Spec V vs. Civic boosted?
Old Mar 27, 2005
civicrider01's Avatar
civicrider01 is an unknown quantity at this point
Who would win? a SE-R Spec V or a 2001 civic ex at 6 psi? From the line? Then from a 40 - 100 mph roll?
Old Mar 27, 2005
civicskater's Avatar
Chicks dig my scent
the sentra probably right off the line, but then the civic the whole way
as long as the driver can drive
Old Mar 27, 2005
the turbo civic no contest.
Old Mar 27, 2005
ACURAwerx's Avatar
ACURAwerx is on a distinguished road
my friend with a 2000 EX with i/h/e has raced two spec vs.. once with a passenger in his car (me) and the other guy had a passenger (which was a girl) so im assuming there was more weight added to the civic, it was probably from about a 40-100 roll (not planned, just happened) my friend floored it first, and the spec V (stock i assume) could never catch up or pass the civic... another time from stop my friend with the same civic (minus a header) raced a specv (modded i assume) with more weight added to it (1 more passenger i think, im not sure it happened some time ago) and the spec v was about half a car ahead the whole time and when we shut down (which was around 70 im guessing?) the spec V was starting to pull a little bit. I know the spec V is supposed to be weak off a roll and strong from a stop, but they aren't fast at all, especially if a civic can hang with it. Supposedly i think a specv with with i/h/e is supposed to hang with a wrx (so i've read)? so maybe modded they can get some power, but stock they are prettty weak. Spec V vs. a civic at 6 psi (untuned) would be no contest at all in any race.
Old Mar 27, 2005
02fpcivic's Avatar
02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light
my car on 6 pounds killed a lot of cars spec v is no prob
Old Mar 27, 2005
HorrorSkopes's Avatar
HorrorSkopes is an unknown quantity at this point
6psi?
what's that? 160whp 170whp...?
DIG:1st and 2nd goes to the specV, 3rd and beyond is all civic.
ROLL:SpecV will pull half way thru 2nd... but as 3rd comes along, civic all the way.
Old Mar 28, 2005
JetBlu01's Avatar
New Member
JetBlu01 is an unknown quantity at this point
I say civic on 6psi all the way b/c I think I ran like a 14.7 on like 6-6.5psi with like a 2.3 or 2.4 60'
Old Mar 28, 2005
ACURAwerx's Avatar
Originally Posted by HorrorSkopes
6psi?
it depends on the setup, tuning.. ect. Someone could have 170whp at 6psi while someone else has 140whp.. theres no set number. the general rule is 10hp every 1 psi though
Old Mar 28, 2005
Logan3024's Avatar
Its to bad civics need 6psi of boost to hang with a 17k NA spec v.
Old Mar 28, 2005
XxJDMCivicxX's Avatar
A Spec V is a 15 second car. If you can run under 15 you should be good, in this case i think you should somewhat easily be able to beat him.
Old Mar 28, 2005
SODJAZERO's Avatar
SODJAZERO is an unknown quantity at this point
I beat a spec v on 5lbs of boost. One in texas and one here in okc. It was easy... Boost wins
Old Mar 29, 2005
bgoetz's Avatar
bgoetz is an unknown quantity at this point
a spec v is a mid 15 sec car and the only one that I ran across is I was trying to pass and he downshifted and floored it so I down shifted and did the same. It was just me and he had a passenger I got passed him and he was pissed so he flew by me when I slowed to somewhat close to the speed limit and almost wrecked into oncoming traffic. So I would say the civic without a doubt.
Old Mar 29, 2005
civic01vtec's Avatar
lol......spec v would get destroyed
Old Mar 5, 2010
cagcivicokc's Avatar
cagcivicokc is an unknown quantity at this point
Re: Spec V vs. Civic boosted?
Civic
Old Mar 5, 2010
02civicsi02's Avatar
Low and slow!
