Increased gas mileage
Old Sep 29, 2004
Farage's Avatar
I like you! do you like me?
i have a 2k3 ex coupe with 20,000 miles. over the past 2-3 weeks i have been experiencing an amazing increase in gas mileage. before this, i used to fill up a full tank of 93 gas every friday night and by sunday, half would be gone so i would put another 10 bucks in on tues or weds. recently, i put in DIY ram air intake with a k&n drop in filter and started filling up on 87 gas for the first time in my car's life. now, the gas needle does not move! the full tank lasts me over a week with a day or so left! wtf is going on? i am driving the same amount and i drive very very hard. what can be the reason for this awesome increase in mpg?
Old Sep 29, 2004
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
87 is easier to burn than 93 ...
Old Sep 29, 2004
518's Avatar
518
518 is on a distinguished road
Im sorry, but measuring the gas mileage by the day (full tank lasts me over a week with a day or so left) is not the proper way of doing it. Try again.
I thought someone has posted the proper way of getting the mpg?
Old Sep 29, 2004
2K1Civic17"Gabe's Avatar
It has been posted. Could be that you are using the right gas now. You shouldnt have been using 93. I used to use 89/93, but I use 87 now, and 89 once and a while. I notice that the higher octance goes faster on my car too, so I dont waste my money, cuz its not doing any good anyways
Old Sep 29, 2004
Silversleeper's Avatar
Silversleeper is an unknown quantity at this point
Actually, contrary to what you may have heard, I believe that the higher the octane, the easier it is to burn. Simply because it is a purer gasoline, therefore sparks quicker and burns more completely than a lower octane count gasoline. This is the way I was explained it. Can someone clarify?
Old Sep 29, 2004
SOHC's Avatar
I spent 1425 points to do this.
SOHC is an unknown quantity at this point
mines been going up too.. i think its because of the cooler weather, no AC!!
Old Sep 29, 2004
mexinaction's Avatar
i use 87 and i get great mileage compared to 93
silversleeper i agree what you say, dats what i have been told also
Old Sep 29, 2004
Only use the specified Octane for your cars, or youll get screwed, and there is NO extra benefit to higher octance regardless of what you have been told.
Old Sep 29, 2004
4drcivic2k1's Avatar
Turbos, Engines, Chassis and Suspension Tech
4drcivic2k1 is an unknown quantity at this point
Higher octane is harder to burn. The volatility of it is lower to prevent detonation and preignition. The lower the octane the easier it is to burn. Regarding the extra benifit of higher octane, you are partially correct in the fact that a stock motor will not compensate with advanced timing and leaner mixtures to make use of it. A race engine with 100 octane vs 118 octane will generally allow you to make more power because you can advance the timing and run leaner.
Old Sep 29, 2004
ramboa's Avatar
ramboa is an unknown quantity at this point
4drcivic2k1 is perfectly right, the higher octane is the gas, the harder it is to burn. This is the reason why high octane gas are used on most "sport" car and turbocharged ones since those car have "high compression" engine. This extra pressure inside the detonation chamber helps the high octane gas burn faster and a lot easier...Our civic being with very low compression rate engine, most of the gas is left un-burned thus poor gas milage.
Old Sep 29, 2004
Yeah, I meant it wont do much on a stock engine.
Old Sep 29, 2004
ACURAwerx's Avatar
ACURAwerx is on a distinguished road
higher octane is harder to combust, that is why high performance cars use them and not economy cars, i dont understand why people put premium in a non fi civic... it probably does more harm then good
Old Sep 29, 2004
hustlelikem0fo's Avatar
thats right.
now if you want to get even better gas milege start putting NAWZ in your gas tank..... that stuff will burn so easily you'll get like 800 miles out of a tank of NAWZ
Old Sep 29, 2004
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
Originally Posted by HustleLikeM0FO
thats right.
yup... with just a little NaWz, your sohc vtec engine will grow an extra cam and become dohc too
Old Sep 29, 2004
I always hear about putting NAWZ in the gas tank, wouldnt nitrous in the gas tank cause a lot more probs than just injecting it when you need it?? Like running only one tank with nitrous wouldnt seem too safe?? Anybody know the answer to this
Old Sep 29, 2004
Nitrous doesn't burn. NOS the company makes a fuel additive "octane booster." Ramboa has the right idea with where he was going, but technically our engines are not "very low compression." They are on the high side of factory cars, with almost 10:1 compression. The combustion chamber (not detonation chamber) is subject to higher pressures under boost which can cause a lower octane to ignite at random. The higher octane prevents this ignition.
