Mtx 342 amp 340x1 85x2 75shipped
Old Mar 14, 2004
nunzio42's Avatar
nunzio42 is an unknown quantity at this point
Aight i dropped the price 25 bucks...anyone?
This list is for a MTX Thunder 342 amp. This amps sells for $249.00 new, this is a great deal!!
ThunderEQ bass enhancement makes the Thunder342 2-channel amp a great candidate for powering a subwoofer: you get 340 watts RMS in bridged mode, plus the ThunderEQ, or drive a pair of power-hungry component (or full-range) speakers with 85 watts RMS per channel, using the variable high-pass crossover. Speaker-level inputs let you integrate this amp with nearly any system, even your factory radio. Heavy-duty, nickel-plated terminal block connectors ensure efficient current transfer to the amp. Inside, high-powered transformers and patented PWM MOSFET switching power supplies deliver dynamic output for your speakers. Intelligent Surface Mount Design isolates various amp sections for greater operating stability and seriously low noise levels.
SPEC's
85 watts RMS x 2 at 4 ohms
170 watts RMS x 2 at 2 ohms
340 watts RMS x 1 bridged output at 4 ohms -stereo or bridged mono output
4-ohm stable in bridged mode -Tri-Way capable
Requires 8-gauge power and ground leads — wiring and hardware not included with amplifier
PWM MOSFET switching power supply Intelligent Surface Mount Technology for cleaner sound and greater reliability
variable (40-200 Hz) high-pass/low-pass crossovers (12 dB/octave in high-pass mode, 24 dB/octave in low-pass mode)
ThunderEQ Bass Enhancement (0-18 dB bass boost at 40 Hz)
preamp outputs
speaker-level inputs with SmartEngage (turns the amp on when it detects signal from the receiver, eliminating the need for a separate turn-on lead from your receiver)
Used for about 2 months.....no problems with it. Upgraded my amps to xtants.....so no need for this amp 75 shipped any questions pm me please.
Old Mar 14, 2004
nunzio42's Avatar
heres a pic
File Type: jpg
Old Mar 14, 2004
nunzio42's Avatar
bump b4 bed
Old Mar 15, 2004
nunzio42's Avatar
bump
h4ldol
Apr 24, 2017 08:16 PM
Mad Dog Tannen
Oct 19, 2016 08:12 PM
UltraHDGames
Jun 8, 2016 05:16 PM
Mc7602
Sep 17, 2015 02:01 PM
redcloud
Sep 7, 2015 01:45 PM
