Sponsored by:
Sponsored by: CARiD
Energy Suspension motor mount inserts
Old Oct 23, 2004
bgoetz's Avatar
bgoetz is an unknown quantity at this point
Thumbs up Energy Suspension motor mount inserts
Honestly the best mod for the cash. You can get them at summit racing and they are only $30. The install is not difficult at all may take 3hrs (.5 on the front mount and 2.5 on the rear mount). The rear is kind of hard to get on and off and takes patients, but it is well worth it. If you have a manual 7th gen this is a must due to the fact that it eliminates any and all wheelhop. The car does have a bit more vibration through the body especially in lower rmps, but the benifits more than make up for this. The engine just plain runs better and creates a mush tighter feeling to the entire car even handling. Due to the lack of engine movement I would expect to see an decrease of maybe 2hp lose between the crank in the wheels so +2hp, and even greater difference in tourqe (which every 7th gen can use). Go get yourself some you will not be disapointed you are more than welcome to PM me with install questions
Old Oct 23, 2004
Jeff's Avatar
Jeff is an unknown quantity at this point
I installed those a while back on my 01 civic. They work pretty good, except for the fact that your whole freakon car shakes. But thats the price you pay for performace =)
By the way does your hood rattle when you have your ac on and the cars at a idle? Mine does now.
Old Oct 23, 2004
C2i0v0i1C's Avatar
SuperMODrizd
am i missing somethign here, what are we talking about, post a pict of these things
Old Oct 23, 2004
RiceRocketeer's Avatar
Custom Titles are played out
RiceRocketeer has a spectacular aura aboutRiceRocketeer has a spectacular aura aboutRiceRocketeer has a spectacular aura about
good find
I'd rather have wheel hop than a shitty idle...
Old Oct 23, 2004
Jeff's Avatar
There poly urathane motor mount inserts. You take your motor mounts out and slap the inserts into the opening of the motor mounts making the mount stiffer. This then makes engine vibration vibrate into the car. And also makes it help with wheel hop.
Also on mine, I had to trim the honda mount to get them to fit correctly.
Old Oct 24, 2004
AceKicker's Avatar
AceKicker is an unknown quantity at this point
i went to summit racing and i couldnt find where to buy them can someone give me a direct link
Old Oct 24, 2004
Jeff's Avatar
I bought mine from tornactive.com
http://www.tornactive.com/pd_energy_...civic_01on.cfm
Old Oct 24, 2004
Redline04's Avatar
AKA Mr. 60ft. Not to be confused with Civic_Redline
Redline04 is an unknown quantity at this point
got mine sittin here, hopefully next weekend I'll do the install. Not quite sure how to go about it yet.
Old Oct 24, 2004
bgoetz's Avatar
you don,t have a shitty idel it actually idles better, however at the low rpms it vibrates the car more. They are not to bad to install the front is easy the rear I had to
1. unbolt the entire engine mount from the subframe
2. rotate it so I could get a wrench in to unbolt the bracket (part the hooks to the tranny) from the OEM dampener.
3. I was then able to fit both peices out to put in the insert
4. I then bolted the dampener piece back on to the subframe
5. then slid the bracket the conects to the tranny back in and on to the dampener and bolted everything back up
6. It was not to hard, but took a bit of patience to get everything out and then back in
Old Oct 24, 2004
abmerop18's Avatar
Jam out with your clam out.
hmm. i might have to do this
Old Oct 24, 2004
Redline04's Avatar
wiil the two side mounts support the engine when you remove the front and rear?
Old Oct 24, 2004
Jeff's Avatar
I did my one at a time, front then replaced it, then went and worked on the rear.
Old Oct 25, 2004
LiKEaFeRiO's Avatar
Is there any motor mount available for A/T?
Energy Suspension says its M/T only.
There isn't a difference is there?
Old Oct 25, 2004
Eeeeeeh's Avatar
Eeeeeeh is an unknown quantity at this point
[QUOTE=bgoetz]Due to the lack of engine movement I would expect to see an decrease of maybe 2hp lose between the crank in the wheels so +2hp, and even greater difference in tourqe (which every 7th gen can use).QUOTE]
How can you see a decrease in hp and tq from installing motor mounts?
Old Oct 25, 2004
FuzzBeC00L's Avatar
Fuzzy Boy
There not all that good
Old Oct 25, 2004
bgoetz's Avatar
[QUOTE=Eeeeeeh]
A decrease in loss so a overall gain. Sorry to confuse you
Old Dec 29, 2004
CivicHX01's Avatar
sorry to bring this thread back from the dead... but i can't seem to find these bushings anywhere... i wanna get them but dunno where... can't find them on summit racing or tornactive...
Old Dec 29, 2004
KalliGarri's Avatar
A.K.A BlackCar --- Not From Califorina!
KalliGarri is on a distinguished road
so.... ur saying spend 30 bux.. HAVE A SHITTY RIDE!
Old Dec 29, 2004
civicvtec1ps's Avatar
Search and Learn
No, not really.
Es mm insert aren't even bad .
Not much differences in idel, just slight more rattle.
Get them if you are looking to eliminate wheelhops and better responces.
I am using engine damper and they work just good as es motormounts.
But I havn't seen any engine damper for 7thgen coupe,sedans yet.
So get es motormounts, it's good mod.
Old Dec 29, 2004
carbonfiberEm's Avatar
carbonfiberEm is an unknown quantity at this point
a definate if you have power or drive hard...I need to get some NOW! 6 puck clutch like requires them to pull out hard.
Old Dec 29, 2004
nickm748's Avatar
Eh, dosent seem worth it for a rattle ride
Old Jan 4, 2005
CivicHX01's Avatar
so no one knows where to get them?
Old Jan 4, 2005
aznstylez254's Avatar
Jspek Inspired
aznstylez254 is an unknown quantity at this point
^^ robearracing.com and optionsauto.com has them.
Old Jan 11, 2005
b18c1boy's Avatar
b18c1boy is an unknown quantity at this point
i got mine for 20 bucks from cp racing.
Old Jan 12, 2005
usafstud's Avatar
so u don't need a cherry pick at all for this install?
just unbolt one mout(F/R) at a time?
Old Jan 12, 2005
bgoetz's Avatar
yep . The back is a bitch
Old Jan 12, 2005
usafstud's Avatar
pain to take out or in
or both
Old Jan 12, 2005
robbclark1's Avatar
Retired suspension supermod.
You better get them usafstud before you rip one! haha hmm maybe i should get them. my friend has them on his Se-R and it feels like a massage chair at idle!
Old Jan 12, 2005
Redline04's Avatar
yeah it can be a little rough at idle and things will rattle especially if 75% of your interior is gutted like mine. Wheel hop is gone and that's all that matters to me.
I had to cut my rear and yes it was a bitch to install and cut.
Old Jan 14, 2005
thebigjap's Avatar
thebigjap is an unknown quantity at this point
Is this what you guys were talking about?
http://cgi.ebay.com/ebaymotors/ws/eB...sPageName=WD1V
