Knock clunk BANG 2001 Civic
Old Feb 13, 2005
Harley Rider's Avatar
Harley Rider is an unknown quantity at this point
Question:
Front end makes noise as if it was hit with a hammer when you hit a bump. How do I tell if it’s the struts? I jacked it up and shook, pulled, and pushed every part but heard or felt nothing wrong. With the car back on the ground I can push the front end down with little effort so it seems as the struts are shot. It’s my wives car so I’m assuming this has been going on for some time.
Thanks
Old Feb 13, 2005
Boost_Junkie's Avatar
Boost_Junkie has a spectacular aura aboutBoost_Junkie has a spectacular aura aboutBoost_Junkie has a spectacular aura about
shocks are blown, the shock is totally compressing and making that nocking noise
Old Feb 13, 2005
Boilermaker1's Avatar
Jap-Euro Fusion
Wouldnt suprise me if the struts have had it.... Honda had big problems with them blowing.
Old Feb 13, 2005
civichxtreme's Avatar
civichxtreme is an unknown quantity at this point
Also on the 01's some of em the springs area little different and the lower rungs actually knock together so look at the springs and see if there are any noticeable marks on them
Old Feb 13, 2005
chocobo15_2000's Avatar
§C§H§O§C§O§B§O
chocobo15_2000 is an unknown quantity at this point
its the struts alright...there was a recall long *** time ago about the 01 vics having a problem with the front struts blowing... I had one of mine replaced by the dealer aready, then got paranoid the others were gonna blow, so I went aftermarket. =/
Old Feb 13, 2005
Thank you everyone.
I just went to the store and when I hit a bump doing 40 it bounced like a baseball after the BIG BANG!!!
So can anyone tell me which ones are good and which ones to steer clear of? I took a quick look at the local auto places ad from around me in CT and the struts go from 150 to 350ea. That sucks. I was thinking shock costs.
Is this a hard job? I have no problem working on cars/bikes just don’t have any special tools (accept the ones I had to buy for my HD ).
Looks like 3 nuts up top and 2 big ones on the lower part to drop it out.
Old Feb 13, 2005
EM2jdm's Avatar
EM2jdm is an unknown quantity at this point
^^its pretty straight forward install, but the only problem i had when i took my struts out was the tie connection to the strut. If your still not sure let the professionals do it
Old Feb 13, 2005
Jap-Euro Fusion
Well, you can go for KYB GR2s... they're better than OEM replacements, probably the least expensive option
Tokico HPs are adjustable, they're gonna cost a little more though, and you'll probably be better off doing all 4.
Install isn't too hard. 2 bolts on the bottom, 3 on the top + the steering arm, swap the spring over and put it back together. There's a real good DIY on it in the DIY section, or if you search "Spring install" in this forum.
Old Feb 14, 2005
flotsamm's Avatar
Look around for any leaking or oil around the strut seals. If you find any, most likely theyre blown.
Old Feb 14, 2005
PunkingCivic's Avatar
I need TP for my bunghole
Just when you swap the fronts use this is a guide.
To make sure you put it right.
Old Feb 14, 2005
If you are going to replace them and it isn't really for performance or looks I would suggest the brand Tokico, and get the Blue strut/shocks set.
They are about $400 for all 4 and you could probibly get them cheaper on ebay.
They look like this:
mattdoc
Mar 14, 2017 12:10 PM
bambuski
Nov 12, 2001 10:35 PM
CapYoda
Nov 11, 2001 05:17 PM
Lightman
Nov 10, 2001 06:44 PM
liljoe
Nov 4, 2001 01:27 PM
