RPM Limiting
Originally Posted by DaddyFatSacks
Theres no point, our reline in a EX is 7000, power starts falling off after 6500. Unless you just want the car to scream but be slow.
rpm
I understand dude for a standard engine. However after I custom make a new throttle, port, valve and increase the compression ration. This make a big big big different. My engine make so much power from 5000 rpm all the way untill 7000 and it during that the power is still there no sign of dropping at all. that's why i would like to know if it's possible.
Unfortunately, I cannot answer your question directly.
Look, thank you for all the comment pal. I ask if anyone can remove the stupid limiter. Not the advise how to mod cars. I am in Thailand and have a team who make a B16A engine (non-turbo or kompressor) run at 12.3 s 1/4 miles. And my car (all stock) just custom part polish and internal mod can run at 16.5 s so far for a D17z1 (non-vtec). We are not afriad to blow up the engine or anything. So .....
Originally Posted by 4drcivic2k1
You may want to learn about how a motor works before you decide to remove the limiter. It's there for a reason.
Thanks anyway
Can we stop straying away from the point........ CAN THE REV LIMITER BE REMOVED OTHER THAN WITH THE EMS????? Oh **** man we are on this site to share knowledge, ideas etc The man ask a question then answer if you can ..
Crower just released their cams for our application, so now more than ever we'll need to raise the rev limit.
My simple answer is that there must be a way.
Crower just released their cams for our application, so now more than ever we'll need to raise the rev limit. My simple answer is that there must be a way.
there is no easy way to raise the rev limit. The ecu does not have any maps for fuel or spark past the rev limit. You need AEM ems. that is the ONLY way.
Wow man don't bagg on the guy, if he knows what hes doing let him and if he doesn't know let him, its his car his decision. Just try to answer his question cuz thats what we are here for as a community.
I think you guys should check this out....
http://forum.miata.net/vb/showthread...6&page=1&pp=25
Is this possible the 7thgen ?
ChrisHandHonda
26
Sep 25, 2015 11:28 PM
Juanb24
Sep 15, 2015 12:39 AM
