What the hell is this noise?!
Old May 7, 2004
Solidus's Avatar
IM RICH BIACH!
Solidus is on a distinguished road
Question What the hell is this noise?!
When I am in between 3000 and 3500rmps my engine makes like a lound vibrating noise or something. Pretty high pitched. You drop below 3000 or go over 3500 and it immediately goes away. It sounds a lot louder when it is really cold and when it is hot out it sounds like it is totally gone? What the hell is it?
Old May 7, 2004
deciuss's Avatar
Boosted Auto
do you have any mods done to your car or is it stock
Old May 7, 2004
Solidus's Avatar
IM RICH BIACH!
Totally stock
Old May 7, 2004
zen_master's Avatar
should check ur air filter...
or maybe the injection? try using injector cleaner?
Old May 7, 2004
Solidus's Avatar
IM RICH BIACH!
No i didn't think of that, I guess that could cause that noise.
Old May 13, 2004
hooter73mc's Avatar
hooter73mc is an unknown quantity at this point
air box or valve adjustment
Old May 13, 2004
CivicHX01's Avatar
it could be the crank pulley or other pulleys... i have the same problem but its cuz i didn't lubricate when i installed my rvm pulley... it is gone when its hot outside, and loud when its cold outside...
Old May 13, 2004
I've had that same noise for a long time. Sounds like a ricey intake noise almost. Only does it sometimes. I never figured it out.
Old May 13, 2004
CivicHX01's Avatar
oh and try turning on the a/c... if it gets louder, then it really is one of the pulleys... cuz when i turn on my a/c, it gets really loud... but if not, then maybe its something else...
Old May 13, 2004
Solidus's Avatar
IM RICH BIACH!
Well i just tried the AC thing. I didn't notice it getting any louder. mmm, not sure. But thaks for your help CivicHX, i'll check to see if the pulleys are problem
Old May 14, 2004
04em2's Avatar
04em2 is an unknown quantity at this point
i had a similar high pitched noise in my mitsu....turned out to be the heat shield on the exhaust....maybe thats it...just a guess
Old May 14, 2004
kiwi133's Avatar
kiwi133 is an unknown quantity at this point
I heard it on my car before, a few times when it was cold. Never hot.
I just figured It was some vibration that came from the vtec engaging, or maybe not deciding to be on or off because of the cold? Maybe it is the vtec NOT engaging because of the cold, and the engine gets a slight out of breath sound starting about that rpm? Maybe above 3500 vtec is forced on no matter what as a saftey thing so one could um... accelerate if they really needed to.
I noticed you have an EX as do I (with vtec), and civicHX01 has the super econo vtec. Anyone with a VP, LX or DX (non-vtec civic) ever hear this noise?
I am 100% stock btw
Old May 14, 2004
teampointless's Avatar
Ultimate Member
Anyone have any other ideas... I've noticed it also. 2001 EX w/ VTEC
Old May 14, 2004
cryption's Avatar
2003 Nissan Frontier
i had a noise similar to that and they said a bolt came loose and fell into my exhaust and they took it out and it's been good since
Old May 14, 2004
cryption's Avatar
oh and im LX
Old May 14, 2004
Solidus's Avatar
IM RICH BIACH!
A bold huh? I guess i could just take it to a shop and have them check it out. I'll probably take it in on monday. I'll let you guys know what the final verdict is on that freaky noise.
Old May 14, 2004
KrayziELX's Avatar
KrayziELX is an unknown quantity at this point
i have an LX and i got the same noise, i had it before i put my pulleys on and after i put them on its still the same so i dont think its my pulleys, i've been told it was either that i need a valve adjustment or something w/ the exhaust up front like header or heat shield .. im still up for more suggestions cause i dont know exaclty what it is and i dont have the money to go have something fixed if thats not what it is.
how many people have had this problem?? maybe we can complain to honda and get a recall or something for the people who have it and are still totally stock
i started hearing it about 60000 miles, i had my timing belt replaced the same time i put my pulleys on bout 2 weeks ago at 85000 miles, but i still hear it .. like a quick tapping noise.
i'll try to get a free diagnostic from a shop and then i'll post what they said it was
Old May 14, 2004
Solidus's Avatar
IM RICH BIACH!
That sounds good, let me know what they say.
Old Jan 10, 2009
dubD02CiViC's Avatar
dubD02CiViC is an unknown quantity at this point
Re: What the hell is this noise?!
Sorry to revive a dead thread but my civic is starting to make a vibrating noise like this when I accelerate. Did anyone figure out what the problem is????
Old Jan 10, 2009
WannaBFast's Avatar
Prowlin' with a Purpose
vibrating noise when accelerating.. most likely a motor mount.. check for this by holding the brakes and loading the engine in a gear, and have someone check out hte engine rocking back and forth
usually the front mount is busted.. ive replaced mine twice then i put energy poly inserts in
Old Jan 10, 2009
Cleft_Asunder's Avatar
Cleft_Asunder is a glorious beacon of lightCleft_Asunder is a glorious beacon of lightCleft_Asunder is a glorious beacon of lightCleft_Asunder is a glorious beacon of lightCleft_Asunder is a glorious beacon of lightCleft_Asunder is a glorious beacon of light
Check the hood. With the hood closed, raise the front up and down. If there's play, lower the bracket. If bracket is as low as it can go, dremel the holes longer at the top.
cukaracha
Aug 29, 2015 05:27 PM
ex2peria10
Aug 27, 2015 09:02 PM
WaryDriver
Aug 22, 2015 06:50 PM
JetsterDajet
Aug 15, 2015 08:07 AM
15EXCoupe
Jul 30, 2015 12:59 PM
