Retail Sales - site vendor annoucements Place for Vendors to post their specials and new stuff coming out or just advertise prices. These Vendors have been approved for posting in this section. Don't see anything new? PM them!
Ingalls Engine Torque Damper Coming Out Thursday for SI Hatch!! Get Yours Now!!
Old Mar 29, 2005
peteriap's Avatar
peteriap will become famous soon enoughpeteriap will become famous soon enough
Talking Ingalls Engine Torque Damper Coming Out Thursday for SI Hatch!! Get Yours Now!!
Hello, Peter with Import Auto Performance here with another 7thgencivic first time offer. The much anticipated Ingalls Engine Torque Damper for the SI hatch is being released Thursday!! Get yours now to reserve one while they still have them in stock. This item is going to sell out very, very quickly!
The price will be $159 with free shipping for all 7thgencivic customers.
Contact me if you have any questions.
Info and Pics from Ingalls:
Benefits
Greatly improved off-the-line acceleration
Reduced wheel hop
Improved vehicle stability
Reduced shock loads on driveline components
Smoother shifting
Reduced wear on exhaust system joints
Less vibration transmission to the driver compared to polyurethane motor mounts.
Less shock load, compared to torque straps and chains.
Drifting – helps reduce shock loads when wheels gain traction.
Reduces motor movement – decreases the chance of motor parts rubbing against
the hood and frame.
Specifications
Overall length (mount to mount) = 7 inches (+/-1/4 inch adjustment)
Mounting hole size = 10 mm (.3937 … approx. 3/8 inch)
Maximum stroke = +/-3/8 inch (no preload)
Preload adjustment = 0 – 3/16 inch (max stroke = +/- ¼ inch at max preload)
Maximum shock load (momentary) = 2000 lbs.
Maximum continuous load = 500 lbs.
High quality hardened steel reinforced Teflon Heim joints
Body: 6061-T6 Aluminum
Finish: clear silver anodize
Maximum Recommended HP = 500 with Energy Suspension or Solid Mounts
Old Mar 29, 2005
scatman's Avatar
Still in the game...
wierd, i thought they have been out for a while....arent they called "the stiffy"? anyways, judging from the pics, im assuming that they can be used with strut bars, right?
Old Mar 30, 2005
peteriap's Avatar
The Stiffy has been out for a little while but not the EP specific one with the direct bolt on brackets. Not sure about use with the strut bar.
Old Mar 30, 2005
scatman's Avatar
o, ok...i gotcha
Old Apr 12, 2005
peteriap's Avatar
Bump,Bump
thana
Jun 15, 2020 07:05 PM
Flipg123
May 8, 2015 01:15 PM
dooner24
Apr 14, 2015 07:51 PM
ernhole1
Dec 6, 2001 12:05 PM
eX2ooo
Oct 5, 2001 12:19 AM
