vacuum and idle
Old Dec 20, 2004
kikoy's Avatar
kikoy has a little shameless behaviour in the past
vacuum and idle
i tried searching and i found that the computer must relearn everything?....also my vacuum is playing around 10-20 hg/mm(50-65kpa)
should i let the car learn again or do i still have vacuum leaks? ignition(it also could make the vacuum erratic)/misfire?
i don't a check engine light on so......am kinda lost though......
and yeah i blew my intake manifold before so i changed manifold and new gaskets on the intake side inc. the map sensor.....
i'd appreciate any opinions on what i got in my hand....thanks in advance.....
Old Dec 20, 2004
kikoy's Avatar
anyone?
Old Dec 21, 2004
S2000man01's Avatar
O RLY
start over..... what happened to your car, and what did you replace? and now the issure you are having is a low vacuum rate? (10-20hg/mm.... is this during closed loop or open loop... idle... full throttle, etc)
Old Dec 21, 2004
lkm's Avatar
lkm
Super Member
lkm should not be trustedlkm should not be trustedlkm should not be trustedlkm should not be trustedlkm should not be trustedlkm should not be trustedlkm should not be trustedlkm should not be trustedlkm should not be trustedlkm should not be trustedlkm should not be trusted
omg, this is so over my head. Wth are you guys talking about?
Old Dec 21, 2004
kikoy's Avatar
i replaced my intake manifold(from blowing it up) and the base plate injector gasket along w/ all gaskets at the intake side.....
now am having an erratic vacuum reading along w/ surging rpm's(650-1500 +/-)
what would have gone wrong?
Old Dec 21, 2004
robo1040's Avatar
Once you go Black on Black, You Never Go Back.
robo1040 will become famous soon enough
i have no idea what happened in the first place, but if your saying you "blew up" your intake mani then you might have some other problems from the origional problem that cause it to blow. what was it a nitrous miss or somthing? there isnt much there to not hook up right that would cause the surging and weird vaccume reading, make sure the gasket went on straight, ive messed one of thoes up before, make sure injectors and everything is tight and in place, btw, what was the problem in the first place?
Old Dec 21, 2004
robo1040's Avatar
ohh yeah, and if your having this problem right after doing to work on it, it might be normal, after i did my head gasket my car took about a half hour of driving and idleing to finally start working right, i had a idle/stalling problem
Old Dec 21, 2004
S2000man01's Avatar
O RLY
yeah double check your hose connections, gaskets, etc, and try resetting your ecu. then drive it a bit and the ecu may simply have to re-learn.
Old Dec 21, 2004
kikoy's Avatar
yeah...i guess so....and yeah i blew my intake w/ a nitrous back-fire....
SimpleUser
Apr 24, 2021 02:54 AM
Rlss
24
Feb 26, 2016 09:42 PM
Martinez8o5
Jul 31, 2015 10:58 PM
silentz
Jul 9, 2015 08:16 PM
