Installed my e-Manage today and...
Wow.
For cheaper than a VAFC it's wayyyy better.
The ignition timing is good to have, plus the fuel management is a lot more precise. At first it was kind of scary, but youll like it
The install was pretty tough, wiring a whole bunch of ECU wires in a VERY tight spot was pretty scary but it all worked out.
I wired the ignition and injector harness set it to 4-8-C and the car runs perfect. I didn't wire the VTEC, but it still runs like a champ.
Perfect idle, runs great under load, no check engine lights...
the only problem I had was taht the e-Manage threw the VTEC input error code(Cause VTEC wasn't hooked up), anyone know how I can bypass that?
Aside from that everything worked out great, special thanks to Opto, Dezod, and C20, and a few others!
.The install was pretty tough, wiring a whole bunch of ECU wires in a VERY tight spot was pretty scary but it all worked out.
have pics of the wiring? and how long did it take you to do it? Soldered it and then wraped with elec. tape? i might be getting it.....actually I need to get it. That and possibly a new Vortec FMU/Inline pump.....grrr.....
7thgen Power Maker
http://www.7thgencivic.com/forums/sh...13#post2292413
yeah Dezod..I'm not sure if my pump is working properly.....gotta run some checks with pressure gauge, wideband to see if i'm running to lean or rich. Then it's time for emanage on top of the vortec fmu and inline pump.
7thgen Power Maker
so emanage basically hooks up to a computer? how much?? who sells it cheapest?? . is it something good to have when u dyno tune?? also can i use it the same time as my vafc2??? if not what if i just use the vafc2 to control vtec and the emanage for everything else
7thgen Power Maker
Yes it's a piggyback fuel unit that is much more powerful than the V-AFC2.
BTW is your sig intended toward me?
"Turbo (If someone would
work on me with this)"
Originally Posted by dezod
Save your $$ now. If you getting our kit, it's included.
haha... no... it wasnt intended for you... the intention of "work on me with this" has 2 meanings but i coudnt fit it all.... first meaning is financialy and willingness to buy.. second is i aint no genious.. especially with the 7th gens.. i have had a boosted 98 before and that was a pain in the butt but it seems like that was nothing compared to what the 7th gens have to go through to gt boosted.. seems like a nightmare
oh yea.. i forgot.. i dont know if you remember or not but i did a head swap to add vtec to my dx engine..which means that i needed the vafc2 to supply the vtec signal to the head since i didnt do an ecu swap and that stuff.. with that in mind does that mean i can still use the vafc2 to control the vtec and still run the emanage OR can the emanage run the signal to my head as well?
7thgen Power Maker
7thgen Power Maker
No one has really gotten it to work on the 7thgen.....
C2i0v0i1C does
But his shop won't tell how.......they say it is in the manual
btw........congrats on the install
u have stock injectors ?
I ordered my emanage from www.streetlevelperformance.com and later on will order the support tool along with ignition harness and in the mean time i am looking for some type s injectors.
Originally Posted by civic01vtec
C2i0v0i1C does
Originally Posted by C2i0v0i1C
and that pisses me off too!.....MF wont tell me either, its my damn car
lol. why wont they tell?
See here:
http://www.7thgencivic.com/forums/sh...8&postcount=76
to try it - don't know if it will work or not....
To get rid of the VTEC error... Go to your parameter setttings. Make sure the VTEC box is unchecked. After you unchecked it, click confirm. Then click export.
Originally Posted by Hwoody77
Wow.
Wild Cranker
May 19, 2015 06:10 PM
toastyghosty
32
Dec 26, 2001 02:03 AM
