Help with cleaning piston rings
Old Feb 28, 2004
sakabatou's Avatar
sakabatou is an unknown quantity at this point
I did a compression test on my friend’s car and it had bad compression. The rings on the piston are leaking. They are not broken or any thing the rings just have carbon deposits on them. My question is that is the best thing that he can do. I don’t want to go to a shop and get it Carbon clean. Too much money. I know that you can add some stuff to your gas that will help clean the stuff off. But what is the best to use.
Old Feb 29, 2004
tfnaaf's Avatar
BLDNPSI Mod
If you did a compression test and it was low, then pretty much nothing you can do short of new rings, bore new pistons that will ensure good results. If anything by cleaning the carbon off ive seen more problems pop up like the engine will start to smoke.....
Old Feb 29, 2004
VTECnique's Avatar
VTECnique is an unknown quantity at this point
it could be a couple things other than bad rings... like for instance valves not seating properly. it will most likely be the rings but in either case the engine will prolly need to be torn down for a rebuild.
GritzNGravy
Aug 19, 2015 03:03 AM
Butterfli13
Aug 12, 2015 11:04 PM
Green02civic
Jul 27, 2015 10:48 PM
estes53
Jul 20, 2015 10:43 PM
muttleytm
Jul 8, 2015 04:13 PM
