hey guys gotta couple questions about audio
Abercrombie and Fitch
Alright guys, which box do I get for my 15 inch sub? the logic case smalll vented or medium vented? they will both fit in our cars.... I just need to know which one is better...
http://www.cardomain.com/item/QLCQLH15015SE
http://www.cardomain.com/item/QLCQLH22515SE
And.......... My speaker is an 8 ohm speaker, will it be decent with a 2 channel amp? Again... im not a bass bass head i just want something decent.. thanks guys!
ur leaving out stats, the box depends on what your sub requires and if ur sub is 8ohm it depends on ur wiring, is it single or dual voice coil.. what wattage rms is your sub what wattage rms is the amp you want to use? as long as the amp is bridgeable and gives the wattage you want @ an 8ohm load you should be fine..
http://jlaudio.com/tutorials/wiring/index.html << wiring guide.. btw SVC = single voice coil and DVC = dual voice coil.. just incase you didnt know.. if your sub is just listed as 8ohm, then its most likely a single if its dual it will say 8ohm+8ohm or dual 8ohm, (im not even sure if they make DVC 8ohm subs, I really have no idea) but that is the basic idea of how things go..
oh yea.. vented = ported, most likely the stats will list a cu ft for sealed and ported.. so just reference ur stats/user guide for the sub..
ok, so ur off to a good start, the problem is the 400 and 900 can either be wattage in RMS or PEAK, rms = continuous, peak can be listed as max, or a variety of other things.. you want to try and match the rms, but keep in mind the ohm loads, an amp that is 400w rms @ 4ohms isnt 400w rms @ 2ohms or 8ohms
heres a link how the sub looks like... i just need to know if i should geta large or medium enclosure guys.. thanks!! SPECS Strike 15" SVC 8 ohm -300 watts RMS/900 watts Max · Injection molded polypropylene cone · 2 in. 4-Layer voice coil · Rubber surround · Double stacked magnet
this will really help me out!!
http://www.audio-n-more.com/lightnin...ages/S3_15.jpg
jbradley4809
Apr 7, 2017 04:23 AM
dosmastr
May 5, 2015 12:19 PM
zack22490
Apr 29, 2015 03:17 PM