Old Sep 29, 2004
Nobody knows the answer to this? C'mon people, I cant find anything on the internet
Old Sep 29, 2004
No, it will not work, because:
1. Nitrous oxide is NOT flammable.
2. At room temperature, Nitrous oxide is a GAS, not a liquid.
3. The only reason Nitrous oxide is a liquid inside the bottle is because of the extremely high pressures that exist inside of it.
Old Sep 29, 2004
Thank you
Old Sep 29, 2004
sevenplaces's Avatar
I want a TSX!
sevenplaces is on a distinguished road
cmon, not that hard to figure out.....
total miles traveled since last fill up / # of gallons filled up just now
not hard.....
Old Sep 29, 2004
CivicRocker02's Avatar
I usually put a cucumber in my bum when I jerk off!
CivicRocker02 is an unknown quantity at this point
^^^^ times 2
Old Sep 29, 2004
acurastype01's Avatar
w00t
acurastype01 is an unknown quantity at this point
^^^true
Old Sep 29, 2004
chocobo15_2000's Avatar
§C§H§O§C§O§B§O
chocobo15_2000 is an unknown quantity at this point
i dun think its about being easier or harder to burn... the lower the octane, the less pure the gasoline. Pure gasoline burns much faster than unpure gasoline so that's why filling up on 87 octane gives ur car more mileage, but it doesn't burn as clean as the other.
oh, and don't waste ur money on 93 octane fuel... change ur oil, and get regular maintainence, and ur car should be fine
Old Sep 29, 2004
Wrong. An 87 is just as "Pure" as a 93 octane. The amount of contaminants has relatively little to do with how fast it burns.
Old Sep 30, 2004
SMX's Avatar
SMX
SMX is on a distinguished road
93, 91, 89 and 87 are made from the same base gas stock at most refineries. The only difference is the octane boosters and additives commonly used in the higher octane fuels. Higher octane fuel does not auto-ignite as easily (detonation) and allows higher compression and more timing. That's why it's used in high performance cars. Race cars running 13:1 (like my 440 Challenger) use race gas that has even higher octane...
Feel free to add it to your Honda, all it hurts is your wallet, and your reputation if anyone with half a brain sees you putting it into your car.
Old Sep 30, 2004
lilravingmatt's Avatar
lilravingmatt has a little shameless behaviour in the past
o.0 well my dad says to use the middle type of gas umm i think its 92 ... cuz the car is new... and you want 2 burn gas more clean...less lead i think...so the engine stays more clean... so the car last longer... now after i read i think i want 2 go to 87 lol
Old Sep 30, 2004
Only reason I run 89 instead of 87 is my slightly higher compression engine. For stock, 87 is just fine and is what the car was designed for. In some cases, higher octane gas has caused more damage to the engine because of deposits or something. Every gas is unleaded now.
Old Sep 30, 2004
All modern automobile fuels are lead-free with the exception of certain race gas. Leaded gas is exceptionally hard on emissions parts, and for that reason, is no longer sold to the general public.
Old Sep 30, 2004
SMX's Avatar
SMX
Running 93 won't hurt your engine, but it will hurt your pocket book.
In hot weather when I'm towing race cars with my truck, I will use mid grade instead of regular because the added load and higher temps can increase detonation potential. But that's the only time I don't run regular.
Old Sep 30, 2004
xxnoshelterxx's Avatar
xxnoshelterxx is an unknown quantity at this point
you all say that all octane levels are the same purity, but 93 sure tastes better to me.
