Les is the man! Pics of grounding kit install...
Old Apr 6, 2005
somethingcivic's Avatar
somethingcivic is an unknown quantity at this point
Les has done it again. Here are the pics for the instal on my 04 coupe. Ill do my best to describe what is going where. Thanks to Les for making it and hooking it up, without him I would have had to call in for some massive All photos were taken with my camera phone...sorry for the poor quality.
Pic 1: Just an overhead engine shot giving a good idea what it should look like.
Pic 2: Just to the left of the intake [may not be visible if you still have the stock air intake system on] top wire leading down is existing factory ground. Wire leading left grounds on negative terminal on battery.
Pic 3: Bottom wire is wire leading down from pic 2 - top wire attaches to the small bolt just to the right of the exaust heat shield.
Pic 4: Shot of lines leading to battery. The wire by itself attaches to the place where the fuse box is bolted down.
Pic 5: Long wire that attaches to intake [not visible if you have a stock air box] then attaches to battery.
You should only have 3 wires attached to your negative post. I added a 4th just to be safe - from the negative terminal to just below the battery where the exposed copper wire attaches.
ID:	51370   Click image for larger version
ID:	51371   Click image for larger version
ID:	51372   Click image for larger version
ID:	51373   Click image for larger version
Old Apr 6, 2005
Notty's Avatar
Notty will become famous soon enoughNotty will become famous soon enough
Yes he is the man...I just finished installing the kit on my 04 coupe a few minutes ago. Les' instructions made it too damn easy to see where they hooked up, along with your pics bro!!
LES
Old Apr 6, 2005
matrix311's Avatar
matrix311 is on a distinguished road
nice pics man, does it preform better?
your phone takes nice pics
i can't wait for the lg vx8100
Also that samsung phone you mentioned that will shoot all that video and ****, man that thing is like $1,000 on Ebay, that is way to much for that thing.
Old Apr 6, 2005
FALKEN's Avatar
Civicforums Junkie
i didnt get any instructions with my kit and right now its only half installed
i grounded to a different bolt on the alternator from whats pictured...that shouldnt be a problem, right??
Old Apr 7, 2005
Holy crap...ive never realized just how UGLY that samsung phone is...
Falken: That shouldnt be a prob as far as I can tell, give me a call or PM if you want me to walk you through whats left on your kit.
Old Apr 7, 2005
Tommy Tran's Avatar
Tommy Tran is an unknown quantity at this point
Ya GOSH!!! I havent heard from ya about the cable you need to fit over your airbox! Lemme know what you need and I'll knock it out!
Diff bolt shouldnt be a problem...
Warren have you noticed any difference with the auto tranny?
Peace
Old Apr 7, 2005
uberjeff's Avatar
uberjeff is an unknown quantity at this point
That Samsung phone on the auction is a different one than Verizon is getting. It is likely a Korean model. The Verizon Samsung A970 will probably look similar, but not exactly like that. Hopefully they will pimp it up a bit.
Old Apr 7, 2005
The car starts a bit quicker...but thats all ive really noticed. Ill pay closer attention...
That samsung BETTER be good loking...I also heard Verizon is getting a RAZR...
Old Apr 7, 2005
2K1Civic17"Gabe's Avatar
no 40 hp gain?
Old Apr 7, 2005
Tommy Tran's Avatar
Originally Posted by 2K1Civic17"Gabe
no 40 hp gain?
nah its .02hp per wire!!!
Peace
Old Apr 7, 2005
no 40 hp gain?
Well...I did choose the chrome eye connections over the gold ones...and chrome makes things go faster....yeah, im pushin 500hp at the wheels with 1 1/4 inch exaust! Les' grounding kit changed my life! Thanks Les for pimping my ride! [theme music here]
Old Apr 7, 2005
Tommy Tran's Avatar
Yeah the grounding kit has a way of changing your life!!! we should get a smaller exhaust on your car... with the smaller pipe the exhaust gas velocity would be insane!!! hehe
You think I could be the man if I sold my Grounding Kits to the dealership? That would be pimp!
Peace
Old Apr 10, 2005
Peace
Thats exactly what I was thinking, a custom 1/2 inch exaust system, with a glasspack. Tight. Then I could add the all important 'bleacher seat' wing on the back, the bigger the better.
Old Apr 11, 2005
FALKEN's Avatar
Civicforums Junkie
theres a nut missing on one of your ignition coils
Old Apr 15, 2005
I know. Ive had the car almost a year and a half...I SWEAR it came from the dealership like that...just never had the time to get one.
Old May 10, 2005
jttegx's Avatar
OMNES AD UNUM
bump for some advice. would you say this is one of the greatest groundint points you can do with the wires?
correct me if im wrong but i see:
-neg to chassis
-neg to throttle body? (is that point safe?)
-neg to lower engine block
-FROM lower engine block to existing ground
-FROM existing ground to valve cover nut
in this pic: how come you didnt use the same ground point but instead went with 2 separate ways?
Old May 10, 2005
Tommy Tran's Avatar
-neg to chassis
Ok yes neg to chassis is correct and the factory ground from the upper rad hose housing to the rad support... neg to TB is safe as long as the cable isnt touching anything that could get the jacket too hot...
For the two seperate grounds its the same piece of metal but just looked better and kept the cable from having to be run over or under the rad hose... all of the points are there for a reason!
I have some preliminary reports coming back over longer term monitoring and at least 1 person is reporting back an increase of 1.2mpg!
Peace
Old May 10, 2005
D17thgen's Avatar
D17thgen has a spectacular aura aboutD17thgen has a spectacular aura aboutD17thgen has a spectacular aura about
in this pic, i see 4 seperate grounding wires connected to the neg.
one to chassis
one to TB
one to radiator housing/engine block?
one to ???
Old May 10, 2005
Tommy Tran's Avatar
one to chassis
one to TB
one to ???
Ah yes, somethingcivic's car is an auto so there is ground to the tranny case as well. As close to the solenoids as possible...
Peace
Old May 11, 2005
I have FULL faith in Les' grounding abilities. The wires have been on since the thread started [date?] and I have not seen any adverse effects due to a lack of or over abundance of wire.
Old May 12, 2005
jttegx's Avatar
OMNES AD UNUM
^hey, would any of you guys have a detailed photo of where the auto tranny case is grounded ?
if no, can you describe it so i can check it out tomorrow morning? =D
thanks
Old May 12, 2005
Ill take a picture of it, then post it sometime in the morning.
Old Jun 8, 2005
jttegx's Avatar
OMNES AD UNUM
old thread, but i have 2 questions. got the pics of the auto tranny case ground point?
and by grounding the TB directly to negative battery post, does it serve a purpose? how about grounding it to chassis instead?
Old Jun 9, 2005
Id get that nut, haha. You dont want that moving around, getting dirt in there, getting a crappy spark in that cylinder. Go get a nut to screw!
juror
Suspension DIY
Jul 30, 2019 03:28 AM
Theshwartz35
Jul 18, 2015 10:49 PM
chrisjackson321
Jul 12, 2015 03:00 PM
