Which oil filter wrench do I use for the small honda oil filters?
Old Jan 2, 2005
nonbox's Avatar
nonbox is an unknown quantity at this point
I have a 03 civic si. Can you recommend a good oil filter wrench for the small honda oil filters? Is there an oil filter wrench that you place on top of the oil filter and use a socket and ratchet to turn the hex on top of the oil filter wrench? There's not much room for the metal band oil filter wrenches. Please post urls. Thanks.
__________________________________________________ ________________
http://free.hostdepartment.com/n/nonbox00
Old Jan 2, 2005
streetglower's Avatar
you really shouldnt need one, just use your strength and twist it off. But go to a local autozone or something, they have them. Just grab the filter and compare which one fits. All you need is a racthet, an extension piece, and it works fine.
Old Jan 2, 2005
civic01vtec's Avatar
i always use channelocks cuz all of my filter wrenches are too big
Old Jan 2, 2005
R1Style's Avatar
Get one of those wrenches that you use with the adjustable rubber strap.... that's what I use and it works fine.
BTW... Just because you hand tighten an oil filter... doesn't mean you can loosen them by hand.
Old Jan 7, 2005
thoughthard's Avatar
thoughthard is an unknown quantity at this point
I have one of these stuck in my trunk. Uses a standard socket wrench. Bought it just in case whichever quick lube place I use has a problem getting the oil filter off of my non-7thgencivic. Happened in the past. They lost the right tool to remove the oil filter, and they tried channellocks, the band oil filter wrenches, screwdrivers they jabbed into it, etc. Took them 50 minutes to finally get the correct tool from a parts store. Idiots.
Old Jan 8, 2005
profuse007's Avatar
Senior Member
profuse007 is an unknown quantity at this point
3.99 from harborfreight.com
Old Jan 8, 2005
solo_rider's Avatar
solo_rider is an unknown quantity at this point
you shouldn't need one. i change my own oil and the filter is real easy to take off.
Old Jan 8, 2005
profuse007's Avatar
Senior Member
i upload a pic onto this site. i use this site as a host, btw. what happen to it?
anyways, i always hand tighten mine and have to be opened by a tool. over time the seal is stuck to the metal parts.
Old Jan 8, 2005
dragoon's Avatar
the general rule is to loosen it with a tool and tighten it by hand. i bought one of the universal ones that go on the top of the filter and it works fine.
Old Jan 10, 2005
luciferi's Avatar
luciferi is an unknown quantity at this point
You can buy a factory Honda socket at the dealer.
Old Jan 10, 2005
mradam85's Avatar
mradam85 should not be trustedmradam85 should not be trustedmradam85 should not be trusted
i can always get mine off by hand
carid
Apr 30, 2015 07:00 AM
jessicakaybby
Apr 20, 2015 12:11 PM
dooner24
Apr 14, 2015 07:51 PM