The early 2000's spec v would get beat, but with the newer spec v it would be a good race. And damn only 160-170 whp with 6 psi. It would be a good race against my car.
Old Mar 6, 2010
89CRX's Avatar
89CRX is an unknown quantity at this point
civic would have no problem taking the spec v
Old Mar 12, 2010
Shade's Avatar
Shade is an unknown quantity at this point
what year civic? what engine civic? S/C or Turbo? Spec V only has 175 stock untill the new heavy bodys came out with 200hp. and not only that but almost every sentra weighs about 500+lbs more then most civics. my hatch weighs about 2300lbs
Old Mar 12, 2010
Shade's Avatar
now if it was stock to stock the spec V is way faster then a civic since the spec V runs a 15 and the ctock Civic runs a 17 stock unless you mean a 07+ Si that runs a 14.9 stock there are too many variables to just make some guess, go to the track and run the 1/4 mile for yourself then come back and post your real time and we can tell you what you would do to a SPec V.
Old Mar 12, 2010
Low and slow!
He said he has a 2001 honda civic ex which has the d17y8 and he is probably referring to a turbo.
Old Mar 24, 2010
Shade's Avatar
you sure you dont meean a D16Y8? the D17 doesnt have that much power even with the VTEC model. if its a D16Y8 then he would have about 127hp.
Found in
1999-2000 Honda Civic SR 1.6 Vtec (UK)
1996-1999 Honda Civic EX Sedan
1996-1999 Honda Civic EX Coupe
1996-2000 Honda Civic EX (US)
1996-2000 Honda Civic SI (Canada Only)
1997-2000 Acura 1.6EL (Canada Only)
1996-1997 Honda del Sol Si
1997-2000 Rover 416 Auto
Displacemnt : 1590cc
Bore and Stroke : 75 mm × 90 mm (3.0 in × 3.5 in)
Rod Length : 137 MM
Rod/Stroke : 1.52
Compression : 9.6:1
Valvetrain : SOHC VTEC 4 valves per cylinder
Power : 127 hp (94.7 kW, 129 ps) 6600 @ rpm
Torque : 111 ft·lbf (15.35 kg/m, 145.1 Nm) 5500@ rpm
Head Code : P2J
VTEC Switchover : 5500 rpm
Piston Code : P2P
Redline 6900 rpm
Rev Limited To 7200 rpm
ECU Code : P2P
and hes got about 8PSI? estimating about 8-10hp per PSI. so that be 64-80hp over stock. so yes id see the lighter car with about 200hp beating a heavy car with 200 hp every time, if the driver knows what hes doing. but seriously asking these questions dont prove anything, go to the track thats how you measure power.
Old Mar 24, 2010
ronaldo9's Avatar
I raced one back in my street racing days lol. I was stock and pulled about 3 cars at the start of the race then once my buddy hit 4rth gear in his Spec V he pulled me pretty good. So a boosted civic would have no problem with the added hp granted its tuned right to be able to beat the Spec V. Now if the Spec V is boosted..... no chance, they make some good power.
Old Mar 25, 2010
Low and slow!
Found in
Rod Length : 137 MM
Rod/Stroke : 1.52
Compression : 9.6:1
Head Code : P2J
Piston Code : P2P
Redline 6900 rpm
ECU Code : P2P
I dont remember why I put d17y8, I guess I was thinking bout the d16y8 and made a typing error. But the 2001 ex has a d17 vtec and produces 127 hp. And with 8 psi he will not get near 200 hp for one. A stock d17 vtec probably has 107 whp and with the turbo 8 psi you might be round 170-180 and that is stock 2010 sentra spec v territory. Hell you would be racing a earlier model with bolt ons and it will be sticking with you.
Old Mar 25, 2010
Low and slow!
And what car do you have?
ezone
24
Oct 30, 2017 11:27 AM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
eXNBP
Dec 9, 2001 12:32 AM
brill
Nov 12, 2001 07:29 PM
dubbc
Nov 7, 2001 02:24 PM
