///ALPINE 9815 Settings
Old Mar 9, 2004
hondacivic218's Avatar
hondacivic218 is an unknown quantity at this point
Okay if someone has this deck can u guys please give me your setting for the time Correction and the Xover settings im so confussed in this stuff.....i have 03 Door Civic, all stock speakers no subs. i know the deck is like 899$ CND here in Ontario so im broke..
Please Help me Out
Old Mar 9, 2004
I have an 03 2 door!!!
Old Mar 9, 2004
bickford05's Avatar
bickford05 is an unknown quantity at this point
is it a correction for wireing to hook it up? or a setting on the deck?
if its something to do with programing the deck call alpine, they probaly have over the phone help
Old Mar 9, 2004
civicvtec1ps's Avatar
Search and Learn
Moved to I.C.E. & Electrical
Old Mar 9, 2004
03HondaEx's Avatar
03HondaEx is an unknown quantity at this point
Let me ask my neighbor...his mom works for alpine...and they got some sick stuff in their cars...hopefully they can get me a new tv screen...
Old Mar 9, 2004
im talkin abou the setting on the Deck! not the wiring
Old Mar 9, 2004
LudlamTheory's Avatar
i boogie for the raindrops
if youre using a completely stock system with that deck, all those settings wont change single thing in your sound. dont bother...
Old Mar 9, 2004
tfnaaf's Avatar
BLDNPSI Mod
It should say in the manual, i just sent my iva-d900 in 2 weeks ago for repair but the time correction is based off of the distance from the speakers to the drivers ear. There was a formula, i'll try to find it................
Old Mar 9, 2004
tfnaaf's Avatar
BLDNPSI Mod
Owners manual
About Time Correction
The distance between the listener and the speakers in a car vary
widely due to the complex speaker placement. This difference in the
distances from the speakers to the listener creates a shift in the sounds
image and frequency characteristics. This is caused by the time delay
between the sound reaching the listener’s right versus the left ear.
To correct this, the CDA-9815/CDA-9813/CDA-9811 is able to delay
the audio signal to the speakers closest to the listener. This effectively
creates a perception of increased distance for those speakers. The
listener can be placed at an equal distance between the left and right
speakers for optimum staging.
The adjustment will be made for each speaker in 0.1 ms steps.
Example 1. Listening Position: Front Left Seat
Adjust the time correction level of the front left speaker
to a high value and the rear right to zero or a low value.
*1 Subwoofer speaker.
CDA-9811 only
You cannot change the Time Correction value for the subwoofer,
but you can set the subwoofer's apparent position to the front by
adjusting the Time Correction value of the front and rear speakers.
For details, refer to the “ *1 ” on page 18.
The sound is not balanced because the distance between the
listening position and the various speakers is different.
The difference in distance between the front left speaker and
the rear right speaker is 1.75 m (68-7/8").
Here we calculate the time correction value for the front left
speaker in the diagram on the above.
Conditions:
Farthest Speaker – listening position : 2.25 m (88-9/16")
Front left speaker – listening position : 0.5 m (19-11/16")
Calculation: L = 2.25 m – 0.5 m = 1.75 m (68-7/8")
Time correction = 1.75 ÷ 343*2 × 1000 = 5.1 (ms)
*2 Speed of sound: 343 m/s (765 mph) at 20°C
In other words, giving the front left speaker a time correction
value of 5.1 ms makes it seem as if its distance from the
listener is the same as the distance to the farthest speaker.
Time correction eliminates the differences in the time required
for the sound to reach the listening position.
The time of the front left speaker is corrected by 5.1 ms so that
its sound reaches the listening position at the same time as the
sound of other speakers.
Example 2. Listening Position: All Seats
Adjust the time correction level of each speaker to almost the same
level.
1 Sit in the listening position (driver’s seat, etc.) and
measure the distance (in meters) between your
head and the various speakers.
2 Calculate the difference between the distance to
the farthest speaker and the other speakers.
L = (distance to farthest speaker) – (distance to other
speakers)
3 Divide the distances calculated for the speakers by
the speed of sound (343 m/s (765 mph) at 20°C).
These values are the time correction values for the
different speakers.
2.25m
0.5m
5.1ms
*1 *1
Hope this helps
Old Mar 9, 2004
Civicly02's Avatar
I have that headunit and just go to their website and go to the i-personalize and it will measure it for you
Old Mar 10, 2004
Civic_Racer9's Avatar
(SnOwBoArDeR | FoReVeR)
heh dont worry about time correction ish.....and as for the Xover, change that to flat to get more bass......i have my xover on flat
Old Mar 10, 2004
can u post ur setting for ur Xover just to campare with mine!
thanks
Old Mar 10, 2004
coop's Avatar
coop is a jewel in the roughcoop is a jewel in the roughcoop is a jewel in the rough
I have the 9811 - I had the tweeter salesperson tune it for me. He used a special tape measure that gave you the seconds of time (marked right on the tape measure) which made it easy.
The idea is that you're centering the sound dependent on where you most sit (drivers seat) and I have to say that after having this done I prefer it time corrected. I think you will need higher end speakers to realize the effects though - as Ludlam points out the stocks are crap and you won't see much from this....I'm running Boston 6.5 comps in the front and 6 x 9's in the rears.
Old Mar 13, 2004
etdigitalis's Avatar
etdigitalis should not be trusted
I agree with Ludlam too...
I put a 9815 in my 01 coupe about 4 months ago. I had already purchased JBL 605C comps for the front and GTO936 3-ways for the back, but left the factory cones in there for a week just so I could compare.
When turning up to a reasonable listening volume, the distortion became very evident... those paper things just don't like to be pushed. Even though they were made by Pioneer, they were guided by OEM specs, rendering them crap.
After hearing the extreme difference in clarity between the two, I can gladly say that the painful install was worth it.
Removing the entire rear seat, trim paneling and trunk spring to get to the rear speakers!? But again, it was well worth it...
etdigitalis
"The best headunit in the world can't overcome inadequate speakers."
- Alpine's Website
Old Mar 14, 2004
coop's Avatar
I think the stocks are 15 watt max - very disappointing. I have never had very good experience with Pioneer audio. Ran a pair of 61/2's in the front of my Neon and they never sounded very good. Had to use an active crossover to filter out low end...
Old Mar 15, 2004
WhiteCastle's Avatar
http://www.7thgencivic.com/forums/fo...5&pagenumber=5
GolNat
Nov 27, 2018 03:32 PM
JMKendrick
Sep 16, 2015 06:17 PM
Wheela
Wheels and Tires
Sep 7, 2015 02:14 AM
JohnDay
Wheels and Tires
Sep 6, 2015 06:42 PM
