2004 Civic EX sedan weird noises starting from a complete stop
Old Jan 30, 2005
mattnyc's Avatar
mattnyc is an unknown quantity at this point
Might be nothing...will check out at dealer on next oil change.
Whenever i start from a dead stop, and as the wheels begin to turn, i hear a metallic liquid sound. (Sounds like water boiling but with some metal in the pot). As soon as the wheels have made 1 or 2 revolutions the sound dissapears!???
its not very audible, but if i try to duplicate the noise with the glove box open, i can hear it better.
Any ideas what in the world could this be? I am not worried but curious.
Old Jan 31, 2005
koolaidman's Avatar
koolaidman is an unknown quantity at this point
what does metallic liquid sound like
record the sound if u can
Old Jan 31, 2005
streetglower's Avatar
means your boiling your blinker fluid
Old Jan 31, 2005
_Viper_'s Avatar
Holy **** My 05 does the same thing man.. From a dead stop usually in the morning or after its been sitting for a while i take off and i hear this weird sound..Exactly like you mention it..Its like a (Woooooo) then stops..Get it checked out please and let me know ok....
Old Jan 31, 2005
mattnyc's Avatar
its prob nothing. I beat the hell out of my automatic; put it into 3 unless i need to go long distances. Always trying to get vtec to engage.
I just hope it aint the tranny. it just sounds like some clunky fluid moving around? I am scheduled for Saturday.
Old Jan 31, 2005
koolaidman's Avatar
lose nut behind the wheel!
Old Jan 31, 2005
mattnyc's Avatar
Wait are you being serious or smart?
Did you mean lose nut (me the driver) behing the wheel of my civic?
Or a lose lug nut on the wheel?
Old Jan 31, 2005
_Viper_'s Avatar
Whatever it can't be a loose nut..
I think his Kool Aid is Spiked
Old Jan 31, 2005
koolaidman's Avatar
yes i was beeing sarcastic
where does my blinker fluid go?
Old Jan 31, 2005
k-man's Avatar
k-man is an unknown quantity at this point
your not alone guys, me too.........dont know what it is
Old Jan 31, 2005
mattnyc's Avatar
Well bad news is my service dept at paramus honda said they only check out sounds monday-friday! So i cant take it to them. I am going to ask my friend at acosta motorsport to check out the noise when installing my sway bar and front tower. I'll keep you guys posted. if any of you are due for service soon i would love for you guys to get this checked out by a certified honda serivice dept.
Old Jan 31, 2005
hotrodcivic2004's Avatar
my civic has no boost
......Always trying to get vtech to engage. ...
VTEC!!!!! and if you wanna get techincal its vtec-e
as for the sound. wat about coolant flow? i dunno i've never heard of this one before.
Old Jan 31, 2005
mattnyc's Avatar
Holy ****! I know better. That was a freudian slip
Old Feb 1, 2005
_Viper_'s Avatar
Its not koolant flow thats for sure its too loud for that actually..But thanks for that thought..
Old Feb 1, 2005
mattnyc's Avatar
I have been trying to isolate the sound. I tried moving the steering column to a different position and guess what!? the sound is still there but more muted. Can it be the mateiral that the adjustable steering column uses?
Old Feb 1, 2005
koolaidman's Avatar
Old Feb 1, 2005
mattnyc's Avatar
Well the sound is gone. Lower the steering column adjuster lever. Move the steering column up and down frantically like 20 times. then close the lever to your desired position. The sound should be gone.
Old Feb 1, 2005
_Viper_'s Avatar
Ill try that out for sure......
Thanks
Old Feb 1, 2005
mattnyc's Avatar
I think there is some type of plastic styrofoam that is causing the noise when the car starts to roll from a stop. I vagualy remember this problem with my 1995 civic coupe way back!
Old Feb 1, 2005
mattnyc's Avatar
the noises are still there. I dont know what the F this is. I will just check it this weekend. If i cant find the problem i am going to just ignore it.
I am rotating my tires this weekend so i will check if there is something caught on the axles, since the only time i ever hear this is when the axles/wheels go from non moving to a moving state.
mattnyc =
Old Feb 2, 2005
_Viper_'s Avatar
Go to the dealer with it and get it checked out........
Now read my other thread i just made Dammit im really pissed off now
Old Feb 2, 2005
mattnyc's Avatar
I am only avail on sat but my dealer said they only check out noises mon-frid. thats some BS. So when you go to your dealer to fix the coil spring, see if you can have them check it.
Old Feb 2, 2005
mattnyc's Avatar
I have an all day appt for tomorrow at Paramus honda. Got a $20 loaner car so they can diagnosis/fix it all day.
Old Feb 2, 2005
mattnyc's Avatar
On the way home i had some fun and just played with the throttle/gas pedal. it started to make the noise at wot. then when i went to local roads, the noise dissapeared when i tried to replicate from a dead stop. so maybe there was an issue with the throttle cable? can that make a vibrating noise from rest position through pressing the gas?
If so i am not going to go to honda service. I asked the svc manager why they wont investigate my noise on saturdays. his response was "well we have oil change only techs on weekends and you DONT want them doing anything to your car other than oil changes!"
Nuff said. I have to run some errands so i will try to play with my gas pedal and how fast or slow i press on it to see if the sound has really gone away.
Old Feb 2, 2005
mattnyc's Avatar
ok, i dont knwo why i didnt try this before but while parked i slowly pressed the gas and it made the noise as well. I then opened the glove box and held it in my hand while pressing the gas, same sound. but if i rev the engine harder and then try to slowly press it, the sound is either gone or barely audible.
So i have isolated the sound's source or a mechanical part connected to the source...
A)Throttle cable
B)Gas pedal
Any ideas on how to fix this? I really would prefer a DIY vs going to honda.
Old Feb 2, 2005
k-man's Avatar
interesting so does the noise happen for you only when you start the car up after it sitting for a while, or at all times?
i only really hear it after having the car sit for a period of time and then for the first 5-10 minutes of driving afterwards (longer depending how cold it is out)
Old Feb 2, 2005
mattnyc's Avatar
It has most of the time.
Old Feb 2, 2005
Dlmille's Avatar
Dlmille is an unknown quantity at this point
I to hear this sound in my 04' vic! I vaguely remember a post along time ago about this and heard someone mention something about the AC lines or something, once they had them flushed it went away. However, I can't remember if that post was directly related to this problem or something else.
I will probably try to get the vic into the dealer in the next couple of weeks because it is really starting to get annoying. I will post what I find out, if anything asap!!
Old Feb 3, 2005
mattnyc's Avatar
the car is at the dealer now. initial reaction by the service guy was "heating block has fluid that might be frozen. or it needs to be flushed." but i am worried because they have had it since 8:30am and when i called at 12, they said they are still working on it.
Old Feb 3, 2005
mattnyc's Avatar
fixed but not really. the sound is coming from the coolant and air bubbles built up in our heating/cooling system. my dealer has received several of the same complaints. They flushed/bleed everything and the noise is 99% gone.
He said that it will usually happen during the winter months and or when you use the heater. as well as make sudden changes in direction, ie the gas trapped in a 2 liter coke bottle. you flip it upside down and the bubble just moves. the sound of the coolant is mostly the part thats in the heater core, which holds the coolant right in front of the fan that blows through the vents, that heat/cool the car.
