tinting
Old Aug 3, 2004
civictuner's Avatar
civictuner should not be trustedcivictuner should not be trustedcivictuner should not be trustedcivictuner should not be trustedcivictuner should not be trustedcivictuner should not be trusted
tinting
step 1- clean windows (at least 2 times)
step 2- get tint and place it on the outside first and cut out the pattern (at least 1 inch bigger than window) oh yeah wet the window first with a car soap and water (1 part soap 5 parts water in to a sprayer)
step 3-peel off the protective sheet and place it on the inner wet side of winow
step4- squegge all the bubbles and air from the top to bottom be sure to use some of that soap as lubricant so you dont scratch up everything.
step 5- razor off excess and keep squggeing
step 6- with a heat gun (or for you people that are married you can also use your wives hairdryer set to max heat and medium wind) and squeege with LUBRICANT__SOAP MIXURE to remove and more water and air bubbles and to let the tint adhesive tack on better
step 7- nice yeah
Old Aug 3, 2004
Mr.Modify's Avatar
so your selling instructions?
you just Pwned yourself cause you already gave them out..................BAHAHAHAHHA
NOooooooob wrong Forum....hahahaha....if you were writing a DIY it's good to know ...(i guess)
Old Aug 3, 2004
WhiteCastle's Avatar
step-8 Having to get them redone professionally after the cheap one peals
step-9 WC luaghs that you had to do that.
Old Aug 3, 2004
JX6's Avatar
JX6
Redline Adrenaline VP
JX6 has a spectacular aura aboutJX6 has a spectacular aura about
It's a new member.
What else should we expect.
Old Aug 3, 2004
drumnbassics's Avatar
JDM $lut
drumnbassics is an unknown quantity at this point
c'mon now...easy on the noob hehe
Old Aug 4, 2004
FALKEN's Avatar
Civicforums Junkie
GolNat
Nov 27, 2018 03:32 PM
Mad Dog Tannen
Oct 19, 2016 08:12 PM
UltraHDGames
Jun 8, 2016 05:16 PM
wingsfan19
Oct 1, 2015 03:45 AM
eebing
Sep 12, 2015 05:35 AM
