OEM fogs not working....need help
Old Apr 7, 2004
VellVic's Avatar
VellVic is an unknown quantity at this point
They are Honda OEM fog lights installed after I brought the car. They worked until one of my fogs blew out (driver side).....so I just stopped using the fogs. i recently purchased some hyperwhite h11 bulbs and replaced the blown fogs wit the new fogs. When I went to go test my fogs, they both didn't work . Anyone have an idea on what could be wrong. Thanks
Old Apr 7, 2004
CvC-v01's Avatar
CvC-v01 has a little shameless behaviour in the past
check the fuse on the wire of the fog light...or check your relay
Old Apr 7, 2004
VellVic's Avatar
what do i check for?
Old Apr 7, 2004
CvC-v01's Avatar
on the fuse make sure is still good........if its burn replace it...
the relay you can't really check...but check the fuse....it should be underneath the stearing wheel...i
Old Apr 7, 2004
MIT's Avatar
MIT
MIT is an unknown quantity at this point
maybe check the ground wires........
Old Apr 8, 2004
VellVic's Avatar
i checked the fuse, that seems to be ok...it's not burned or broken
Old Apr 8, 2004
CvC-v01's Avatar
are your wires burned that connect to your H11 bulbs........
Old Apr 8, 2004
VellVic's Avatar
not sure, when i replaced the oem bulds, the wires looked ok
Old Apr 8, 2004
CvC-v01's Avatar
did your lights come with you car when you bought it...
Old Apr 8, 2004
VellVic's Avatar
no, I purchased them from a honda dealer after I brought the car and got them installed professionally
Old Apr 8, 2004
CvC-v01's Avatar
your last try is the relay...i bought mine after market...
and they work pretty well the only problem i had was that my wire burned and it was causing one of my lights to be brighter than the other...so i replace it with a honda original wire..i had to do a mikey mouse but it works....but try your relay...and change your fuse even though it looks good........
Old Apr 8, 2004
VellVic's Avatar
do i call up honda to get a new relay?
Old Apr 8, 2004
CvC-v01's Avatar
yeah call honda..but before you buy the relay ask them if there is any way they can check your old one
UltraHDGames
Jun 8, 2016 05:16 PM
thatcham
Sep 30, 2015 08:28 AM
Cam Diaz
Sep 28, 2015 08:34 PM
meicalnissyen
Suspension
Sep 24, 2015 09:28 PM
h4ldol
Sep 10, 2015 12:25 PM
