2001 Civic EX - front brake makes a clicking sound?
Old Jun 12, 2005
riversidetom's Avatar
riversidetom is an unknown quantity at this point
Hi,
New poster here. I have a question. My '01 Civic makes a clicking sound in the front left brake every once in a while. Normally hear it/feel it when I am almost to the end of my stop. Took the wheel off and didn't really see anything obviously loose but I am not much of a mechanic type.
Any thoughts as to what it could be?
Thanks in advance.
Tom
Old Jun 12, 2005
01_Civic_Lx's Avatar
01_Civic_Lx is an unknown quantity at this point
Well, I am not exactly sure the source of your problem but here is my 2 cents to get you off to a good start.
Before assuming that it is something major you need t olook at the primary parts of the braking system, Take the wheel off and loosen the pin and swing the caliper up. (If you have never serviced or replaced brakes take it to a mechanic). Make sure that the caliper pins are well lubricated, dust boots are intacts and have lube in them. Secondly take out the pads and make sure they are clean and have meat on them.... use a depth gauge to measure them.... at this time look the the rotor as well.... Wow this is getting long.... look at all other major components... lines etc.
Look for a issues.... you may also want to look at the caliper piston.... at times if it is sticking it can cause a clicking or rubbing sound...
Anyway best of luck and keep us posted... I hope thins will assist you.
Old Jun 12, 2005
sleekcivic2004's Avatar
sleekcivic2004 is just really nicesleekcivic2004 is just really nicesleekcivic2004 is just really nicesleekcivic2004 is just really nicesleekcivic2004 is just really nice
does it do it going forward and in reverse
Old Jun 12, 2005
D17thgen's Avatar
D17thgen has a spectacular aura aboutD17thgen has a spectacular aura aboutD17thgen has a spectacular aura about
is your car lowered?
after installing coilovers on mine, ive had the exact same problems and still happens til this day. idk any solutions though, sorry. my best guess would be indexing the struts... theres an DIY around here somewhere.
Old Jun 12, 2005
Boilermaker1's Avatar
Jap-Euro Fusion
If they're honda pads, its just the pad shifting in the clips. They don't seem to fit in perfectly. Don't worry about it.
Old Jun 13, 2005
jttegx's Avatar
OMNES AD UNUM
^same problem here. kinda freaks me out haha.
but your the suspension/wheel/brake/tire guru here, ill take ur word for it. but would replacing the pads with say AEM pads be a solution to this?
Old Jun 13, 2005
Jap-Euro Fusion
^^^ Most aftermaket pads fit a bit tighter. That answer wasn't me talking. That was the dealer talking... mine did it too, and there wasn't anything they could do to fix it.
Old Jun 13, 2005
Big Rob's Avatar
I'm taking over!
Big Rob has a little shameless behaviour in the past
I had some aftermarket pads installed a few weeks ago, and I had some problems. It was bad enough when the brakes stopped working as well, but when smoke started coming out of the wheel well due to them sticking, I decided that it was time to go with honda's brake pads. I'm never using different pads again unless I get new brakes completely.
Old Jun 17, 2005
x25xtalife's Avatar
x25xtalife is an unknown quantity at this point
Pad Shift. Honda Pads Are Made To Shift Forward And Backward To Help Wear The Pads Evenly. We Put Some Grease On Both Ends Of The Pads To Quite It Down A Bit. Customers Bltch All The Time.
Old Jun 17, 2005
D17thgen's Avatar
so would it be safe to use aftermarket pads on the factory braking system? say like AEM , hawks, EBC, etc?
Old Jun 18, 2005
Thanks for all the replies!
No car is not lowered. Completely stock 4DR sedan. Bought the "most expensive" pads (ceramic, i think) from Autozone. Doesn't do it constantly, just occasionally. Took the wheel off and with my mechanic buddy we didn't see anything visibly loose or broken. Seems to be only on the left side though unless I'm just not hearing the other side. Mostly notice it when almost at the end of my stop (15 m.p.h or less). Have never felt it/heard it in Reverse that I can think of.
Any of that info help you diagnose it? Think it just the pads shifting? They aren't Honda OEM pads that's for sure, but again they were like $50 @ AutoZone so they weren't cheapies.
Old Jun 18, 2005
Yoyoio's Avatar
Yoyoio is an unknown quantity at this point
My car does this click sound as you mention, i found out it was the axle nut that came lose. Tighten it and is perfect now. Try that.
Old Jul 5, 2005
AlpJLFan's Avatar
AlpJLFan is an unknown quantity at this point
i have that same issue. I find that it mostly does it after im done reversing then when i get in first and go around a turn and apply the brakes ill hear something click once. it never does it when im driving coming to a stop. just when im done reversing and start my journey in 1st
Old Jul 5, 2005
coop's Avatar
coop is a jewel in the roughcoop is a jewel in the roughcoop is a jewel in the rough
I get that noise and have wondered about it myself - how many of you have ABS?
Old Jul 5, 2005
Notorious SI-G's Avatar
Notorious SI-G is an unknown quantity at this point
Just an FYI, I had a similar noise and it was my worn out struts on the front. Replaced them and the noise is gone.
Old Jul 6, 2005
allmotor's Avatar
nor cal 7thgens
i have a vp and no abs all stock wheels and suspension and that same clicking sound also happens
Old Jul 20, 2005
jaredn's Avatar
jaredn is an unknown quantity at this point
also had loud popping noise when i would brake occasionally.... turned out to be my right control bushing rotted out...
Old Jul 22, 2005
Dirty4Door's Avatar
Dirty4Door is an unknown quantity at this point
dealer says that it's the brake calipers clunking back and forth like a pendulum. that's why it does it when you stop and go.
mine might be bad tho, because it clunks about 7 times before i even make it to the street of my work parking lot...while going forward.
Old Jul 23, 2005
Hmmm
I'm hearing mine more frequently now than I did when I originally posted this thread. Wondering if mine isn't the caliper(s) as well.
BUT what I do know is that I never ever heard it even once before I had my most recent brake job...........not Honda OEM pads either.
Old Jul 23, 2005
czechcivic's Avatar
czechcivic is an unknown quantity at this point
when I took my car in the dealer said its normal and how the braking system works in our cars....
Old Jul 23, 2005
well if that's the case, that sucks. it bugs me a lot for some reason.
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
mattdoc
Mar 14, 2017 12:10 PM
bsmiley
Apr 27, 2015 01:27 PM
TheCrimsonKing
Engine start problems
Apr 25, 2015 09:40 PM
liljoe
Nov 4, 2001 01:27 PM
