what yall think bout this setup?
Old Jul 18, 2004
nolimitrican's Avatar
nolimitrican is an unknown quantity at this point
Im thinking of getting 3 10" comp vr kickers with a 600.1 amp running these subs, i just wanna know if this is a good setup n or what will yall recommend, thx for yall time...
Old Jul 18, 2004
Mystic3030's Avatar
Yup, i'm an A$$hole.
You need double the power if you want to run 3 of them. If you get 2 ohm subs you can run either 1.34 or a 3 ohm load. If you run at 1.34 you need a 1 ohm stable amp that will push 1000 watts at 1ohm. If you run at 3 you need one around 1200 watts at 2 ohm because when you run it at 3 it's gonna put out slightly less. If you go with 4 ohm models you can run at 2.67 ohm. Again you will be around 3 ohm so you need to get something around 1200 watts.
For me, that would be a terrible setup, but for you, it may be great. Thats kind of a baited question that no one but you can answer. Go to a store and listen to the subs to see if you like them.
If you want some suggestions we need to know this:
1. What is your budget?
2. Are you buying online?
3. What kind of music do you listen to?
4. Do you already have a box? Wires? HU?
5. Is space a concern? (i'm assuming no, since you want 3 subs)
6. Are you DIY on the install or paying to have someone else do it?
7. If you need a box, are you building it or buying it, and does the budget provided include the box and wiring, or is it just for your subs and amp?
Old Jul 18, 2004
MegaHurtz's Avatar
If the amp is 1 ohm stable it will be fine, you will be able to parallel wire it down to 1.33 ohm
Old Jul 18, 2004
MegaHurtz's Avatar
Also, what Mystic said
Old Jul 18, 2004
Mystic3030's Avatar
Even if the 600.1 is 1 ohm stable, it's still not enough power
Old Jul 18, 2004
MegaHurtz's Avatar
Haha, I know I was actually post whoring becuase Iwanted to get a screenshot where the most recent post on every thread was me
I got the shot
Old Jul 19, 2004
[B]im just asking cause my boy got that setup in his expedition n it sounds pretty hard, but i really wanted to get 2 12's kickers solos l7 n run it with a 800.2 kicker amp..
