Rough Idle
Old Apr 22, 2004
VtecViXen
Guest
Posts: n/a
Rough Idle
Hey I was talkin to a homie on 7thGen today and seems we have a similar problem with rough idle'ing... for some reason Im not idling high or anything, just rough, and it gets loud like every couple minutes for like 30 secs or something. Ive heard alot of people with something similar. Replaced the battery thinking it may be that, no. Checked my spark plugs, good there. And i dont know what the problem could be. Honda doesnt seem to know either.
Old Apr 22, 2004
Rough idle can be caused by a number of things. Iridium plugs will improve it, but you may also want to check your ground wire connections and maybe even upgrade them. There's one to the tranny and chassis, and another one from the engine to chassis (silver I think). Make sure connections aren't corroded.
Old Apr 22, 2004
VtecViXen
Guest
Posts: n/a
only other thing we could think of is maybe the ECU
Old Apr 22, 2004
MangoEX's Avatar
Just Be
MangoEX should not be trusted
My guess is ECU...
Old Apr 22, 2004
MangoEX's Avatar
Just Be
no sounds like her problem goes beyond spark plugs and grounding wires, especially if she hasn't touched those from the factory. I'd start at the engine/tranny mounts, then work my way to the ecu
Old Apr 22, 2004
You could try resetting the ecu by pulling the battery for 5 mins, then reconnecting and just let the car idle for 10 mins. Then turn it off and back on to go drive.
But check the ground wire (silver one). It grounds the ECU.
Old Apr 22, 2004
Good idea. It may be engine mounts or something that's causing vibration. Make sure the plugs are torqued to 14 ft/lbs.
Old Apr 22, 2004
VtecViXen
Guest
Posts: n/a
just seems strange so many people have a similar thing goin on
Old Apr 22, 2004
yourinmyw0rld's Avatar
does ur RPM gauge go up and down????
Old Apr 22, 2004
VtecViXen
Guest
Posts: n/a
no rpm is cool, thats the weird part
Old Apr 23, 2004
Nodnero's Avatar
Hmmm. . . . check your fuel filter. That COULD be something, it was a problem with my suburban. Could be the same thing.
Old Apr 23, 2004
kafyn722's Avatar
i know i know, its a honda. j/p
Old Apr 23, 2004
fonto's Avatar
The LA Clipper
Do you play your radio alot with your car off? When you car starts does it do it, or do you have to drive a couple miles before it happens?
I know with my car it always runs at atleast 14.3-14.4 volts (up to 14.7) when i start the car, but it will drop down after a few minutes of driving and playing the radio.
The civic battery is weak as heck though...I would try upgrading your grounds...and maybe think about a better battery...and always turn your car on if you are using any of the electronics in the car.
Old Apr 23, 2004
x007den's Avatar
x007den is an unknown quantity at this point
yup, try this out. it might not do it but its another thing off your checklist.
Old Apr 23, 2004
VtecViXen
Guest
Posts: n/a
yeah i replaced the battery with a interstate, so it aint that.....ill check the fuel filter and im also gonna try to reset the ecu i guess.
Old Apr 23, 2004
dj02's Avatar
wouldnt be ecu you gould get a CEL. have u messed with the trotle cable at all? i rember when i first tightned my trotle cable i did it to much and it started doing it the same thing. so check that, if not check ur pluggs, how many miles u have on them? may need new ones OEM plugs are ****......
Old Apr 23, 2004
VtecViXen
Guest
Posts: n/a
yeah im gonna get new plugs, hopefully willl help the problem, i was thinkin about NGK Platinums.....what do you think?
Old Apr 23, 2004
dj02's Avatar
thoes or the denso's
Old Apr 23, 2004
VtecViXen
Guest
Posts: n/a
denso what? which ones? but then i know with my other car, getting anything but stock actually hurt it in the long run. What about that Vin? Is it ok on the car to use after market plugs?
Old Apr 23, 2004
dj02's Avatar
denso irdiums... and no it wouldnt hurt only make things better.
Old Apr 23, 2004
VtecViXen
Guest
Posts: n/a
how much do those run? i know the ngk's are so freakin expensive
Old Apr 23, 2004
dj02's Avatar
about 50.00
Old Apr 23, 2004
VtecViXen
Guest
Posts: n/a
oh that aint bad, well ill try it and see what happens....ill have you listen to it this weekend, see if you think anything else could be wrong...seems wouldnt be a problem since i got the car if its just spark plugs, but well see.
Old Apr 23, 2004
dj02's Avatar
-werd
Old Apr 23, 2004
Nodnero's Avatar
FUEL FILTER!!!
Old Apr 23, 2004
dj02's Avatar
^^^ehhh maybe but it shouldnt be that but then again it's a honda
Old Apr 23, 2004
VtecViXen
Guest
Posts: n/a
yeah ill check the fuel filter too chase....i hope its not that, i only use 91 octane and i use fuel cleaners and everything, dont know why that would be a problem
Old Apr 23, 2004
Nodnero's Avatar
How long have you had it? Fuel cleaners only help clean injectors.
Old Apr 23, 2004
xstrghstx2k1's Avatar
xstrghstx2k1 is an unknown quantity at this point
do what i am going to be doing get rid of it and upgrade.. teheheheh
Old Apr 24, 2004
MangoEX's Avatar
Just Be
jonda.. Denso Iridium IK22s are what i got $55 on the bay
