Rear Speakers in a coupe
Old Nov 3, 2004
Blahman2's Avatar
One Slow Civic.... But I can take turns pretty well :-)
Blahman2 should not be trustedBlahman2 should not be trustedBlahman2 should not be trustedBlahman2 should not be trusted
Is there a DIY? I tried searching but nothing came up. Would it be the same as in a sedan?
Old Nov 3, 2004
Blahman2's Avatar
please some one help!
Old Nov 3, 2004
MegaHurtz's Avatar
http://www.7thgencivic.com/forums/sh...d.php?t=155281
It was in the DIY section
Old Nov 3, 2004
Blahman2's Avatar
thanks alot
Old Nov 4, 2004
coop's Avatar
coop is a jewel in the roughcoop is a jewel in the roughcoop is a jewel in the rough
watch the white clips in the rear deck - remove it carefully and make sure they are ALL accounted for during reassembly.
Old Nov 4, 2004
Blahman2's Avatar
I know, I've seen the clips before with my door speakers. The door speakers are soo much easier to replace.
Old Nov 4, 2004
coop's Avatar
deck rattle is your risk if you miss any of them - and you DON'T want to have everything back together only to discover that problem....if it's the first time coming apart, use a pair of pliers or somethign to squeeze them out from underneath as you pop the panel off....
Jeffdp
Aug 5, 2015 11:38 AM
Jeffdp
Jun 18, 2015 06:18 PM
Galvezj11
Jun 17, 2015 04:13 PM
PimpBot5000
Nov 26, 2001 07:15 PM
BabyLX
Nov 16, 2001 05:53 PM
