Zex Ignition Timing??
Old Apr 4, 2005
HeHateMe's Avatar
HeHateMe is an unknown quantity at this point
Well I just finished installing my Zex wet-kit on my 2004 Lx. Zex recommends checking the ignition timing,how do I do that? Whats the default timing set at? Any help??
Old Apr 4, 2005
djmota's Avatar
You cannot adjust the timing in our cars unless you are running and e-manage piggy back or if you had a standalone ecu. DOn't worry about it and do the other precautions...91 or higher octane when spraying and spark plugs 2 ranges colder than stock. you will be fine.
Old Apr 4, 2005
HeHateMe's Avatar
cool thanks, I purchased Zex sparkplugs with my kit.these should work?
Old Apr 5, 2005
2K1Civic17"Gabe's Avatar
same with turbo?? I am using IK20s, so that should be fine, and 91 octane is the highest I can find in AZ. Probably cuz its so hot, colder states need higher octane I guess cuz the airs more dense.
But is this the same for boost? I am freakin out about boosting more than 5lbs since I cant retard it.
pincookie1
May 4, 2015 12:22 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
Doc
Dec 12, 2001 11:47 AM
supercivic01
South
Nov 30, 2001 11:27 AM
ACEM2
Bolt-on Engine Performance
Nov 11, 2001 08:36 PM
