Popping When I turn....
Old Feb 17, 2005
CaffeineCulture's Avatar
CaffeineCulture is an unknown quantity at this point
ok....lately when ive turned my wheel far to one side or the other i can hear a pop sound and feel it a bit as well....my sterring is fine and all, but why is it doing this lately? possibly cuz ive been going over rough bumps lately (lots of construction where i live)?? any tips or w/e is greatly appreciated!! thanx a lot
Old Feb 17, 2005
joshb_'s Avatar
Boosted 04
joshb_ is just really nicejoshb_ is just really nicejoshb_ is just really nicejoshb_ is just really nice
you could have a broken spring, your steering knuckle could be messed up (unlikely)....there are alot of problems that could cause a "popping sound".. Jack up your car and take a look see. If you have been doing alot of burn outs or driving your car really rough i would also check the cv joints after you check the suspension.
If you have after market springs, the spring may have to be re seated because you could have hit a bigger bump and it may have unsteated its self to the point when you turn its clicking into the right spot.
Old Feb 17, 2005
Bires's Avatar
Bires is an unknown quantity at this point
I had this exact same problem last fall. Luckily, my car (02) was still under warranty. You have a bad strut assembly, most likely the front left or front right.
Honda replaced three of mine until they got the bad one, since they knew it was the strut, but could not visually tell any damage.
Old Feb 18, 2005
streetglower's Avatar
honda sure knows how to hire and make technicians.
Old Feb 18, 2005
joshb_'s Avatar
Boosted 04
Yea, i have noticed alot are no good, thats why im appling there even tho ill be certified for toyota after the semister.
Your best bet is to bring it to honda, they will tell you the problem and it should be covered but if its not and its something simple just tell them you dont have money now and you will bring it back later. Then just go home and fix it.
Old Feb 19, 2005
ah ok...thanx alot...but yah, i jave been going over soem nasty bumps lately, but the clicking only happen sometimes when i make a sharp turn (like into a parking space) and my regualr driving is uneffected and there are no noises. While i got yall here, i gotta ask....why does my car vibrate so much on the inside (even when the stereo is off)!!?? My friends 2-door coupe seems very solid compared to mine....no rumbles at all!! just seems to me like my car is shakey....it drives fine and all and i dotn hear outside noise too much, but the constand vibrating and rumbling is odd...any suggestions ?!?!
Old Feb 19, 2005
this is also why im afraid to get my exhaust system....i dont want it to enhance the vibrating of my door panels (or w/e) and have them rumble all the time...will that even really happen ?
Old Feb 19, 2005
skiboard's Avatar
if you are hearing poping sound from front suspension, it might be your spring moving around. I had a same problem after lowering. I fixed it with new ball joints but it sometimes happens when it's cold
Old Feb 19, 2005
Bires's Avatar
Originally Posted by CaffeineCulture
...While i got yall here, i gotta ask....why does my car vibrate so much on the inside (even when the stereo is off)!!?? My friends 2-door coupe seems very solid compared to mine....no rumbles at all!! just seems to me like my car is shakey....it drives fine and all and i dotn hear outside noise too much, but the constand vibrating and rumbling is odd...any suggestions ?!?!
Check/Have Honda check your motor mounts. If you threw a mount, than the engine vibration will translate into the chassis.
Old Feb 19, 2005
DestnationUnkwn's Avatar
DestnationUnkwn is an unknown quantity at this point
Check the bolt on the top of the strut, the nylon locking bolt that attaches to the strut piston it might be a little loose. Happens sometimes. That should fix it. Let me know if it does.
Old Feb 21, 2005
so u think it may be an engine mount?? hmmmm...last time i told them it was the door panels that seemed to rumble and they "couldnt find anything" ,......i dunno if it is a mount tho cuz it never really vibrates when im idle or anything....usually when im moving and when my stereo is on! it really bothers me...even if it is the interior, what could it be and can they fix it? cuz some of the inside parts dont seem so solid to me (not like they falling off or anything, but they just seem kinda...bleh). My friends' civics all seem solid and dont rumble when they drive.....any help is always appreciated!! hope honda dont fick me over here!!
Old Feb 22, 2005
_Viper_'s Avatar
if it pops then its a CV joint that is shot
Nothing to do with shocks my friend.....
CV joint 100 %
Old Feb 22, 2005
ok....so its a CV joint...and if i fix it my car will not pop?!?! what about the vibrations lol...i really want them gone!! GERRR lol....also, will a CV cost me alot to replace???
Old Feb 22, 2005
hey bro dont die......id help yah....but...well yah lol.......GO RACE!! WooT!!
Old Feb 22, 2005
oh, and b4 i forget, I WHOOPED the hell outta a prelude with like $35,000 under the hood.....thats driving skills right there....and yes it was a set up sprint race thorugh windover farms.!! he even admitted that i whooped him good and that i got some serious driving skills!! i feel speshul!! ;-)
Old Feb 22, 2005
JDm7thGen's Avatar
Slow Down Im Gonna Spurt!!
JDm7thGen is an unknown quantity at this point
check the bearing plate at the top of your strut tower...
Old Feb 22, 2005
Bires's Avatar
CV joint 100 %
Maybe. Maybe not. It definately was the strut on my car, but maybe your pop is a different kind of pop.
Is it kind of a thud ? or a higher-pitched pop?
Generally, torn/worn CV boots make audible noises in all turns, not just at extremes like he's describing.
Old Feb 23, 2005
Exactly. CV Joints/boots usually make a constant clicking noise while turning.
Old Feb 23, 2005
yah, mines just when i turn far to one direction...and its more of a low thud...not a high-pitched click.....
Old Feb 24, 2005
Bires's Avatar
I would wager it's one of your struts. It translates through the pedals? If so-front strut, most likely.
You can try to resit them, if you have the means, but most likely Honda will want to replace them outright. I had mine replaced. The ride hasn't really changed at all with the new struts, just no more pop/thud.
Old Feb 28, 2005
true.....ive also noticed that the steering on my 4-door is a bit looser than the sterring on my frirnds 2-door....like her car can resist understerr a bit more and is a bit more solid than mine....is that the strut too, is that normal??
ricer_em2
May 11, 2016 08:09 PM
sesi
Oct 1, 2015 02:03 PM
Whitexj
Sep 30, 2015 02:04 AM
emiixo
Exterior
Sep 22, 2015 03:53 AM
JJ291
Sep 2, 2015 11:49 PM
