HELP! i cut up the stock tweeter pod but still cant get my type r tweeters to fit
Old Jul 13, 2004
turboslug's Avatar
Super Hoser
turboslug will become famous soon enoughturboslug will become famous soon enough
ok, i cut up the insides of my tweeter pod but the type r tweeter still wouldnt fint
only way i think it'll go in is if i remove the part with the metal clip but if i cut it off, what will hold the pod to the door?
anyone want to trade tweeters with me? i have a brand new set of alpine type r tweeters with the mounting kit..hehe...some mb quart or infinity tweeters would be great..
Old Jul 13, 2004
renone's Avatar
renone is an unknown quantity at this point
get these
Old Jul 13, 2004
turboslug's Avatar
Super Hoser
yeah but i already bought components...
if i switch, it'll probably have to be a trade for kappa series tweets or mb quart tweeters
Old Jul 13, 2004
irishtemper's Avatar
irishtemper has a spectacular aura aboutirishtemper has a spectacular aura about
you can buy the tweeter pods from honda, i thinks they are $10 each.
Old Jul 13, 2004
turboslug's Avatar
Super Hoser
i already bought and extra pair of stock pods even though my car already has them...
anyways, i cut one up and the type r tweeter still doesnt fit....it seems that the tweeter is about 1mm too wide so it wont go into the hole from the front. there's also no way i can get it to go in from the back either
Old Jul 13, 2004
Build a bracket and mount the tweeter on the mid range you get better imaging that way anyway. having the distance will be out of phase and will throw off your "stereo triangle", having the tweeter close to the mid will make it alot better but in order to have a true stereo triangle you would have to add a center channel. The distance from the drivers seat to the passengers speakers is alot longer than from the piller on the drivers side and IMO is too close to you and would be off axis. Do the above, it will be alot better.
Old Jul 13, 2004
MegaHurtz's Avatar
Buy the regular non-tweeter sail panels and mound the tweeters to the outside. I am guessing they came with cups that attach to the back?
Old Jul 13, 2004
PopcornPlaya's Avatar
Electric Boogaloo...
Just get the non-ex sail panels. Slap them on there, and flush mount them in the doors. As irish said, it'd sound better if you kept them within 12 inches of the mid, but hey, if you really want them there, just get some sand paper, or grinder, or something and grind off the excess. Once you do that, use the flush mount pods with them. (Make sure you grind enough for the pods and all, not justthe tweet, unless you want them fixed, so you can't swivel them to your liking/music taste.
Old Jul 13, 2004
MegaHurtz's Avatar
Does swivelling really make that much of a difference?
Old Jul 13, 2004
somewhat, it throws off the angle and makes it seem futher away to try and equal the distance from both sides. if you were to say mount the pass. side in the doors, mid and tweet together and put the drivers side in the kick panel it would be a big difference than mounting the drivers side in the door.
Old Jul 13, 2004
turboslug's Avatar
Super Hoser
i dont like how those would look...someone posted pics of infinity tweets mounted that way
Old Jul 13, 2004
MegaHurtz's Avatar
Righty-o, makes sense.
Personally, I don't like my speakers to be within a direct earshot. I like them to be facing away from me or just not firing directly at me because I don't like to hear where the speakers themselves I only like to hear the sound... if you know what I mean
Old Jul 13, 2004
turboslug's Avatar
Super Hoser
anyways, i shaved off a tiny bit more of the pod and sanded the tweeter down about 0.5mm...
i'm was able to force the tweeter into the pod...still isnt perfect but decent... the trick was to angle the tweeter then shove it into the pod from the front..hehe...
Old Jul 13, 2004
turboslug's Avatar
Super Hoser
PICS!!!...damn, someone should write a diy on how to get those tweeters in there...it takes a lot of custom work to fit them into those pods
Old Jul 13, 2004
renone's Avatar
mine are in a 03 si and they are infinitis and they swivel
Old Jul 13, 2004
turboslug's Avatar
Super Hoser
nice...i guess you were able to get the mounting kit into the pods too, eh?
Old Jul 14, 2004
renone's Avatar
opps
Old Jul 14, 2004
renone's Avatar
tweets
yeah
i have had like three pairs of tweets in there
all i did was notch out the insides
dremel tool
the biggest i had in there was atomics
so i know at least in the si we have plenty of room...
Old Jul 14, 2004
turboslug's Avatar
Super Hoser
the alpine tweeters were huge...
i had to do more than just cut out the back piece...i had to use an exacto knife to shave off any excess plastic around the opening...if i didn't, there would be a large gap between the pod and the tweeter...the pod would also look bulgy...the tweeter also had to be forced into the pod...it wasnt an easy drop in...
Old Jul 14, 2004
Civic_Racer9's Avatar
(SnOwBoArDeR | FoReVeR)
how does the factory(honda) hook up the tweeters in the EX's anyways?...it is plug and play? or they hook it up with the front door speakers?
i would love to know that.
Old Jul 14, 2004
turboslug's Avatar
Super Hoser
it's hooked up in parallel with the stock speaker
the tweeter's high pass filter is just a capacitor...there's no large crossovers...
if you you buy aftermarket tweeters, you need a crossover....
Old Jul 14, 2004
thx turboslug
too much work for just tweeters...already have 8 in my car and 4 crossovers. thats good enough.
sound clean and clear yet its very bassy for just speakers
Old Jul 14, 2004
Thats exactly the way a system should be, proper placement and adjustment= not knowing where the sound is comming from, I personally like it that way, some people just want it loud, even if its distorted, yuk
GolNat
Suspension DIY
May 12, 2022 06:49 AM
shawe90
May 11, 2015 10:17 PM
ademarco6
Nov 16, 2001 10:19 PM
klam
Nov 15, 2001 05:30 PM
doublins
Nov 11, 2001 07:01 PM
