Height difference within the same set of springs?
Old Jul 2, 2005
wonderz's Avatar
wonderz is on a distinguished road
Question Height difference within the same set of springs?
Hi, does anyone know if there can be a height difference within the same set of springs for our cars?
my friend told me the rear springs are different from each other, like one is taller than the other.
thanks.
p.s. i know the front springs are different from rear, i am talking about within the 2 rear springs there are difference.
Old Jul 2, 2005
Akutenshi's Avatar
The Rizing Sun
i kno the answer...
(but im not tell jOo)
Old Jul 3, 2005
wonderz's Avatar
question.
Old Jul 3, 2005
R1Style's Avatar
whoever told you that lied. Both rear springs are the same height/shape/width/spring rate as one another... same goes for the fronts.
Old Jul 3, 2005
wonderz's Avatar
well, i sold him my new set of koni suspension kit, and when he opened the box, the rear springs are different...
Old Jul 3, 2005
same. only height difference would be on the car if they haven't settled.
Old Jul 3, 2005
wonderz's Avatar
that's weird...
'cause i think Koni only makes this set for our civics in either 50mm and 55mm version, which the springs should be the same in either case. i don't get how they could have messed up.
any chance they compensate the weight on driver side or something?
Old Jul 3, 2005
flotsamm's Avatar
The rear stock springs look identical for each side. Same thing for the Konis. If your friend is comparing stock to Koni, theyre gonna look different since stock is linear and Koni are progressive.
Old Jul 3, 2005
wonderz's Avatar
no, he's comparing koni rear spring to koni rear spring...
cukaracha
30
Jul 26, 2015 12:01 PM
JustaRhymez
General 7th Gen
Jul 10, 2015 07:12 AM
Ccoop87
Jul 9, 2015 03:26 PM
ballmich
Jul 9, 2015 11:59 AM
MamaBear2015
Jul 3, 2015 11:26 PM
