Finished box today, and put a hole in my sub. I SUCK
Old Jan 14, 2004
quick83's Avatar
quick83 is an unknown quantity at this point
Well the carpet and grill came today so I was able to finish the box I made. However when I was putting everything back together the drill slipped and put a small hole in the rubber around the sub. I’m pretty pissed but what can I do. It doesn’t sound bad though; my fried said it sounds the same. So I don’t know what to do.
Old Jan 14, 2004
civic01vtec's Avatar
junk it...........there is nothing u can do. The hole will only get bigger after u keep playing it.
When i am drilling the screws for mounting the sub, i always cup my hand around the screw and drill, so in case i do slip, my hand will stop it.
Old Jan 14, 2004
Ed's Avatar
Ed
Forget drilling through your hand, save the speaker!
just dab some silicone or the like on it, I think it should be alright
Old Jan 14, 2004
CelCUs's Avatar
CelCUs is an unknown quantity at this point
Had a pic of my box up here but took it down . . . and yes the sub, 6 x 9 and amplifier chambers were all seperated LudlamTheory
Old Jan 14, 2004
WhiteRabbit's Avatar
i hear that nailpolish can help seal it, i dunno though. silicone seems like it would work better.... like a tub sealer or something real real rubbery
Old Jan 14, 2004
cambo's Avatar
I wish I was asian
thats a rockford punch HE2 correct? what size? i got a pair of 12s in a bandpass box.
Old Jan 14, 2004
quick83's Avatar
12"
Ill try silicone the hole is real small like 3/16"
Old Jan 15, 2004
LudlamTheory's Avatar
i boogie for the raindrops
i really hope that the 6x9 and the sub chambers are separated
Old Jan 15, 2004
jwalker87's Avatar
Bodacious Member
jwalker87 is an unknown quantity at this point
yeah, holes in the rubber surround part are fine. If you dont feel comfortable doing it yourself, there are shops that do it. Last year we took a pair of home theater loudspeakers that had HUUGE holes in that part of the woofers to a guy who re-did that surround part. It might not sound quite as good, but better than ditching the speaker.
Old Jan 15, 2004
AlpineCivic's Avatar
You can use sillicon or anything similiar but dont put too much or use a product that is very thick and heavy since this will change the center of gravity of the cone and change the sound.
Old Jan 15, 2004
7thGenerasianCivic's Avatar
damn... that is the worst thing you could do to a sub. I would go with what they said. Dabb some rubber on it.
Old Jan 15, 2004
PopcornPlaya's Avatar
Electric Boogaloo...
another good investment for future reference would be one of the magnetic screw guides. they have a slider thing that you slide down over the screw to keep it from wobbling, and keep it aligned straight. that could help in keeping the screw/bit from finding an undesired resting place. i use them all the time, and they work great. i think they are available in a kit with different bits for like 8 bucks.
Old Jan 15, 2004
Or do it the right way Drill the correct size hole Tap it and then you dont have to worry about messing up cause the screw will go right in with out the need of a power tool.
Old Jan 15, 2004
exept for a drill ;p
i prefer the guides
Old Jan 15, 2004
jwalker87's Avatar
Bodacious Member
what I do is to mark the holes with sharpie while the sub is on. Then take the sub AWAY from my workspace, and then do the drilling. I do pilot holes, then use a drill to thread the screws all the way in, then back out. Then I bring the sub back over and the holes are already made and threaded and everything. No danger to the sub, unless my sharpie slips.
Old Jan 15, 2004
i dunno man, sharpies can punch a hole through engine blocks, they can be darn violent!
Old Jan 15, 2004
quick83's Avatar
there were already holes there already it was my own stupidity. Anyway i fixed it today, I work at a frame shop and we use this silicone adhesive/ sealant. Its strong stuff we use it to mount objects on to mat board in shadow boxes. So I used a little on both sides, so i should be all set.
Old Jan 16, 2004
JohnDoe's Avatar
JohnDoe is an unknown quantity at this point
I'd say junk it and buy a JL
Old Jan 16, 2004
jwalker87's Avatar
Bodacious Member
yeah JL's are awesome, right? I have a JL 15w0 sitting in my room waiting for my JBL amp to arrive; i cant wait. It's gonna be a hell of a lot better sounding than my Sony and with 2 8" Audiobahns.
Old Jan 17, 2004
quick83's Avatar
I put it in my car yesterday morning and it sounds fine.
ORskier
May 7, 2015 04:54 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
OoSiLvErCiViCoO
Nov 14, 2001 11:35 AM
OoSiLvErCiViCoO
Nov 14, 2001 06:21 AM
katya
Nov 9, 2001 06:15 PM
