Brand New Sandisk Compact Flash Memory Card 256mb!!!
I buy these in bulk so i can offer you some decent prices!!! the more you buy the cheaper the price!!!
1 card = $70.00 Canaian
2 cards = $130.00 Canadian
3 cards = $200.00 Canadian
Shipping will be about $4.00 Canadian for most States!!!
here are the specs:
System Performance
Start-up Time
Sleep to Write 2.5 msec max.
Sleep to Read 50 msec max.
Reset to Ready 50 msec typical
400 msec max.
Data Transfer Rate to/from Flash 20.0 MB/sec burst
Data Transfer Rate to/from Host 16.0 MB/sec burst
Active to Sleep Delay Programmable
Controller Overhead Command to DRQ 50 msec max
Power Requirements
DC Input Voltage
Commercial 3.3V ± 5%, 5V ± 10%
Typical Power Dissipation
Sleep 200µA (3.3V) 500µA (5V)
Read 21 mA (3.3V)
34 mA (5V)
Write 21 mA (3.3V)
34 mA (5V)
Environmental Specifications
Temperature
Operating Commercial 0 - 60º C
Operating Extended -40 - 85º C
Non-Operating Commercial -25 - 85º C
Non-Operating Extended -50 - 100º C
Humidity
Operating 8 - 95%, non-condensing
Non-Operating 8 - 95%, non-condensing
Acoustic Noise (at 1 meter) 0 dB
Vibration
Operating 15 G peak to peak max.
Non-Operating 15 G peak to peak max.
Shock
Operating 2,000 G. max.
Non-Operating 2,000 G. max.
Reliability and Maintenance
MTBF (Mean Time Between Failures) >1,000,000 hours
Preventive Maintenance None
Data Reliability < 1 non-recoverable error in
1014 bits read
Physical Specifications CompactFlash CompactFlash Adapter
Length 1.433 in
(36.4 mm) 3.370 in
(85.6 mm)
Width 1.685 in
(42.8 mm) 2.126 in
(54.0 mm)
Thickness
(Body) 0.130 in
(3.30 mm) 0.1968 in
(5.0 mm)
Thickness
(Removable Edge) 0.155 in
(3.94 mm) N/A
Weight 0.40 oz
(11.4 g) 1.16 oz
(33 g)
Ordering Information
Order Model # SDCFB-YY CompactFlash
SDCF-03 CompactFlash Adapter
YY: 16: 16.0 MB
32: 32.1 MB
64: 64.2 MB
128: 128.0 MB
192: 192.0 MB
256: 256.9 MB
384: 384.5 MB
512: 512.5 MB
thanks
JUST PM ME IF YOU WANT ANY!!!
here are the specs:
System Performance
Start-up Time
400 msec max.
Power Requirements
DC Input Voltage
Read 21 mA (3.3V)
34 mA (5V)
Write 21 mA (3.3V)
34 mA (5V)
Temperature
Humidity
Vibration
Shock
1014 bits read
Length 1.433 in
(36.4 mm) 3.370 in
(85.6 mm)
Width 1.685 in
(42.8 mm) 2.126 in
(54.0 mm)
Thickness
(Body) 0.130 in
(3.30 mm) 0.1968 in
(5.0 mm)
Thickness
(3.94 mm) N/A
Weight 0.40 oz
(11.4 g) 1.16 oz
(33 g)
YY: 16: 16.0 MB
32: 32.1 MB
64: 64.2 MB
128: 128.0 MB
192: 192.0 MB
256: 256.9 MB
384: 384.5 MB
512: 512.5 MB
thanks
brags
46
Jan 7, 2016 09:39 PM
