B&G's S3 coilovers.. direct fit on 03+?
Old Feb 6, 2005
jttegx's Avatar
OMNES AD UNUM
i know theirs been issues with the 03+ civics suspension bolts/mounts compared to the 01-02's. my question is would the B&G's S3 true coilover system bolt right up to the 2003 coupe? heres the link: http://www.tunersports.com/product_i...oducts_id=2001
has b&g made only 1 set thats specifically for 01-02 or does their one set fit all 01+ civics? Would the 2003+ owners need to purchase the 01 mounts? if so, anything else besides just the top mounts?
and lastly, anyone here riding on b&gs in their 03+ civic?
thanks
Old Feb 6, 2005
rijowysock's Avatar
ThE FaMiLy SeDaN
u asked this in my thread...
they will fit.. ur car has a wider bolt tho..
so what u gotta do is grab a B&G front.. and u get a drill or a "hole widener cant thing of technical name) drill it out so that ur oem bolt will fit thru...
top mounts=urs fit.. just they are said to make noises.. so u go out and buy some from honda 56$ or id just ride on 03 tops and IF i had a proble then buy em..if needed.. its not a "safety" issue w/ tops cause the B&G has a metal top peice.. its just a noise thing.. some have it some dont.
soo ina nut shell.. buy a B&G S3 for an 01... drill holes out a lil wider(no structualr difference casue theirs alot of extra metal.. and slap on w/ oe 03 tops.. wait a week listen no probs good to go.. problems buy 56$ in honda parts..
riley
btw B&G still for sale
Old Feb 6, 2005
Yoyoio's Avatar
Yoyoio is an unknown quantity at this point
riley
the 56 bux of OE part you're talking about. do you know what they are, part #?
thx
Old Feb 7, 2005
rijowysock's Avatar
ThE FaMiLy SeDaN
its been covered liek 500 times look around.. im not trying to be a search fiend but idk off head its listed on alot of B&G threads.. actually theirs a set forsale in FS forum..(01 upper mounts)
Old Feb 7, 2005
nickm748's Avatar
I heard you can just buy the 01 front camber kit and avoid drilling the holes from 14mm to 16mm
Old Feb 7, 2005
rijowysock's Avatar
ThE FaMiLy SeDaN
yeah, but u would then need both bolts... and your knuckle assembly is wider inside...so it would wobble..
drill coilover otherwise it'l wobble
Old Feb 7, 2005
rijowysock's Avatar
ThE FaMiLy SeDaN
riley
