DIY: Apex'i V-AFC Install Instructions
Old Nov 23, 2001
Jimmy24's Avatar
Jimmy24 is an unknown quantity at this point
APEX V-AFC VTEC CONTROLER
[IMG]i/expressions/face-icon-small-confused.gif[/IMG]
Does anybody knows the color coding of the ECU to hook up the v-afc, looks like nobody has tried this thing!
Please help!!!!!
Old Nov 23, 2001
WhosYoDadday85's Avatar
www.ImportFactor.Com
WhosYoDadday85 should not be trustedWhosYoDadday85 should not be trusted
You talking about this thing?
Old Nov 23, 2001
NeoMagus's Avatar
NeoMagus is an unknown quantity at this point
that looks like what the mans talkin bout
Old Nov 23, 2001
Booohahaha's Avatar
BAD MON
can i ask u a question? hope u can answer it
how low can u lower ur vtec???
and have u noticed any difference in power ???
thanks for the info!
Old Nov 23, 2001
Direct all your questions to "Boosted" [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old Nov 23, 2001
black2k1vtec's Avatar
black2k1vtec is an unknown quantity at this point
<< can i ask u a question? hope u can answer it
I think any lower than 3000 is bad, on my friends 97 SI he gained about .4 in the 1/4 mile!!! Thats with some guy who totaly knew how to tune the D16Y motor. I want one for my 2k1 soon.
Old Nov 26, 2001
Jimmy24's Avatar
Man! I've been trying to find somebody or a diagram or something just to find out what cables or how to hook it up, everybody says that because it's a new design, there is no way to hook it up, unless you have a diagram to find out which cable is which. It could be bad to hook up the wrong cable. By the way, do you feel the difference? Thanks man!
Old Nov 26, 2001
mattskav's Avatar
mattskav is an unknown quantity at this point
Well if you understand how the controller works (i.e. what wires have to hook up to what inputs and outputs) then I would suggest you get a copy of the honda factory service manual (your dealer can provide you with the form) and use the wiring diagrams in there to hook it up ja?
Old Nov 26, 2001
Jimmy24's Avatar
I'll do that, thanks!
Old Nov 26, 2001
mattskav's Avatar
the difference from stock isn't that extreme, i was in a 99 prelude that my cousin had just installed (he owns altered atmophere) and all the gains were caused by droping the vtec kick in point. you dont get an increase in max power but you gain *a lot* of additional power from say 3500 to the point of stock activation and thus the car is MUCH quicker because the higher power lasts longer. If you raise the limit way up it is cool as hell when it kicks in, feels like you just hit the NOS [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
good luck, and if you get it to work let me know, i was going to try it myself around x-mas when i can get down to his shop.
Old Nov 26, 2001
01rallyeredex's Avatar
01rallyeredex is an unknown quantity at this point
So the VAFC will work for our cars, since we have The New I-Vtec? And it really works? And i know that with the new Vtec that it kicks in at like 4200 would it even be worth spending the 400 dollars for one?
Old Nov 27, 2001
Jimmy24's Avatar
Still looking for that diagram in order to hook it up. As soon as I find it, I'll let you know!
Old Nov 27, 2001
Boosted's Avatar
Boosted is an unknown quantity at this point
I have the diagram here you go: Plus I have the Factory electrical manual on our cars
all but one of these wires can be located under the capret on the passenger side The map sensor wire.
connect these two in this order:
brown wire (ground connects to the black wire going to the ECU)
black wire (ground connects about 4 inches behind the brown wire, make sure that the brown wire is closer to the ecu than the black)
gray wire (connects to the red w/black stripe, this may also be found under the hood off of the TP Sensor) Thottle Sensor
green wire (connects to the baby blue wire at ECU) RPM Signal Wire
This is where it gets tricky. Pull 2 wires through the fire wall to the map sensor. connect one to the white wire of the V-AFC and the other to the yellow wire. DO NOT GET THESE WIRES MIXED UP.. Unsheath the harness and cut the green w/red stripe wire. This is the wire that sends the signal to the ECU. Remember to leave enough wire to butt connect to. With this in mind. Here we go....
white wire (connects the green w red stripe wire (that you cut) that goes into the map sensor itself.)
yellow wire (connects to the green w/ red stripe wire (that you cut) that goes back to the ECU)
The reason for pulling the wire is this. There are 5 green w/ red stipe wires that come through the firewall and you do not need to cut the wrong one.
