Max boost WITHOUT Alcohol Injection?
Old Oct 21, 2004
Ahtasham's Avatar
Ahtasham is an unknown quantity at this point
Whats the max boost you guys are running without using alcohol injection (or retarding the timing) without any problems. I have an external wastegate thats preset to 5 psi but at higher rpms it goes up till 6 psi. I have the Profec E01 but havent installed it yet. How much boost can I run without using alchy inj on a stock engine?
Secondly, those of you using the alchy inj, did you guys ever had any kinda problems with it? And what mixture do you guys use? 50-50? Or pure methanol. Its methanol right?
Old Oct 22, 2004
JetBlu01's Avatar
New Member
JetBlu01 is an unknown quantity at this point
I have my alcohol set for 7psi so I say 7psi...I'm running like 90/10 alcohol but I'm going to switch to methanol soon...I have it in my garage but I'm just waiting to run out of alcohol b/c i'm too lazy to drain the alcohol
EDIT: I run 5psi low and 8psi high so at 5spi, no alcohol for me
Old Oct 22, 2004
Ahtasham's Avatar
Are you using the windshield water bottle and pump or do you have an another setup for the that?
Old Oct 23, 2004
JetBlu01's Avatar
New Member
Old Oct 23, 2004
Ahtasham's Avatar
What about the rest of the poeple here? How much boost do you guys run without using alcohol injection?
Old Oct 23, 2004
oeleven's Avatar
oeleven is an unknown quantity at this point
im running 5psi low setting and 9psi high setting no alchy no problems
Old Oct 23, 2004
C Orndorff's Avatar
Once boosted now i-VTEC
C Orndorff is an unknown quantity at this point
I run 1 gallon of Xylene in my gas tank to every 10 gallons of 91 gas this makes my octane alot higher. this is for 12 to 15lbs of boost (built block)
Old Oct 24, 2004
guns's Avatar
Skyline R33
guns is an unknown quantity at this point
8psi without Methanol. 12psi with meth shot from the windshield wiper bottle and pump.
At 250whp Pure Methanol owns you.
Old Oct 25, 2004
Ahtasham's Avatar
You ran 250 whp on stock internals??? And how were you able to handle the tire spin at that much power?
I am just running 5-6 psi without alcohol right now and when I put my foot flat in the third gear I get tire spin (205/55 R15) when the turbo spools up to peak power.
Old Oct 25, 2004
chesireCAT's Avatar
chesireCAT is an unknown quantity at this point
Are you on the stock clutch (wheel spin in 3rd gear....), I hardly get wheel spin anywhere on 5psi with t3/t4b
Brandon
Old Oct 25, 2004
guns's Avatar
Skyline R33
17" tires and I would drop tire air to 16lbs at the track. ALso you probably need a ACT extreme clutch/pressure plate. Are you sure its tire spin and not clutch slip. Both will peg the redline.
Old Oct 25, 2004
Ahtasham's Avatar
Yes I got the ACT XTSS setup and the prolite flywheel
I need new tires though. I just bought 16" wheels and now looking around for tires. I dont have much options where I live. The best I can do is Yohohama AVS sport or Goodyear Eagle F1.
What tire size do you recommend? 205/50 or 215/45 ??? This is also my daily drive car so I am kinda leaning towards 205's. But do let me know what you think!
Old Oct 25, 2004
Ahtasham's Avatar
And by the way Guns how much did you 'run in' (break in) your ACT Clutch?
Old Oct 26, 2004
JetBlu01's Avatar
New Member
WOW!! I can chirp SHIFTING into 3rd....
yeah I think your tires (ahtasham) SUCK!!
Old Oct 26, 2004
civic01vtec's Avatar
i can't chirp shifting into 2nd anymore...........i think i need a clutch
oh yeah, my alchy setting is like 6.5 - 7 psi.
Old Oct 27, 2004
JetBlu01's Avatar
New Member
this is with my STOCK tires on though...not 18's...
bowie
Jan 21, 2018 09:29 PM
h4ldol
Apr 24, 2017 08:16 PM
C-Hamm
Sep 28, 2015 10:31 PM
Michelle2006
Sep 19, 2015 06:09 AM
99BoostedSi
Sep 7, 2015 04:49 PM
