Sponsored by:
Sponsored by: CARiD
What do you think of these hood pins/locks?
Old Jan 18, 2005
abmerop18's Avatar
Jam out with your clam out.
i dont really like the look of hood pins, but i understand the necessity of it on a CF hood and i do not want ones that anyone can just open the hood. so, what do you think of these?
http://cgi.ebay.com/ebaymotors/ws/eB...MakeTrack=true
Old Jan 18, 2005
C2i0v0i1C's Avatar
SuperMODrizd
so lets see, ur going to have to pull the lever on the hood release, get out, unlock the driver side, then unlock the pass side and then lift up in the middle
Old Jan 18, 2005
RiceRocketeer's Avatar
Custom Titles are played out
RiceRocketeer has a spectacular aura aboutRiceRocketeer has a spectacular aura aboutRiceRocketeer has a spectacular aura about
anything to be safe?
Old Jan 18, 2005
sumyungviet's Avatar
sumyungviet is an unknown quantity at this point
and then how hard is it gonna be to close??? to try and fit 3 things to lock at same time???
Old Jan 18, 2005
xproductionz's Avatar
xproductionz is just really nicexproductionz is just really nicexproductionz is just really nicexproductionz is just really nice
i have used those before..basically after its installed you unlock the hood first then pull the hood release and then release the hatch under the hood.. to close the hood you just close it like you regularly and push the hood down.. then lock it.. i think the only bad thing about those is if your hood is locked and you must get under the hood cause something happened then the hood locks will only slow you down... especially if you have a fire and need to put it out and cant get under there fast enough to put it out
Old Jan 19, 2005
y.e.c.r.'s Avatar
y.e.c.r. is an unknown quantity at this point
dont worry about it man. it's not a big deal. you dont have to pull the hood release. just get out of your car, unlocking the locks will take you 20 seconds max, then pull the lever under the hood like normal. it might be a little bit annoying to install them initially because you need to match the locks up perfectly, but after that it's not a problem.
Old Jan 19, 2005
zachgeyer's Avatar
hum they look nice
Old Jan 19, 2005
jfan's Avatar
I never liked the circular ones. Even if its carbon fiber, I think the different weave pattern will make it obivous that it is there.
Old Jan 19, 2005
djmota's Avatar
I think they would look a hell of a lot cleaner than normal hood pins. With a little bit of added security (keeping would be thieves away from your battery to disable your alarm) I would sport em if I had a fiber hood.
Old Jan 19, 2005
manahoonie's Avatar
is that any different than pull the lever on the hood release (i've seen a few hoods that have it), get out, undo the driverside, then undo the pass side and then lift up in the middle??? or minus the hood release.
SammySC
121
Apr 7, 2017 07:43 PM
UltraHDGames
Jun 8, 2016 05:16 PM
Bikergofast
Detailing
Nov 20, 2015 02:34 PM
rnaodm
Sep 21, 2015 12:42 PM
AyyeeGeorgee
Sep 14, 2015 12:54 PM
