HELP! Will + rep you if you do! My friend drives a 97 Accord LX
Old Mar 31, 2005
QBoi's Avatar
the drivers side power window stopped working. He can make the window roll down, but not roll back up. All the other windows work okay. I'm guessing its the switch? Thanks!
Old Mar 31, 2005
Kadenx's Avatar
If the window rolls down...Its unlikely that its the switch....I bet its the motor....Check to see if the window goes up with you helping it along....If it does go up slowly with help...its the motor
Old Mar 31, 2005
eye_see_you's Avatar
let the devil out
I had this happen in my 02 vic. Unplug the switch make sure its clean and then plug it back in. all the switches have to be connected in order to have a complete circut so try it after that.
Old Mar 31, 2005
QBoi's Avatar
Thanks for the help guys, I'll pass the info along. Any more help is cool too!
Old Mar 31, 2005
Kadenx's Avatar
I doubt that a connector is unplugged since the other 1 or 3 roll down and up fine. The affected window, if I understand correctly, rolls down but not up. That would not be a disconnection problem....that would be a lack of proper voltage at the solenoid/motor or a bad solenoid/motor
Now wheres my REP!!
j/k
Old Mar 31, 2005
Blahman2's Avatar
One Slow Civic.... But I can take turns pretty well :-)
Blahman2 should not be trustedBlahman2 should not be trustedBlahman2 should not be trustedBlahman2 should not be trusted
its the motor, that gen accord had problems with the window motors... My moms motors are going out the window (pun intended)
Old Mar 31, 2005
QBoi's Avatar
You have given out too much Reputation in the last 24 hours, try again later.
I'll get you guys rep soon, sorry
Old Mar 31, 2005
DJ_NILOCIVIC03's Avatar
DJ_NILOCIVIC03 is an unknown quantity at this point
Can you hear the motor click when you try to roll it up? if you see that the motor doesn't even try its the switch but if you notice that the motor tries its either the regulator or the motor, but I work at a Salvage Yard and probably you won't be able to just find the motor or the regulator by it self......you got to buy them together.....
Old Apr 1, 2005
QBoi's Avatar
motor won't click. even if you press the switch, window wont roll up. cant get the window up at all. do we have to remove the door panel and replace the switch?
Old Apr 1, 2005
let the devil out
normally you can pop the piece off where the switches are and just replace it without removing the whole panel.I had the same wierd problem with my vic days ago. After reseating the connector and cleaning the contacts it started working again. just a test it may be more than that for you but just my .02
Xuhme
21
Aug 7, 2023 03:40 PM
F1wanabe
Apr 27, 2015 11:06 PM
tylerginevan
Apr 27, 2015 12:29 PM
smmahan
Apr 15, 2015 08:17 PM
