FS: used hayames w/problems =|
OMNES AD UNUM
hey people,
i have a set of hayame full coilovers for sale. im having money issues as of now
now the problem with these is that the front right hayame is pretty much fcuked up
(see pics below). what basically happened was that these were on during an accident. a local shop took the damaged coilover and rewelded it. it looks sturdy and strong but i would recommend buying replacements from hayame.
now the front-left has cosmetic damage. where the tie rod connects, their is a about 120 degree crack on the paint/weld. its about 1mm in width size BUT i am not sure that it cracked through the paint and/or the weld. i brought it to techday and what i heard was that it seemed good to ride on. see pics for crack damage
as for the 2 rears, its basically used and works fine. its possible to use your stock/oem uppermounts on the hayames but i cant gaurantee that because i've never tried it. other then that, the rears are fine. if you know anyone who does welding cheap, the front-left hayame shouldn't be a problem. but surely do recommend finding replacements for the front-right one because it looks pretty bad. if your willing to use stock uppermounts for the rears, thats great.
$200. im willing to meet up or travel a certain range of distance. if no one calls this one out in nor-cal, its gonna be in the forsale forums.
if their are any questions about these, just let me know. if you want more pics of certain angles, just hit me up on aim: jttegx and let me know. if you dont use aim, post it here and ill keep this board updated
now pics of:
FRONT-RIGHT HAYAME
now pics of:
FRONT-RIGHT HAYAME
OMNES AD UNUM
Fronts
http://www.7thgencivic.com/forums/at...chmentid=30604
http://www.7thgencivic.com/forums/at...chmentid=30605
http://www.7thgencivic.com/forums/at...chmentid=30606
http://www.7thgencivic.com/forums/at...chmentid=30607
http://www.7thgencivic.com/forums/at...chmentid=30608
http://www.7thgencivic.com/forums/at...chmentid=30609
http://www.7thgencivic.com/forums/at...chmentid=30610
http://www.7thgencivic.com/forums/at...chmentid=30611
cdiajoe
Feb 15, 2004 01:22 AM
Keigo
Dec 5, 2003 11:35 AM
RcivicRR
Nov 20, 2003 05:04 AM
