loosen it, no sockets. Look for the bolt that has the deep square end in it. that is the bolt. Replace the washer after you do this to prevent leaks.
wow i'm shocked you waited 60k miles on an auto. I did mine at 18k and it was filthy. Been doing it every 10k since then. Dealer does them now cause car is lowered and I can't fit under anymore.
yeah i did mine at 30k and it was nasty. The fluid wasn't even red anymore, it was more of a orangish brown color. The drain bolt on a auto is on the right side near the subframe. My bolt was painted blue. It was the only bolt that had some blue paint on it if that helps at all.
just look for the bolt that has a washer on it. And the bolt is the one that a 3/4 ratchet will just fit into. Stick a ratchet up there and find the bolt that the ratchet will fit into. the bolt is closest to the passenger wheel.
um no actually it says 30k for auto and even thats way too long.
you kno for a moderator, u don't seem to kno shiet. And after you read this, ur prolly gonna say some shiet like "wanna get banned?" Do you feel this immense power w/ ur empty threats of mere words? Yeah, ban me if it makes you feel good, but i'll always find my way back, after being banned like 5 times already. So gearbox, u can kiss my
! Last edited by AzNTiG3R; Jul 10, 2005 at 11:40 PM.
Oh hey sorry wasn't trying to upset you, just posting what I know from a maintenance brochure that was published by honda specifically for the 01+ civic. You need to calm down with that name calling, kid.
Drunken Master-7thgen Ninja
Here you go guys. Straight from Honda. Everything should be done under severe conditions unless you live in a perfect atmosphere, which doesn't exist. Please don't insult my intelligence. I've been here a long time and know quite a bit about civics actually.
not to question you but whats the point of normal service intervals if you say that it should always be under extreme conditions unless its a perfect environment. i don't get it.
Good question, and the answer is in the owners manual. You should follow severe maintenance if you drive under any of the following conditions:
1. driving less than 5 miles per trip, or less than 10 miles per trip in freezing temperatures.
2. Driving in extremely hot conditions 90F, 32C
3. Extensive idle or long periods of stop and go driving.
4. Driving with a roof rack, or through mountains.
5. Driving on muddy, dusty, or deiced roads.
I really don't think anyone can say they haven't done at least one of those.
i don't do any of those. i will be drivin in mountains in a couple of days though, but here in atlanta i don't do any of that crap. i stick with reg intervals. except i change my oil every 3k and i change my plugs every 60 k. ive only had the car 5 months and changed the plugs when i got it. i will be changing the timing belt soon though. not gonna wait till 90k. probably 80 or 85.
You don't have city traffic or drive in the winter? Must be nice. I always do 2, 3, and 5. If you get timing belt done, might as well get an oem pulley new and have them put that on along with waterpump. Since everything will be apart anyway...
no when i get that stuff changed i will be getting uderdrive pulleys and probably a lightweight flywheel, i will wait till 90k cause my warranty will almost be out anyway. what do you mean about the water pump?
ah okay. well usually they do the water pump with timing belt since everything needs to come out to change it. Better to do it with the timing belt than have it go out a year later and have to pay all that money again. When I get my cam gear in august, i'm getting timing belt, pulley, and water pump put on as well for the same $250 charge. If you don't already know, waterpump is part of the cooling system. It does just what it says...pumps coolant lol.
i just didn't know the pump needed to be changed also. but thanks for the heads up. when my ride hits 90 k im gonna have to order, the underdrive pulley, the cam gear and the flywheel to get my mechanic to do it all at once. new water pump price=?
Re: 60,000 mile Transmission fluid change
My 2001 Civic EX calls for a transmission fluid change at 120,000 and my Haynes repair book agrees.
