toda vtec killer cams for the d17
"mmmBAHHHH" - vtec y0
can some body anybody give me some info on the toda race cams. i dont even know if im posting this in the right forum but id like some info on em. i know they cost and arm and a leg but i hear the performance with em is amazing so could somebody please give me some info or a link to the site. thanks alot
DH, Bullfrog(Gude), KMS, and Crower .... Crower and DH are the lowest priced versions of a regrind out right now ... There are currently NO replacement cams available for the D17A(x) that I have heard of ..
toda vtec killer cams for d17 will never happen man. sorry to be the bearer of bad news but d17 is like a black sheep motor man. we dont get half the **** bseries motors get.
yeah i know it sucks.....me n my buddies just pulled the d15 outta his crx and they were puttin the tokico shocks n struts in when i left its about 2 get a b18 and im jealous
I need TP for my bunghole
header headers cam cams you know what they mean
anyway this site appears to have a cam for our car so they say
http://www.namotorsports.net/listing...at=8&subcat=83
Autotech 260 Degree Sport Hydro Camshaft (8V)
Universal - fits all vehicles
Product's Details:
This sport hydraulic lifter camshaft was originally developed for use in Volkswagen G60 engines. The unique demands of a forced-induction engine require a special cam design to fully optimize power gains. Shorter duration with less overlap are key features in getting the biggest charge possible into the combustion chamber. Too much overlap will result in "wasted" intake air, literally running through the motor without being used. This cam is also suitable for use in A3 2.0L cars, as it is does not usually require updating the valve springs, or remapping of the car's ECU to run well. It is 50 state legal under C.A.R.B.E.O #D-375-1. This camshaft will provide gains of approximately 10 horsepower on a G60 engine. Asymmetric. Lift:0.421 Int/0.409 Exh, dur:260°/256°,111° LC. The Autotech 260° Hydro Cam is ground on an OEM Chill-hardened billet. Lifetime Warranty from Autotech.
Autotech 270 Degree Sport Hydro Camshaft (8V)
Product's Details:
What we feel is the finest sport hydraulic lifter camshaft available. Extensive experience with the VW engine design as well as consistent engine dynamometer testing has resulted in a camshaft that is without question the smoothest, most drivable performance cam you can buy. The AUTOTECH Sport 270° Hydro cam is 50 state legal under C.A.R.B. E.O. # D-375-1. This cam allows the VW enthusiast to enjoy the benefits of a substantial power increase with no sacrifice in drivability. The AUTOTECH 270° Hydro is the best performing street legal camshaft available. Its idle characteristics have been refined to the point that it idles as if it were a stock cam (15 inches vacuum @ 900rpm). Yet, its full-range power lets you know that it is definitely not stock! Torque increases over stock appear as low as 2500 rpm, continuing without fail until over 6000 rpm. Power gains range from 7 to 9 horsepower depending on vehicle and its state of tune. Lift: 0.449", duration: 270deg. at 0.1mm check, 112deg. LC. Fits all 1.8 and 2.0 liter engines with hydraulic lifters, including crossflow heads. The AUTOTECH Sport 270° Hydro Cam is ground on an OEM Chill-hardened billet. Lifetime Warranty from Autotech.
Autotech 286 Degree Solid Lifter Sport Camshaft (8V)
Product's Details:
This cam runs strong after 3000 rpm and peaks at 6800 rpm, netting a 13 horsepower gain. The profile is 11.2mm lift with a 286 degree duration measured (the European way) at 0.1mm check clearance. Translated, this is 0.436 inches lift and 243 degrees of duration at 0.050" check clearance. The AUTOTECH Sport 286° solid lifter cam works best on injected cars that are already extensively modified. This cam requires the use of SportTuned valve springs and may require lifter bore clearancing on 1.6L and 1.7L production cylinderheads. Lifetime warranty from Autotech.
Product's Details:
Product's Details:
Product's Details:
ricer_em2
May 11, 2016 08:09 PM
beanhead
Sep 24, 2015 12:04 PM
OptimisticWay
Sep 18, 2015 09:37 PM
Juanb24
Sep 15, 2015 12:39 AM