Next is the VTEC wires:
Here we go again. This time pull 2 more wires (one connected to the purple wire and one connected to the pink wire of the V-AFC)through the firewall to right under the air box and the resonating box. It has a gray connector with a single blue wire coming out of it. This is where the VTEC solenoid valve is.... Once again cut the blue wire remember to leave enough to but connect to....
pink wire (connects to the blue wire (that you cut) that goes to the VTEC solenoid valve)
purple wire (connects to the blue wire (that you cut) that goes from the VTEC solenoid valve to the ECU)
Now to power it:
red wire (connets to the yellow w/ black stripe wire that goes into the ECU)
orange wire (connects to the yellow w/ black stripe wire (behind the red wire that is closer to the ECU than this one) that goes to the ECU)
Here is the 2nd option to the power. Remember that your car will not run unless the V-AFC is on. So either you can hook up the power wire as above, or you can hook both wires up to a switch that is hot at all times (this is how I have mine, since I have push button ignition in my car).
I hope that this helps!!! If you need more info please
EMAIL ME...
Old Nov 27, 2001
It says you have the Super AFC in your sig?? Is it the same as the V-AFC??? I thought it was different. Nice DIY, where did you get the electrical manual from?? Helms manual?? Thanks.
Old Nov 27, 2001
Hobby2K's Avatar
Hobby2K is an unknown quantity at this point
I know this is an awful question to ask but how does an apex v-afc work and what are the benefits of getting one.
Old Nov 28, 2001
Boosted's Avatar
I do have a S-AFC, but I also have the wiring diag. for a V-AFC.... The electrical diagrams are complients of Helms =)
It is the same that the Honda Dealerships around here use....
V-AFC has 2 functions:
      Old Nov 28, 2001
      Jimmy24's Avatar
      BOOSTED IS THE MAN!!!!!![IMG]i/expressions/beer_yum.gif[/IMG]
      Old Nov 28, 2001
      lestat's Avatar
      lestat is an unknown quantity at this point
      question, i know lx is diff on ex but is there any vtec controller we could put in our lx ... ??
      i know it sounds newb, but we want some vtec sedans [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
      Old Nov 28, 2001
      Boosted's Avatar
      You can't put a VTEC Controller on our cars but there is a substitute.
      Apex i Super-AFC. We do not a VTEC Motor but with the S-AFC we can adjust our
      fuel maps on a hi and low thottle scale... You can also set where you want to difference between
      hi and low thottle settings.
      I have noticed slight increases on my LX.. I think that is works the best when you are pumping NOS through a Venom Kit.
      Old Nov 28, 2001
      trevor's Avatar
      trevor is an unknown quantity at this point
      HEY BOOSTED,,,,,,,,,kind of an off topic question,,,, but what shot nitriuos are you shooting (ususaly)
      and how often????????????????????
