People with coilovers please answer!!!!
Old Jan 7, 2002
spoiledsteph
Guest
Posts: n/a
i just got coilovers installed, and i want to know if the ride is supposed to be hard...its mainly in the back though. it feels like there is no shock absorption at all if i hit a bump or pothole. it blows. can anyone say if this is normal or if i just got sh*tty coilovers. THey are OBX. thanks all
Old Jan 8, 2002
0100010's Avatar
0100010 is an unknown quantity at this point
Depends on how much drop you have, which determines how much suspension travel you have left.
Wait, you have OBX coil overs. Nevermind, thats your problem(most likely). Get yourself a set of Ground Controls. And them some Koni struts. And some Ingalls camber kits. Then tell me how your suspension is doing.
Old Jan 8, 2002
SpdRcrChk's Avatar
BOOST JUNKY
SpdRcrChk is an unknown quantity at this point
OBX....that's the problem....I agree. I have GC coil overs and my ride is nothing liek what you described. [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old Jan 27, 2002
new2civics's Avatar
new2civics is an unknown quantity at this point
Do you have to get new struts with any type of coil overs.? !
Old Jan 27, 2002
Becky's Avatar
Becky is an unknown quantity at this point
i have GC and its bumpier then stock but thats cause i still have stock shocks and there is no play. but its not that bad
Old Jan 28, 2002
2cute's Avatar
2cute is an unknown quantity at this point
OBX doesn't make coilovers for the 2k1 civic yet
Old Jan 28, 2002
01IncaPearl's Avatar
01IncaPearl is an unknown quantity at this point
<< OBX doesn't make coilovers for the 2k1 civic yet >>
wrong wrong wrong.
Old Jan 28, 2002
It has been said a million times in the past. YOU GET WHAT YOU PAY FOR. I learned the hard way and went with cheap coilovers and had a crappy ride. Much happier with my Neuspeed sports springs. It may not look as good or be as low but now I can at least drive down the road and not bounce all over the place.
Old Jan 28, 2002
TexazMane's Avatar
TexazMane is an unknown quantity at this point
well when i got my 1st installed i had my car slaaaamed to see what tha ride would be like.....it wuz bumpy as hell in the back especially..but when i raised it up some more the back doesn't bounce how it used too..also one of mine in the back wasn't sittin right...i got my coilovers from r-speed racing....i still got stock struts though and i got it to sit right so now its aight....but u prolly need to raise ur car. the 2k1's come stock wit the back high too so that should tell u somethin.
Old Jan 29, 2002
mykel115's Avatar
mykel115 is an unknown quantity at this point
I think when you drop your car too much the strut doesnt have enough play that it keep hitting the bump stop
Old Jan 29, 2002
oblivious9's Avatar
oblivious9 is an unknown quantity at this point
the stiffer, the better...otherwise you'll scrape. And you need different struts and a camber kit, otherwise you'll blow your struts and you'll have to buy new tires every month.
Old Feb 7, 2002
TeamStylesRacing's Avatar
TeamStylesRacing is an unknown quantity at this point
I have skunk2 coilovers, no camber kit yet, hopefully in a couple weeks. what does the strut do?
Old Feb 7, 2002
IonRays's Avatar
IonRays is an unknown quantity at this point
yea drop it 1.7 front / 1.5 rear
Old Feb 9, 2002
Turtle's Avatar
Turtle is an unknown quantity at this point
1.7" and 1.5"?? Thats all?? I went for 2.75" and 2.5". Stock struts and shocks too. Haven't even got a canber kit. The camber is only out 1 deg front and 1.4 deg rear. Nothing to worry about really soon.
Old Feb 18, 2002
CiViCBoY's Avatar
CiViCBoY is an unknown quantity at this point
Yup, that's it. Do not put OBX suspension problems on your car. They suck bigtime. Past experiences.
Old Feb 19, 2002
dreadmang's Avatar
dreadmang is an unknown quantity at this point
I am soon to have skunk2 coilovers for my car, they have been ordered for the past two weeks. however, when i have them installed, i am planning to replace the factory shocks. From what i've heard thats a must. ALSO, the motor sports dealer at the honda dealership i bought my car from told me that i would NOT need REAR camber correctors........ is this true?
____________
Old Mar 21, 2002
andypanda's Avatar
andypanda is an unknown quantity at this point
ur car is going to bounce no matter what kind of springs u get even aftermarket shocks and struts ur car will still bounce if u dont want ur car to bounce put ur stock springs back on
Old Mar 25, 2002
Essa's Avatar
Essa is an unknown quantity at this point
<< i just got coilovers installed, and i want to know if the ride is supposed to be hard...its mainly in the back though. it feels like there is no shock absorption at all if i hit a bump or pothole. it blows. can anyone say if this is normal or if i just got sh*tty coilovers. THey are OBX. thanks all >>
It all depends on how low you lower your car. If you lower it more than 2.75, your rear shocks start bottoming out no matter what kind of adjustable spring you have (even Ground Control) because your shocks don't have enough travel distance. Your car basiccaly sit on the shocks instead of the spring. That's why you feel like there were no shocks at all. The solution is, find a shorter shocks. Other shocks like koni, would help but you 'll still get the same problem every now and then, because they have the same length. IF you didn't lower your car more than that, check your bump stop (I doubt it though since you ask a professional to install it). IF you still have doubt, try to raise your car 1" for the back. Your problem will dissapear.
Hope this would help you.
Essa
Old May 28, 2002
frekyjason2002's Avatar
frekyjason2002 is an unknown quantity at this point
i have a 2k2 civic and i have the same problem with my coilovers in the back. i also have a problem in the front, when i turn left or right it makes cracking noises. during regular driving it squeaks. any suggestions????? im thinking about going to springs[IMG]i/expressions/face-icon-small-sad.gif[/IMG]
Old May 28, 2002
stillmatik23's Avatar
stillmatik23 is an unknown quantity at this point
i have GC and they are sweet with the ingalls camber kit...no problems whatsoever...get rid of the OBX..they only make decent exhausts..sorta..lol
Old May 29, 2002
htowncivicEX's Avatar
htowncivicEX is an unknown quantity at this point
<< i have a 2k2 civic and i have the same problem with my coilovers in the back. i also have a problem in the front, when i turn left or right it makes cracking noises. during regular driving it squeaks. any suggestions????? im thinking about going to springs[IMG]i/expressions/face-icon-small-sad.gif[/IMG] >>
If you have Ground Control coilovers, this is normal. GC's use polyurethane bushings, and when they become dry they tend to squeak. I wouldn't worry about it, but if it does bother you you could always use relubricate them to fix the prob.
Old Jun 3, 2002
i did oil the upper ring, the washers, and the adjustable ring and they work like my stock suspension now, it makes no noise at all. thanks.
Old Jun 5, 2002
HippyCivicEX012's Avatar
HippyCivicEX012 is an unknown quantity at this point
Im gettin my B&G and ingalls camber in the mail ill let u all know how it rides when i get them installed
Old Jun 5, 2002
teamstylesracing where did u get ur rh s-7's from and how much?
How low did u drop ur ride
SoslowEj666
Mar 8, 2016 01:10 AM
martinsmartin
Aug 15, 2015 07:34 PM
JKWood
Jul 28, 2015 03:45 PM
mHo2
Jul 27, 2015 12:57 PM
EM_WON
Jul 22, 2015 06:49 PM
