What is meant by kick back?
Old Dec 14, 2001
02Si's Avatar
02Si is an unknown quantity at this point
I read this relatively old thread about auto tranny kick back? Auto tranny kick back
I think I may have it.
My exampleis this. I go reverse, brake to stop, change gears to D, let go of the brake, then I begin moving forward, then a very tiny jerk occurs soon after moving forward.
Old Dec 14, 2001
Doc's Avatar
Doc
Doc is an unknown quantity at this point
Assuming you are coming to a complete stop after backing up before putting the car in a foward gear, it sounds like the transmission has not fully engaged into gear. This may be caused by "low line pressure", this is the pressure of the transmission fluid that actuates gear engagement. It can be adjusted by your dealer through the ECU. There are other causes for this late gear engagement but this is the most common. I would have your dealer check it out, a little bit of time spent to check it out and fix the problem now can save big $$$ later.
tylerginevan
Apr 27, 2015 12:29 PM
Braun
Apr 23, 2015 09:03 PM
