raced an srt4 with my type s
Old May 20, 2005
2k3hondaguy's Avatar
2k3hondaguy is an unknown quantity at this point
i raced an srt4 last night with my new type s the 4 had an upgraded blow off valve and intake and said his boost was turned up. he beat me but not quite as bad as i had intended. he beat me by about 2 car lengths.
Old May 20, 2005
S2000man01's Avatar
O RLY
i hope you're running hondata among other things....
Old May 20, 2005
hotrodcivic2004's Avatar
my civic has no boost
bullcrap, that cars got 50 horsepower+ over you. not to mention the torque difference since honda is notorious for low torque. he either gave up after 2 car lengths or you are just plain lying. that srt-4 shoulda torn u up.
Old May 20, 2005
nindoo's Avatar
Why is my vagina bleeding?
Ddi you guys race from a roll?
Old May 20, 2005
HondaGuy12's Avatar
Fiji Club Member
i concur.. is urs a 2005 or 02-04? (Rsx)
Old May 20, 2005
S2000man01's Avatar
O RLY
whoa calm down buddy. if he's modded with hondata i/h/e it's a very likely encounter. might wanna find out what mods HE has before you start slamming him.
Old May 20, 2005
nindoo's Avatar
with simple bolt ons on an 05 some poeple put a bit over 200hp
CAI, exhaust, DCRH this guy is putting 204whp. This car is fairly new maybe the HP will go up once the car is broken in.
http://forums.clubrsx.com/showthread...highlight=DCRH
Now that's not too weak.
Old May 20, 2005
AJ Quick's Avatar
AJ Quick is an unknown quantity at this point
Good job.
Old May 20, 2005
Vantage's Avatar
Vantage should not be trusted
I dont believe 2 car lengths...
STR4's with upgraded boost = 14.00ish cars,
Type S with a realistic Driver = 15.00ish cars....
Old May 20, 2005
tripledoublegs's Avatar
Euro-Spec
mid to high 13s
Old May 20, 2005
S2000man01's Avatar
O RLY
again, you people post with NO IDEA what mods he has.
Old May 20, 2005
quick silver's Avatar
472rwhp @ 7400 RPMs and 12.93 psi
quick silver has disabled reputation
You are on that substance known as crack!
Unless you have a Stage 2 or 3 SRT4 you are not going to tear up a K20A2. Give it up. SRT4s aren't the same as a WRX or an EVO so don't even play that card.
Gettin really sik of dumbazz people actin like they know what they are talkin bout. *** the dumbshyt...letz handle this on the track!
Old May 20, 2005
S2000man01's Avatar
O RLY
.... a stock SRT4 can run high 13's. no stage mods needed. a K20 RSX-S stands NO chance against an SRT4 unless the K20 is modded.
you might be the one on the crack. lol
Old May 20, 2005
bgoetz's Avatar
bgoetz is an unknown quantity at this point
Image of vin diesel running to his car. You are an idiot don't post here again
Old May 20, 2005
bgoetz's Avatar
Yes they can run high 13s (drivers race with hondas love child the s2k) and a good driver stock type s can run mid 14s. 1 second in 1/4 is around 8 or so cars
Old May 20, 2005
Are you sure? On what, drags? A stock SRT4 makes maybe 195 whp. A K20A2 with I/RH/E/#4 makes that no prob. I know the SRT4 still has an advantage torque wise.
There are some SRT4s in my area that I cannot wait to race...some EVOs / WRXs too but I aint messin with them until I am boosted. Aint no fool here.
I'll guarantee you that when I get my car back and broken in that I will run LOW 14s on street radials.
Old May 20, 2005
bgoetz's Avatar
^^^^nope a SRT4 is 210-220whp stock
Old May 20, 2005
bgoetz's Avatar
top end SRT4s give evos a run
Old May 20, 2005
bgoetz's Avatar
Did you swap to a type S if so you will run low 14s and be close to a SRT4. If you would have put the type R in like I had said you would be mid-high 13s. However if you hondata, cam, lsd, and put the flywheel in the type s I think that you will be close to low-mid 13s alot faster than a SRT4
Old May 20, 2005
HorrorSkopes's Avatar
HorrorSkopes is an unknown quantity at this point
Exclamation
the k20z makes impressive numbers modded, but still not enough when the srt4 is 230whp stock and the srt4 only weights in the 2900lb range.
Old May 20, 2005
bgoetz's Avatar
230 is a bit high, but not to far off. My #s were conservative (mustang dyno), I would say in reality my numbers are closer
Old May 20, 2005
Exclamation
A stock SRT4 makes 230 horsepower at the fly. Normal loss through the drivetrain is 15%. That means it is makin around 205 whp.
no bro, it well known fact that dodge under-rated the srt4 and that what you see is the "FLY", it's really "WHEEL" horsepower. The o3 (first year) was putting out 215whp, and the o4+ are putting 230whp.
Im not praising dodge, and could care less... but I know for a fact that it was determined. Take a look at srt4forums and look @ stock dynos... ull see
Old May 20, 2005
Ok dude...check out this link....
http://www.dodge.com/srt-4/performance.html
The 230 horsepower is at the fly, not the wheels.
Whenever a manufacturer states the horsepower / torque of their vehicle they are talkin about at the fly, not the wheels.
Old May 20, 2005
bgoetz's Avatar
I am makin this guarantee based on the fact that I have the resources (i.e., money) to make this happen.
Bring on the flamin.
Dude i like the idea that you have "the money" and you will have a fast car, but for real shut the fvck up. Icebergs vic was impressive, but in the end it is just a civic and nothing more. Even if you get a plate that says boostedk20 how many people will know the difference from your car and mine?? I will tell you this much I was very, very close to buying a K20A (and yes I have the $ and the $ for boost). I am going to save and buy a real performance car that can run a straight line as fast as your boosted K and run a track faster (z06, SCM3, SCSK, boosted 350Z ect.)
Old May 20, 2005
Exclamation
c'mon, are you that ignorant? I just stated "it well known fact that dodge under-rated the srt4 and that what you see is the "FLY", it's really "WHEEL" horsepower"
Do you really think a 195whp (what you state is stock) srt4 can run high 13's stock?
Old May 20, 2005
bgoetz's Avatar
I am not to shure what you what us to see?? Civic EX 127 mfr 110 whp= a loss of less than 10 percent. 230hp and worst case loss of 10 percent = 205 (10hp more than your original statement). And hp or trq does not mean **** the car is a high 13 low 14 car from the factory
Old May 20, 2005
15% power loss through the drivetrain is standard in the industry.
Old May 20, 2005
bgoetz's Avatar
Money or not you are just way to new to the entire thing. Save this post and in a year you will look at it a laugh at how big of a jackass you were
Old May 20, 2005
bgoetz's Avatar
Drivetrain loss is not a standard it just happens the less the better
Old May 20, 2005
Vantage's Avatar
it is true that dodge underrated ALL The SRT-4's and all the mopar bolt on kits/stages for it. They make abotu as much WHP as claimed at the crank. and just for the record. my friends SRT-4 with a stage 1 turbo ran a 13.7 on slicks, no way in hell a Type-S, even with bolt ons could even get close.
