adjustable cam gear explanation..
Old Jan 25, 2005
Method4's Avatar
Method4 is an unknown quantity at this point
can some one explain to me how an adjustable cam gear works?
Old Jan 25, 2005
someguy's Avatar
someguy is an unknown quantity at this point
you can advance or retard your cam timing.(make the valves open eariler or later) good for tuning.
Old Jan 25, 2005
Method4's Avatar
well does it add HP ?? sorry i completely new to this
Old Jan 25, 2005
someguy's Avatar
not unless you add a good cam to it. but on our cars i dont think so...like i said its for tuning. you can have it set so it works better in either low, mid or high rpm range. by that i mean how early or late the valves close helps in a different rpm range.
Old Jan 25, 2005
Method4's Avatar
i see. well thanks
Old Jan 25, 2005
Havok2k1's Avatar
Wicked Pissah Admin
It moves the powerband (usually not for the better)
Old Jan 25, 2005
Method4's Avatar
yea..
Old Jan 25, 2005
also if you mill the head cam timing might need adjusted
Old Jan 25, 2005
Method4's Avatar
o ok. seems crazy
Old Jan 30, 2005
ty.barrack's Avatar
ty.barrack is an unknown quantity at this point
yeah dead on, you may want one if you are running turbo, or nitrous for track days, but you really gotta know what you're doing with those, if you put it in wrong you could toast your engine really fast.
Old Jan 30, 2005
Mirage's Avatar
Mirage is an unknown quantity at this point
The real trick to using adjustable cam gears is to do the tuning on a dyno. There is no way you can do it otherwise. The HP gains are smaller than you can feel so unless you are going to dyno tune them dont even bother to put it on.
When the factories set up the initial cam specs, their #1 criteria is tailpipe emissions. Performance may be second or third behind fuel economy, but it is NEVER #1. With that in mind, an adjustable cam gear will let you dial in the cam timing for a bit more performance. It will give gains with a totally stock motor, just not very much. And not enough to justify the dyno expense if all you are doing is tuning the cam gears.
I have some dyno data of cam gears on an 01 LX with just a cold air. It picked up 2 HP on the top end. if anybody cares to see it, I can look for it and post it.
btw, the potential gains of adjustable cam gears on a stock motor are much increased if the motor is a DOHC because in addition to advancing or retarding the cams, you can split them from each other and that can help HP alot. Also, if you have lots of mods, then the stock cam timing will begin to really hold you back. If you have a milled head, them you have to have them or you cannot dial in your cam to it's proper location and "wrong" cam timing can kill your power in a hurry.
Old Jan 31, 2005
djmota's Avatar
If you could post that dyno I would like to see it. I hope it also has the final settings.
Old Jan 31, 2005
I ordered a new aem cam gear (5 bolt revised model) which is going on along with timing belt/crank pulley/waterpump in a few months. Camgear is getting tuned after that as well.
Old Jan 31, 2005
Mirage's Avatar
Here it is. 3 runs at each setting, standard, 2 degrees adv and 4 degrees advanced. All 3 runs combined for an average then compared to the averages of the other 2 settings.
btw, this is the only type of dyno comparison that you should accept. You will notice the variation run to run without any changes made to the car! averages of multiple runs when testing small gain components are required.
enjoy
File Type: zip
Old Jan 31, 2005
koolaidman's Avatar
koolaidman is an unknown quantity at this point
hondas r interferience fit to much or too little...time for a new head
Old Jan 31, 2005
Mirage's Avatar
true, but you have to be some kind of dumbshit to go +/- 20 degrees on a cam gear! typical best power numbers are going to be within 5 degrees of base.
Old Jan 31, 2005
so this is gonna help with milled head right?
Old Jan 31, 2005
Chris3k2's Avatar
Chris3k2 is an unknown quantity at this point
gearbox i thought u didn't like crank pulley's??? are u getting an aftermarket one or just replacing the oem??
Old Jan 31, 2005
replace oem pulley
Old Jan 31, 2005
koolaidman's Avatar
hey **** happens...the majority of the ppl on this site dont know what they are doing in the first place...so might as well warn them ahead of time
Old Jan 31, 2005
koolaidman's Avatar
no...only going to make the valves closer to the piston...if ne thing ur only raising ur compression
Old Jan 31, 2005
koolaidman's Avatar
y u going to replace the harmonic balancer...i wouldnt change it...if ur going to change ne thing BALANCE THE ENGINE!!!!!!!!!
Old Jan 31, 2005
um well doesn't raising compression increase power? As long as the cam gear does something...even if it's just making the valves at the right distance.
Old Jan 31, 2005
koolaidman's Avatar
LOL and where do i my blinker fluid
yes raising compression will increase hp and tq
but the valve timming will make the bigger difference...advancing - hp + tq retarding + hp - tq...dont remember whats what but that what it could do
if u really want to gain power
balance ur pistons
get a new head
Old Jan 31, 2005
okay thanks man. My head is okay, it's been ported and polished, with hi flow valves. Just want to make sure the cam gear will be useful. And how do you balance the engine?
Old Jan 31, 2005
koolaidman's Avatar
take out the pistons and weight them and drill somewhere on the skirt to balance...
ur better off gettin high compression pistons with total seal rings
Old Jan 31, 2005
What other mods can I do to make the car faster? I don't want intake and exhaust cause all it does is make noise and no gains. About engine stuff. I've already done accessory pullies, pnp head, valves, iridium plugs, now the cam gear, and vafcII for tuning.
Old Jan 31, 2005
koolaidman's Avatar
ecu tuning...boring lots more but its all custom work
how do u want to go about it
high hp or tq moster?
Old Jan 31, 2005
ajhdragon's Avatar
7thgens official a$$hole
[QUOTE=koolaidman]take out the pistons and weight them and drill somewhere on the skirt to balance...
Hmmm your acting like balanceing an engine is easy. Its not that easy to completly balance and engine and is definatly not for the avergae person. you really should be fairly experienced in building engines and how they work. I mean its not like yeah just pull them out, drill a little and boom. It takes precise machine work to do it right. And you would also have to balance each lobe and lifter of the cam, make sure all the rods are the same. It's one hell of a process. and is definatly not cheap. but how is that pnp head cause im thinking of milling it 3mm and doing a pnp, what kind of gains did you get?
Old Jan 31, 2005
koolaidman's Avatar
[QUOTE=ajhdragon]
ya its calle blue printing...
