Emergency
Old May 2, 2005
Kubias's Avatar
Member
Kubias is an unknown quantity at this point
Emergency
I am trying to ge my header off and the last bolt (of course) is rounding off. Is there another way to get it off??
Help!!!!!!!
Old May 2, 2005
Rennen's Avatar
New Mod on the Block
you could try that gator grip thing they have at wal-mart. i tried it and it worked pretty good.
Old May 2, 2005
Blahman240's Avatar
Touch it... He won't bite, He'll just come at you pretty quick.
Blahman240 is on a distinguished road
bolt breaker... Then a new bolt from a dealership... Or drill it out.
Old May 2, 2005
zachgeyer's Avatar
drill it my thoughts 100%
Old May 2, 2005
Kubias's Avatar
Member
Sorry, it's the nut off the block to the header. the one off to the far right.
Old May 2, 2005
Kubias's Avatar
Member
Was the bolt you used it on nearly rounded off??
Old May 2, 2005
Blahman240's Avatar
if its only one bolt... it won't affect exhaust flow at all... But get a replacement if you drill it asap.
Old May 2, 2005
Kubias's Avatar
Member
but, it's not the bolt. it's the nut.
Old May 2, 2005
AlienX's Avatar
AlienX will become famous soon enough
nutz eh... cut if off ! silly..
Old May 2, 2005
jeffsta17's Avatar
jeffsta17 is an unknown quantity at this point
Vice Grips and clamp them down real tight then hit it with a hammer, thats what I did. Also use lots of WD-40
Old May 2, 2005
Ashhole's Avatar
Ashho-san 7thgen Ninja
Ashhole will become famous soon enoughAshhole will become famous soon enough
i had the same problem. they got this stripped nut remover kit at Sears, for like $30. thign worked great. three turns and the nut was loose. thing digs into the stripped nut and wont let it go after that.
Old May 2, 2005
mykungfuisthebest's Avatar
mykungfuisthebest is an unknown quantity at this point
lol thats like a diy on how to strip a nut immidiately lol... but im glad you got it to work lol i would never do that
my friend broke one of those pin socket thingys from wall mart on a nut i got off with 1 hand with a good socket wrench.
best way to do it get a friend, and a breaker bar, one of you put all your weight foward against the bolt from the back of the wrench, other turn it with the breaker bar(or any steel pipe that fits snug around the back of your wrench.)
if this doesnt work, its not coming off w/o drilling. and make shure the engine is totaly cooled down before doing this as they expand like a mother when its 600 degrees lol.
Old May 3, 2005
Kubias's Avatar
Member
My buddy jay showed up and he had this idea and it worked. we had to take out the power steering but hey i'm back on track.
Old May 3, 2005
Kubias's Avatar
Member
Does anyone know if i remove my front sway bar with my car on ramps will the car drop or anything??
Old May 3, 2005
Blahman240's Avatar
way to thread jack.
Old May 3, 2005
trakfoot's Avatar
trakfoot will become famous soon enoughtrakfoot will become famous soon enough
I had the same problem and the things Ashhole was talking about... Grip outs (something of that nature) worked great. Get nice set from $20-$30.
Old May 3, 2005
dariusld's Avatar
dariusld is an unknown quantity at this point
Originally Posted by Blahman240
way to thread jack.
How can you jack your own thread?
I would save the drilling and cutting and all those other suggestions for last option. Aluminium is soft and delicate(easily stripped) be careful. Iv'e used the wd-40 and vise grips before and it worked and didn't work. I'd rather do that then drill it out My favorite tool for stuck anything, is a impact tool. It's not so much how stuck it is, as getting force on the nut.
Old May 3, 2005
turboengnr's Avatar
DONT PANIC
i had the same problem. The stock nuts are soo soft that if you use a chisel-style punch you can pretty much cut it in half with a 2.5 lb hammer.
Old May 3, 2005
Kubias's Avatar
Member
I am just running in to so may problems. I just AHHHHHHHHHHHHHHHHHHHH
