Weight reduction in preocess *Pics*
Old Apr 20, 2005
HyaBoosta's Avatar
Well in the never ending quest for better 1/4 mile times and free horsepower I am gutting the car. I have removed the rear seats and everything in the trunk. I am in the process of removing the sound reduction tar from the trunk,floor, under the carpet and firwall. I am saving it all to weigh in the end to let everyone know if it is really worth the effort. I will also be spraying the bare metal showing in the back black to match.Here are some pics of the process so far.
Old Apr 20, 2005
Civicly02's Avatar
let us know how it goes
Old Apr 20, 2005
PunkingCivic's Avatar
I need TP for my bunghole
cool, whatever floats your boat!
Old Apr 20, 2005
scansel912's Avatar
scansel912 is just really nicescansel912 is just really nicescansel912 is just really nicescansel912 is just really nice
How hard is it to take the back seats out? Im thinking about doing that and just my trunk. I wonder how much weight that is...?
Old Apr 20, 2005
FTK01CIVIC's Avatar
woah thats gutted... best of luck with your project!
Old Apr 20, 2005
booba5185's Avatar
7thgen Terminator Ninja
booba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to behold
all that and i wonder if it makes a big dif.
dont forget to take a poop before u race too, it'll make u lighter, and go naked with no shoes!!!!!!!!!! j/k unless u want to
Old Apr 20, 2005
Jrfish007's Avatar
I did that to one of my older civics.... didn't help much in the 1/4, maybe .1 or so. Sure helped in handling though.
Old Apr 20, 2005
Nick's Avatar
Formerly 2blu
I did that to my car once. It helped cuz i beat an impreza 1.5 that would usually walk me.
Old Apr 20, 2005
HyaBoosta's Avatar
yeah I think it makes a difference. I'll get on the scale and weigh everything I removed. when I go out to run I remove the passenger seat and that seat and bracket is pretty heavy. with what I have taken out it's about the difference of racing with a passenger and not.
Old Apr 20, 2005
aoar's Avatar
aoar is an unknown quantity at this point
remember to take a/c out.
Old Apr 20, 2005
djmota's Avatar
I have always wondered what the sound deadining material wieghed. Are you using the dry ice technique or just scraping it out? kepp us posted
Old Apr 20, 2005
nindoo's Avatar
Why is my vagina bleeding?
if you take off the tar is possible to put it back in case you change your wind later on?
Old Apr 20, 2005
xX03EXx's Avatar
Sweetest Dude on 7th Gen
Remember to race on near empty gas, that could kill your efforts. Also, take out the passenger seat if you are going to the track you can always put it in. Take out the plastic center console around the shift assembly.
Old Apr 20, 2005
AzNmiKex215's Avatar
2k1civic.com O. G.
take out all the speakers!
Old Apr 20, 2005
civic01vtec's Avatar
i am doing the same thing, but mine is for my custom trunk set up
it sux adding weight to a boosted car, but oh well
Old Apr 20, 2005
zachgeyer's Avatar
nice
Old Apr 20, 2005
zachgeyer's Avatar
careful you float away
Old Apr 20, 2005
tinman's Avatar
tinman is just really nicetinman is just really nicetinman is just really nicetinman is just really nicetinman is just really nice
You forgot the seatbelt in the back. And don't forget Grey's Gas door lightening DIY.
Old Apr 21, 2005
Ellocodetroit's Avatar
The Declaration of Independence was written on marijuna paper
Ellocodetroit is a jewel in the roughEllocodetroit is a jewel in the roughEllocodetroit is a jewel in the rough
Glove box can go to, Fuse cover, carpet, headliner. In the engine...Windshield wipers, wiper hoses, wiper motor, hood prop(??), Fuse cover, valve cover, winshield fluid reservoir.
Old Apr 21, 2005
jeffsta17's Avatar
jeffsta17 is an unknown quantity at this point
TAKE OFF YOUR BRAKES!!!!!!!!!! j/k i dunno man gutting ur car is cool for race, but im all show lol.
Old Apr 21, 2005
diskreet's Avatar
Old Apr 21, 2005
nickm748's Avatar
nice
Old Apr 21, 2005
eye_see_you's Avatar
let the devil out
all that material weighs in around 26lbs when its fully gutted. Andrew the "BEAR" has a 6 sec hacthback that has been stripped and thats about what it averages in most cars. If your running the strip it may be worth it, but a daily driver I just don't see the hassle is worth it
Old Apr 21, 2005
ren808's Avatar
ren808 is on a distinguished road
why dont you remove the engine and trans........that will diff lighten YOUR LOAD....
Old Apr 21, 2005
Sdcivic549's Avatar
Sdcivic549 is an unknown quantity at this point
My coupe is stripped and caged, the only thing left really is most of the stock dash minus all the guts, in the place of the HVAC are all the fan, ignition, power, fuel pump switches and oil, and water gauges. Chucking everything and basically only putting in a racing seat, harnass, cage, fire bottle, and nessecery electronic bits nets a good bit of savings. Remember cages are heavy so they take up alot of weight that you just took out but the stiffness that you gain is worth it in spades.
If you're using a full length exhaust you're carrying about 20lbs of ballast, cut it off just under the passenger seat and stick on a turndown with a little resonator. Chuck the stock seats and get a fixed back race seat with side mounts for a hefty loss. If you don't already have an intake chuck all the scilencer boxes under the hood, they weigh quite a bit. Get aluminum body coilovers, they're worth 5+lbs per corner over stock steel bits. Hollow swaybars are the only way to go, chuck all those crappy rubber bushings and go to solid wherever you can. Use solid upper shock mounts(tien pillowball), they are way lighter than the rubber bushed stock type. Get a racing battery, that's worth 10lbs or so. Go crazy and do plastic windows, C/F hood(a superthin racing type, not those OE replacements. Ditch the 18's for a set of light weight 15's. The list goes on and on.
My HX coupe's down to a mere 2115lbs on a full tank of gas with an EX engine and tranny and mainly I/H/E and it will give a modded GSR a run for it's money in a line and destroy it in the corners. Light = Fast
Old Apr 21, 2005
HyaBoosta's Avatar
thank you for that. Even if all this effort gets me .2 quicker on the 1/4 it's well worth it. what if you run a 13.1? well that little weight reduction makes you a 12 sec car and that sounds dam better then 13.1. Haters hate on
Old Apr 21, 2005
scansel912's Avatar
Let's see some pics. Fastest anyone's gone with bolt-ons on this site is 15.1 (slower than modded GSR's)
Old Apr 21, 2005
djmota's Avatar
that is one light *** coupe. any pics.
General DIY
Sep 25, 2015 08:02 PM
Jrosa
Sep 14, 2015 08:24 PM
montanacivic
Sep 7, 2015 08:48 AM
MamaBear2015
Aug 27, 2015 09:29 PM
Mr.Beefy
Aug 12, 2015 04:39 PM
