suggestion for a good AMP kit?
Old Aug 7, 2004
zen_master's Avatar
hi guys!
can you suggest me a good amp kit for my new system?
it's Solid Audio 1200watt MAX 2 CH amp.....600RMS at stable 2 ohm..
my car is 02 Civic COUPE..
how many ft and gauge of power wire do i need?
how many ft and gauge of ground wire do i need?
i do also has the 1farad cap along with the system....
any good kit from ebay? monster cable kit?
thanx!
Old Aug 7, 2004
MegaHurtz's Avatar
I suggest saving yourself some money and buying everything seperately.
You need:
20-25 ft of 4 gauge wire (power)
10 feet of 4 gauge wire (ground) Can be same color as power or different, your choice
Assorted 4 awg ring connectors (you will also need a large crimping tool to do the 4 awg wires which is a good idea to buy)
3 large 4 gauge connectors with set screws for your cap (2 power 1 ground)
1 ANL fuse holder OR 1 circuit breaker (up to you to decide on amperage. I recommend 80 amp circuit breaker)
20-25 feet of 16-18 gauge blue wire (remote)
1 ~20ft RCA
10-15 feet or so of 12 gauge speaker wire
Electrical tape (red and black, use red to tape power connections, black for ground)
That should cover it I believe, I am sure somebody will call me out if I miss something.
Just run your power wire thru your firewall, under your door sill, under your body panels and into your trunk. Connect the end of the power wire to one of the large 4 gauge connectors and put that to your cap +. Use another short length of 4 gauge and set screw connector from cap + to amp +. Use the third set screw connector for your cap -. GROUND BOTH YOUR AMP AND CAP TO THE SAME SPOT. Failure to do so will cause ground loop.
That's all I can think of for now, but you can always post questions here as they arise
Old Aug 8, 2004
zen_master's Avatar
thanx man!!
wow, you need 20ft power cable??
Old Aug 8, 2004
MegaHurtz's Avatar
It would be to your advantage to buy as much as possible, that way you have a bit of slack.
20 feet isn't bad, personally I would get 25 and just cut it off if I had to, that way you have as much slack as you want
Old Aug 8, 2004
zen_master's Avatar
hm.....
i bought monster kit though....
it has 18ft 4 gauge power cable.....i hope it fits. =)
Old Aug 8, 2004
MegaHurtz's Avatar
It should but it might be tight
Old Aug 8, 2004
zen_master's Avatar
the problem is the ground cable,
i only have 3 ft of em....
probably fit the amp..i wonder whether it fits the cap....
Old Aug 8, 2004
MegaHurtz's Avatar
You'll probably need to go out and buy another 3 feet
Old Aug 8, 2004
Civic_Racer9's Avatar
(SnOwBoArDeR | FoReVeR)
knukonceptz.com
buy that kit!!! quality ****!!!
Old Aug 8, 2004
Regularjoe's Avatar
Regularjoe is on a distinguished road
Walmart actually carries nice kits made by Scosche. They have everything you need and are all under $20. IMO you can't beat it.
Old Aug 8, 2004
zen_master's Avatar
thanx again for the informations!
wal-mart cables? hmmm....letsee...i saw those cables too in walmart..
Old Aug 8, 2004
MegaHurtz's Avatar
Yeah Walmart wiring kits are okay... that's about the extent of their quality gear when it comes to car audio
Old Aug 8, 2004
zen_master's Avatar
lol...
that's what im concerned about...........
anyway, i got monster cable, whaddya guys think? the 500W kit..
Old Aug 8, 2004
MegaHurtz's Avatar
What gauge is the wire?
Old Aug 8, 2004
zen_master's Avatar
it's a 4 gauge power....
4 gauge ground....
http://cgi.ebay.com/ebaymotors/ws/eB...spagename=WDVW
Old Aug 8, 2004
MegaHurtz's Avatar
That's good enough, that's what you'll need
What type of fuse holder did they give you with the kit?
Old Aug 8, 2004
PopcornPlaya's Avatar
Electric Boogaloo...
Umm... wire is wire.
Old Aug 8, 2004
MegaHurtz's Avatar
Not when it comes to size
And there are variations, some wire is better suited to some applications than others...
Old Aug 8, 2004
Like I said, wire is wire. The only thing that really matters is the RCA's. The different sizes for different currents in power, ground, and remote wire are really the only consequental things that matter. Brand name doesn't mean jack shjt. It's still gonna carry the current the same, assuming that it is free of nicks, and breakages in the wire, etc.
Old Aug 8, 2004
zen_master's Avatar
actually, i think, what matters is the way it insulates the current......
poor quality wires probably won't insulates better compared to the good one...
Old Aug 9, 2004
Regularjoe's Avatar
Unless the wire shorts out .... its grounded just fine .....
Old Aug 9, 2004
zen_master's Avatar
can i actually use the audio grouding wire to replace my stock groundin system?
Old Aug 9, 2004
MegaHurtz's Avatar
If you wanted to...
Old Aug 9, 2004
zen_master's Avatar
maybe i can use the leftover.............LOL
civic1316
May 29, 2015 05:13 PM
autowill
May 15, 2015 11:36 AM
superstanko
Apr 28, 2015 04:38 AM
GaryFishell
Apr 24, 2015 06:49 PM
