Iridium spark plugs....messing up my engine?
Old Aug 20, 2004
Metallica454's Avatar
The Beer-man
Metallica454 is an unknown quantity at this point
Ever since I installed Denso Iridium spark plugs on my Civic (03 EX/28,000 miles), It has been a little tougher to start (it turns over longer before it starts up), and I swear my power band is all F-ed up. In 2nd gear mainly, as I accelerate I feel a lot of valleys in the powerband that were not there before. It's almost as if I'm letting of the gas a little as I accelerate, but I'm not. I'm going to put my old ones back in and see if it helps.
Old Aug 20, 2004
dragoon's Avatar
check if the densos are gapped properly?
Old Aug 20, 2004
streetglower's Avatar
check if you also torqued them properly.
Old Aug 20, 2004
Yup, both of the above. You have to use a torque wrench. I like my iridiums, but they're NGK and make the engine run way better. And yes, I've measured the voltage of regular to iridum, and the iridiums use alot less power. But if the densos are messing up, try putting back the stock double platinums.
Old Aug 21, 2004
The Beer-man
They came pre-gapped for the 1.7L VTEC and I torqued them to 17ft-lbs when I first installed them which I believe is the correct torque. If not, please tell me.
Old Aug 21, 2004
you over torqued them, should of been 13 ft.-lbs.
Old Aug 21, 2004
jahernandez's Avatar
jahernandez is an unknown quantity at this point
I have heard a lot better things about the NGK iridiums...I have them in my Nissan Altima and they work wonderfully...
Old Aug 21, 2004
Yup. Alot of honda mechanics also tell me NGK is the best brand for our civics.
Old Aug 21, 2004
MIT's Avatar
MIT
MIT is an unknown quantity at this point
yeh. u over torque them, should be 13 ft-lbs only.....
Old Aug 21, 2004
yup I have Iridiums on my car and they work great.
Old Aug 22, 2004
tacheon's Avatar
tacheon is on a distinguished road
Over/Under torquing by a couple foot pounds does not affect performance of the vehicle in any way. You won't feel any difference in engine performance either way. The only reason a torque is specified is to prevent stripping of the threads in the aluminum head. Most mechanics don't install sparkplugs using a torque wrench.
Old Aug 22, 2004
True true...I do it by the feel...sounds kind of erotic...
Old Aug 23, 2004
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
I had the same problem with denso iridiums ... however, I never torqued them properly (lack of torque wrench) ...
but maybe I'll go with ngk's soon ... I'm not a big fan of denso's needle-tip spark plug
thana
Jun 15, 2020 07:05 PM
JohnnyBxo
16
May 9, 2015 05:53 PM
Blaster30
Apr 22, 2015 12:21 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
3rdcivic
Oct 21, 2001 01:26 PM
