UPDATE!! GOT PICS UP : i got my hids in my tyc finally
Old Oct 28, 2004
kimchi29's Avatar
soooon to be psshh
kimchi29 is an unknown quantity at this point
i finally got them in. just need to do a lil more aiming and then should be done. im going to take pictures tonight at night since its only like 2pm here. they look pretty sexy. now only if i knew how to do a retrofit in them =) will work for now, i must admit i see sooo much more though. thanks to impulse and riceboy for the help. you guys rock!
Pic with tycs and hids off
Pics with tycs and hids on (warming up i think)
Cutoff pic 1
cutoff pic 2 with some ground beam patterns
couldnt get any night headlight shots since my camera kinda sucks =)
could i get some feedbacks on the headlights
Old Oct 28, 2004
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
Diy!
Old Oct 28, 2004
congrats man.. cant wait to see 'em.. i'm doin a retrofit soon, so if/when i figure it out and you need help, feel free to ask.. lol
Old Oct 28, 2004
W1LLY_G's Avatar
Cant wait to see them!!!!
Old Oct 28, 2004
KaZeLL's Avatar
KaZeLL will become famous soon enough
nice...ive always wondered how they would look in TYC
Old Oct 28, 2004
kimchi29's Avatar
soooon to be psshh
bump, feedbacks after you guys seem them please i personally love them
Old Oct 28, 2004
fonto's Avatar
The LA Clipper
Sweet!!
Old Oct 28, 2004
Man that looks sexy
Old Oct 29, 2004
karlozc2003's Avatar
karlozc2003 should not be trusted
Nice !
Old Oct 29, 2004
Civic_Racer9's Avatar
(SnOwBoArDeR | FoReVeR)
look at that nice clean cut of the light beam
Old Oct 29, 2004
Ramones's Avatar
Ramones is an unknown quantity at this point
Really nice cut off.
Old Oct 29, 2004
runner1738's Avatar
so what exactly did you put in your tycs and how much did it cost you? i have tycs and have been thinking about doing something liek this since i love night driving but still cant see enough
Old Oct 29, 2004
reflekt's Avatar
reflekt is an unknown quantity at this point
oh ****, that looks really good. can you give us some details. and yeah...like what derek said, DIY?? I have stock blacked out headlights right now, but the light visibility sucks.
Old Oct 29, 2004
kimchi29's Avatar
soooon to be psshh
heres the diy i got from riceboy. Im going to quote you riceboy!!!!!!
i'm pretty sure you have the headlights out of the car. if you dont, then do so... also, replace your headlight fuses (stock 15A fuses) with at least 20A fuses. dont forget to test the bulbs before breaking the seal, just in case one bulb doesnt work, so you can get a free replacement bulb (in case you're having problems trying to fire them up, look below...)
anyways, if you try and fit the h1 hid bulb into the tyc housing, it will not fit. you will have to file/drill/bore out the hole that the bulb goes into. you're prolly gonna have to drill out/file out a lot of metal to get the bulb to fit. if you look at the base of the bulb, there's a little plastic...shield looking thing that you're gonna have to fit into the housing as well. i also ended up filing down the black plastic backing a little because a little 'nub' on the housing was keeping me from inserting the bulb all the way in. now, put the bulb in the housing and BE CAREFUL!!! when i was doing this part of the installation, i put a hairline fracture in the stick thing that goes from the top of the bulb to the bottom. luckily, i didnt mess up the wire inside the insulation (i'm assuming thats what it is). repeat on the other side.
now that you got the bulbs in, plug the stock wiring harness into the tyc wiring harness, and the tyc harness into the HID wiring to the ballast, and the ballast wiring to the bulbs (that is kind of a given though...). now, the "tricky" part. low beams on the TYCs are blue and black. high beams are red and black. this was how it was in my case, so, just for reassurance, plug in a regular h1 bulb (assuming you have one) into one set and turn on the low beams. now that you figured out what the low beam wire colors are, plug that into the HID kit. the tricky part about this step is that the wiring on the TYCs are reversed. essentially, you're gonna plug in the positive (red) HID wire (harness to ballast) to the black wire, and the negative (black) HID wire to the blue wire. it took me a couple days of attempting to plug in the kit to realize that.
now, find a good position for the ballast and plug everything in where they're supposed to be. so what you want with wires and whatnot. i am yet to re-install my weather seal, and so far, i still have no fogging (i also siliconed the hell out of the edges when i first got the TYCs...). however, i am gonna put that one soon, and i'm also doing a retrofit, so it's all going to come together after i do that. dont forget to aim the headlights.
if you got any more questions, get me on aim at kimchi29. the wiring was custom for the kit i had. i guess its different by every kit. i got h1 kits. and my friend did the wiring for me. ill take pics of the wiring and such in the day. hit me up at aim on kimchi29, email at kimchi29@gmail.com or call my cell at 562 644 8799
Old Oct 29, 2004
ImPulse's Avatar
Looks nice Hardly any glare... I' am glad that you are happy with the kit
Old Oct 29, 2004
chicohonda02's Avatar
Since 2002 Baby!
looking good dude
mikey1
21
Aug 27, 2015 06:38 AM
