how to lower clutch engagement?
Old Jul 7, 2004
wez20011's Avatar
wez20011 is an unknown quantity at this point
can somebody teach me how to lower clutch engaement. I can lower the clutch physically but the engagement of the clutch itself is still very high.
Thanks
Old Jul 7, 2004
Zzyzx's Avatar
Autocross Junky
?? You are trying to get it lower to the floor? you should be using the minimum pedal travel possible.
Old Jul 7, 2004
Sickboy's Avatar
Sickboy will become famous soon enoughSickboy will become famous soon enough
You don't want the engagement point too high or in the future it might slip on you. Somewhere near the middle usually works best. But, I haven't tinkered with mine yet so I can't help you. Too bad it's hydraulic and not cable, those are cake.
Old Jul 7, 2004
StreetLevelPerformance's Avatar
Your Parts Guy
StreetLevelPerformance is on a distinguished road
7th gens have cable trannies.
Old Jul 7, 2004
Sickboy's Avatar
I really need to find some time to get under the hood then, I was told otherwise and my other cars have been priority.
Old Jul 7, 2004
Havok2k1's Avatar
Wicked Pissah Admin
Wez, stop double posting threads. Please use the search.
Old Jul 10, 2004
wez20011's Avatar
thanks man
okay, I want to lower it just a bit closer to the floor for better timing and better reaction speed. and better launch time...
Old Jul 10, 2004
tinman's Avatar
tinman is just really nicetinman is just really nicetinman is just really nicetinman is just really nicetinman is just really nice
Yes, but the CLUTCH is hydraulic.
Old Jul 11, 2004
CuRiOuSfIsH's Avatar
Back From The Banned!
I have an idea on how to do it on older Civics, there is a screw around where the clutch pedal and firewall meet and can be adjusted there, dont know if that works for the 7thgen
Old Jul 19, 2004
wez20011's Avatar
I tried that but It just kinda lowers the clutch physicaly. the Engagement part is still up way up...
Does honda have the capabilities to lower the clutch? even if it's hydraulic?
Thanx
Old Jul 22, 2004
wez20011's Avatar
hey is this the thing to adjust to lower clutch engagement?
ID:	33526   Click image for larger version
Name:	small large view.JPG
Old Aug 2, 2004
wez20011's Avatar
I know how to lower the clutch already inside the car the part where the clutch kinda hydraulic gold shaft thing below the car.
first you just untighten the nut then adjust it lower to lower the engagement. I had to learn this from my bro, he knows how to adjust since he drives an Si and he lowered his clutch engagement also.
Old Aug 2, 2004
bakuretsu's Avatar
bakuretsu is an unknown quantity at this point
I'm curious about this, even if it's only adjusting the physical pedal and not the actual engagment point.
*bump*
Old Aug 13, 2004
wez20011's Avatar
it's not just the physical height I'm talking bout here there are 2 adjustments that can be done right on the clutch inside the car, there is this but and bolt type of adjustment which is in front of the clutch pedal... when you see it it's also gold colored nut and bolt... this is just to adjust the physical height... don't adjust this till you've adjusted the shaft first...
the shaft is what the clutch pedal pushes... it's a gold colored metal shaft with a nut located near the pedal side and not the firewall side. untighten the nut then tighten the shaft inwards to lower the clutch engagement.
then adjust the front nut and bolt to lower the pedal physically so that there won't be that much slack when you depress the pedal.
Old Aug 13, 2004
WannaBFast's Avatar
Prowlin' with a Purpose
get a new pressure plate?
mrohitredd
40
Sep 9, 2017 12:03 PM
mjdiaz89
Jun 21, 2016 09:26 PM
OptimisticWay
46
Oct 15, 2015 02:16 PM
Kyles24
Jul 16, 2015 10:14 PM
06Si_Girl
Jul 12, 2015 12:08 PM
