Whats a good boost controller for sf kits?
Old Jun 10, 2004
Jeff's Avatar
Jeff is an unknown quantity at this point
Im going to be buying one soon, whats a good boost controller to buy and also a turbo timmer to work with a sf kit.
Let me know
Jeff
Old Jun 10, 2004
civic01vtec's Avatar
how much u looking to spend????
u want a manual or electronic?????
I paid $35 shipped for my mbc from ohmysac.
Old Jun 10, 2004
Jeff's Avatar
I want a good one, I going to be paying a lot for the turbo so I would like one thats going to do its job. Also civic01vtec, did you throw any check engine lights when you installed your kit?
I would like to get a electronic one.
Old Jun 10, 2004
well, if you want a good mbc.......u can get the turbo xs dual stage.....ohmysac's is a good one too, it is the same one catalyst uses and a few others.
electronic ones........ apex'i avc-r, greddy profec-b or greddy e-01.......but expect to pay 300-500 for these.
yes, i have a CEL........b/c i don't have my IAT sensor hooked up
Old Jun 10, 2004
Jeff's Avatar
Is the Iat sensor the same thing as the map sensor missing link?
Old Jun 10, 2004
no, IAT is the Intake Air Temp. sensor that is mounted in ur stock air box or intake pipe. SF doesn't give u a hole for this, so most of us just ties it off.
Old Jun 10, 2004
Jeff's Avatar
ohh ok i know what you mean, I wasnt thinking straight. If i drill a hole in the sf piping and install a rubber holder from a aem it should be cel free then? saying that i have a aftermarket high flow cat with o2 sensors installed.
Old Jun 10, 2004
right, but some off us aren't sure if the rubber gromet will hold and won't blow out. One member (HTOWNBOY) used resistors or sumtin to trick the sensor, but i forget what. Guns knows about it.
Old Jun 10, 2004
MadWheel's Avatar
Premium Boosted Member
I made a DIY on how to use the stock IAT with the SF kit. All you really need is some sandpaper, a drill, a bit, and a pipe tap. Mine's just the way it was when I first installed the sensor. And it did help my car.
civic1316
May 29, 2015 05:13 PM
autowill
May 15, 2015 11:36 AM
Supramk3
May 11, 2015 07:55 PM
superstanko
Apr 28, 2015 04:38 AM