      50 shot 2wice a day???? gimme an example........thanks
      [IMG]i/expressions/face-icon-small-wink.gif[/IMG][IMG]i/expressions/face-icon-small-wink.gif[/IMG][IMG]i/expressions/face-icon-small-wink.gif[/IMG][IMG]i/expressions/face-icon-small-wink.gif[/IMG][IMG]i/expressions/face-icon-small-wink.gif[/IMG][IMG]i/expressions/face-icon-small-wink.gif[/IMG][IMG]i/expressions/face-icon-small-wink.gif[/IMG][IMG]i/expressions/face-icon-small-wink.gif[/IMG][IMG]i/expressions/face-icon-small-wink.gif[/IMG][IMG]i/expressions/face-icon-small-wink.gif[/IMG][IMG]i/expressions/face-icon-small-wink.gif[/IMG][IMG]i/expressions/face-icon-small-wink.gif[/IMG][IMG]i/expressions/face-icon-small-wink.gif[/IMG][IMG]i/expressions/face-icon-small-wink.gif[/IMG][IMG]i/expressions/face-icon-small-wink.gif[/IMG][IMG]i/expressions/face-icon-small-wink.gif[/IMG][IMG]i/expressions/face-icon-small-wink.gif[/IMG][IMG]i/expressions/face-icon-small-wink.gif[/IMG][IMG]i/expressions/face-icon-small-wink.gif[/IMG]
      (just wonderin cause im lookin to buy, and wonderin how much i should use it)
      Old Nov 29, 2001
      Jimmy24's Avatar
      Hey boosted, I follow everything you said, about the installation, and I got it on, and the pressure, throttle possition are working but no rpm signal and of course, vtec not working because it works with rpm's. I think you said, the green wire of the vafc was supposed to be connected to the baby blue one, I wonder if you are getting the cables from the ecu or underneath the carpet, because in the ecu there is a baby blue wire a kind of blue-green wire (very similar to the baby blue one) and the same blue-green with a red line. I hooked it up to the baby blue one but no rpm signal no were, so whe I pass 4000 rpm's check engine light comes on and It wouldn't pass 4000 rpms, what I did was that I left the rpm cable (green) disconnected and I hooked the vtec wire as it was, everything is normal but I can only see the pressure and the throttle settings. What do you think,!!!!!
      Old Nov 29, 2001
      Boosted's Avatar
      Here goes. I have took my digital camera and took pics out of the Honda book so that you can see exactly the (3) different locations of the Tach Wire AKA TDC Sensor.....
      Since the pics are so big, I am just going to link them....
      Diagram 1
      Diagram 2
      Diagram 3
      Diagram 4
      Diagram 5
      Diagram 6
      Diagram 7
      Diagram 8
      Diagram 9
      I hope that this will help some.... Thanks and let me know if there is anything else that I can do...
      Old Nov 29, 2001
      mattskav's Avatar
      how much was that book?
      Old Nov 29, 2001
      Boosted's Avatar
      I gave $150 for the electical troubleshooting and the service manual.
      Old Nov 29, 2001
      trevor's Avatar
      thx[IMG]i/expressions/face-icon-small-sad.gif[/IMG]
      Old Nov 30, 2001
      Jimmy24's Avatar
      [IMG]i/expressions/beer_yum.gif[/IMG][IMG]i/expressions/beer_yum.gif[/IMG]Again, Boosted is the man!!!!!!!!
      Thanks, my VAFC is up and running
      Old Nov 30, 2001
      mattskav's Avatar
      jiimy, did you wire it up w/ boosteds instructions just fine, or is there anything you can add?
      also how does it feel? good? did you turn it way up to like 5500 yet [IMG]i/expressions/face-icon-small-smile.gif[/IMG][IMG]i/expressions/face-icon-small-smile.gif[/IMG][IMG]i/expressions/face-icon-small-smile.gif[/IMG]
      Old Nov 30, 2001
      Jimmy24's Avatar
      I hooked it up with boosted intructions, the hardest part was to find the RPM signal wire, but he send a couple of pictures, there's one of them that I used, (the one showing where the tach test point was), what I did was, I used a multimeter to check continuity in that test point and inside the car, by the ECU, also I never ran wires through the firewall, he just gave me that idea and I used the multimeter to find the map and VTEC sensor wires in the sensors itself, checked continuity inside for each cable. But you can use Boosted intructions and you will get it right for sure, he's got the diagram. My is running fine, you can adjust VTEC and fuel but the system is very complex, I am taking my car to a shop to get it tunned and so they show me how to use this thing wright. As soon as I get it tunned, I'll let you all know for sure. hope I answer your question!
      Old Nov 30, 2001
      lestat's Avatar
      Where do u buy this afc stuff? send us the link guys [IMG]i/expressions/face-icon-small-smile.gif[/IMG] sounds like its a bit complicated DIY ... but err... i'll have to see the part ... and see where it really fits in [IMG]i/expressions/face-icon-small-confused.gif[/IMG]
      Old Dec 3, 2001
      Jimmy24's Avatar
      Hey does anybody knows what is this thing for: "Blitz Power Meter i-D "[IMG]i/expressions/face-icon-small-confused.gif[/IMG]
